fredk
Contributing Member
Everything posted by fredk
  1. A follow up; I bought a small fixed spool reel and the idea would work, but the reel's line section has to match the bobbin thread section. I went to an angling shop and the chap there helped me search out a reel. We found a few. But I can't afford to buy it for about 7 days, when I get some pay in Continued on
  2. Try it on a curve. The pieces probably match when you try it on a curve, such as your waist.
  3. Are they 3D printed?
  4. I would use upholstery grade chrome tan leather. Mainly because I have tons of it. The upholstery leather is very flexible and would fall nicely. Mine is about 1.5 mm thick so it would be heat resistant. In fact I made a part-time blacksmith a waist length apron out of it and it served him well
  5. Why are you home so late? A guy down the pub lost a $100 note Were you helping him look for it? No, I was standing on it
  6. You can reduce the tack of any tape by putting in on your jeans first then pulling it off. The more times you do this the tack gets weaker each time
  7. Double sided sticky tape or rubber glue?
  8. Not me I couldn't fit it in one photo. Not that its large but the different areas
  9. and Dusty covered Downtown
  10. On a different thread about tools wanted I said I wanted a tool to wind Boss bobbins. I started to think as I wrote. A fixed spool fishing reel could/might be adapted I bought a small fishing reel It will work but, a big but, the fishing reel spool has to match the Boss bobbin. On this one its only half size so would only wind the thread in the middle of the Boss bobbin When I get the chance I'll search out a larger reel. A lot of fishing/angling shops have closed up here recently. Some only sell on-line now
  11. I'm kinda busy the next few days but I'll devote time to it later in the week
  12. I got rid of all my Dusty Springfield CDs Now I just don't know what to do with my shelf I just might go Downtown
  13. Your PJ is different to my vaseline. The leather absorbed the vaseline I'll do some more tests later
  14. Yes and use plenty. Tie one end of the thread to something and, holding the other end, pull it tight, run your wax up and down the thread
  15. So for a hat measure round the crown on the inside
  16. Simple as can be; measure, in cm, around the head. just about 1 to 1.5 cm above the ears and eyebrows. For a small head this will be about 54 to 56 cm, for a medium head about 56 to 57 cm and for a large nut about 58 to 60 cm Here is a conversion chart to go back to the old hat sizes https://www.hatsandcaps.co.uk/pages/hat-size-guide
  17. Could you not finish it and sell it?
  18. afaik the man-made threads can be affected by UV light rays but linen is not. Linen goes slack when it gets wet, this may be beneficial in that leather swells when wet, so the linen thread wont cut into the leather whereas the man-made thread will Also its more 'traditional' so that be important to some people I have a queue building up of around 400 steering wheels to recover. A lot of them have the threads broken or weakened due to UV light and not wear & tear
  19. Nice So will I once this moves up to the 'I got to really, really, really finish . . . ' pile. At the mo its only in the ' . . .really finish. . . 'pile
  20. One thin coat will seal but not be heavy enuf to crack You can 'Mop and Glo' Its meant for wood floors but its a thin acrylic varnish. I use a local version of it regularly, Others on here also use it
  21. Have you tried a coating of varnish?
