Everything posted by Chief Filipino
That is a great idea! Although I personally would worry that the Tibetan masks would get ruined over repeated use. Maybe you have another mask that you could use that isn't so old or unique?
Thank you!
Hi everybody! So I finally finished a mask I was working on! It has some room for improvement but I really love it!
The leather is just some designer sides (I think that's what they call it) from Tandy that I have gotten at some really good deals. The weight is about 2 ounces to 4 ounces. Feel free to copy my design if you like. Let me know if you want/need the dimensions. I have been putting edge kote on but I'm starting to think I will skip this step because I personally like the feel of the raw sides.
Nicely done!
Steampunk Phone Holster
Chief Filipino replied to Airth's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Nicely done! Did you use the stamps for the gears or are those all hand cut/tooled/etc? Also how did you get the background on the inside of the gears? I am very impressed! -
Hello Moderators! I have been trying to post several topics and I go to add a picture or two, then get the message that I can only upload 1.46mb. So I resize my images and try to upload them again only to get the same message. I have tried to also just post one picture that is only 50kb but still get the same error message. At times I just give up, tonight it seemed that if I backed out of the post completely and got back into it that I was able to post though that hasn't always worked for me before. I'm not sure what you can do for this but I just wanted to give you the information to look out for and perhaps fix whatever bug may be causing this. Thank you for all your hard work! I love this site!
I have some questions regarding acrylic resolene and neatsfoot oil that I am hoping someone can answer: 1. How long will acrylic resolene last? If it is on a mask that is worn once or twice a year what is the expected life? 2. Will neatsfoot oil penetrate a piece that has been covered with acrylic resolene, let's say the piece has seen moderate use for a few to several years.
Hi Tom. I am beginning to play around with mask and after seeing your amazing piece I would like to pick your brain for some tips. I made a skull mask last year and covered it with a bazillion layers of acrylic resolene (I had three layers on it but as I wore it during a parade my sweat started coming through). It still has a bit of a smell to it unfortunately even after all this time. What do you use on the inside of your masks to help prevent sweat seeping into your mask?
Beeswax, some leather, a lighter, and a burnisher
Chief Filipino replied to Chief Filipino's topic in How Do I Do That?
Hopefully not! You're still using the site so I think it should be fine. The search doesn't pull what I am looking for unless I type in just one or two tags, but then I have to go through so much to find anything I'm looking for. That's just my experience anyway. -
Good idea Biker thanks! -
Thanks Madmax again. I need to learn how to type in the proper search terms when I am searching for a specific topic. -
Thanks Madmax! -
Chief Filipino posted a topic in How Do I Do That?
So I tried something out tonight that seemed to work fairly well. After all was said and done for my final burnishing touch I rubbed some beeswax on a piece, then flame kissed it with a lighter and immediately used my burnisher on it. I like the results, but I am not sure if this is a valid technique. 1. Has anyone else tried this? 2. Will this damage the leather piece? 3. Is there a better way? I like to use beeswax on my edges to seal them up instead of edge kote. 4. Thank you. -
Thank you! I will post a pic if it all goes successfully!
Nicely done!
Awesome thanks Michelle! Do you just use that or do you put any kind of finish on it?
Ummmmmmmmmmm sooooo ya my attempt was not very adequate. HAHAHA thank you for the tips. At this time I do have to do everything by hand, so unfortunately no buffer wheel other than my own two hands. Thank you for the assist. I have lots of work to do
Awesome work! Did you bevel the edges? It's hard to see in the picture but if I was wearing that kickass cuirass I wouldn't want square edges rubbing me as I moved about in it. This is an awesome piece and I am inspired to try my hand at one! Thanks for documenting the process!
"Sloth-Bag"
Chief Filipino replied to Youri's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
It's quirky and cute -
So I've been typing in the search bar to try and find information that I'm looking for but haven't had much luck. I am working on a mask that I want to add steer horns on and I wanted to know how best to polish/finish them. What I ended up doing was actually rubbing the outside with beeswax, turning it over my zippo, and then buffing it with an old t-shirt. They came out decent, though not shiny. Is this a valid way to finish them? Is there a better way? I am looking to do some other artistic somethingorother with the left over horn and would like to find a way to bring out the natural beauty of the horns. Any advice? What have you done? Anyone have any pictures? Thanks!
