Everything posted by Dwight
What Rubber Pad And Where To Buy For Shaping Holsters
Dwight replied to Wizcrafts's topic in Leather Tools
Vacuum bag 101: I bought my vacuum pump from Harbor freight, . . . they sell two models, . . . being the cheapster I am, . . . I bought the smaller one, . . . basically $100 a few years back. I went to JoAnn's fabric and bought some clear vinyl, . . . 30 inch by 45 or 48 (whatever the width is), . . . folded it in the middle, . . . contact cemented the edges for the first 2 inches or so, . . . came up with a bag that basically is about 26 by 22 inside (with the coupon, think it was $10 or so). Piece of rubber hose from my automotive pile of spare parts. Quart of Vacuum pump oil from McMaster Carr. Found the vacuum bag fitting on a website that sells vacuum bags & stuff for people doing wood veneer work. It was about $15 plus p&h. I wet the cut and sewn (except for the last edge under the trigger guard) holster piece, . . . wrap it around the gun or blue gun, . . . mold it a bit with my fingers just so it knows where it is supposed to be, . . . close up the bag, . . . turn on the pump, . . . let it pull down, . . . then most of the time, turn it off, . . . let the pressure equalize, . . . then hit it again. About 10 to 15 seconds each time is plenty. May God bless, Dwight -
FWIW, . . . the info I got years ago was to get Gum rubber, . . . 40 durometer, . . . and I got mine from McMaster-Carr. It worked great, . . . until I got to doing a lot of plastic fantastic bang sticks. Since they belonged to the customer, . . . I could not see breaking a $400 gun in a press to make a $60 holster. I quit using it and sold it, . . . use a vacuum bag now, . . . actually prefer it twice over the press. Press is great for doing bearings though, . . . lol. May God bless, Dwight -
Dye Rubbing Off?
Dwight replied to Starman's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
Dye is pigment is a liquid suspension medium (cliff notes version). When you dye something, . . . pigment lays on the top, . . . and out of the top 10 offenders in this problem, . . . black is by far the worst offender. You should have taken a used wash cloth (or piece of a terry towel) and just buffed it, . . . buffed it, . . . and buffed it until no more pigment comes off. That would have ended the problem for the 95% most part. To end it, . . . 100%, . . . you have to put on some kind of sealer. Yes, . . . it will eventually quit rubbing off, . . . but by buffing the heck out of it, . . . you can make it happen quicker. May God bless, Dwight -
Rob, . . . the old fashioned 50/50 (by weight) neatsfoot oil and virgin beeswax, . . . melted together, . . . will give you a really nice shine, . . . but the trick with it is that you have to work to get that high polish, . . . and it is a fragile finish, scratches fairly easy. If you are thinking show collar, . . . on for the ring, . . . then back in the box till the next show, . . . with a little buffing in between, . . . it should work for you. But, again, the initial "shine" takes some elbow grease. I cut the time a bit when I use it by rubbing it on, . . . going over it with a heat gun to melt the wax into and on the leather, . . . buff, . . . add some more product, . . . more heat, . . . more buff, . . . till I get it where I want to quit. May God bless, Dwight
Following up on what Renee said: do a search for Brazos Jack as author, . . . you will have to go down through the list, . . . you are looking for 4 separate posts, . . . one for the holster, then it's instructions, . . . another for the cartridge box, then it's instructions. Have fun, . . . I haven't made mine yet, . . . and the operative word is "yet", . . . May God bless, Dwight
That only works to a certain degree, . . . as the bag will mush up against the tooling and scramble it. I have come to the conclusion that I can have a formed holster / knife sheath, . . . OR, . . . I can have a tooled holster / knife sheath. Asking for both is asking for kids and peace and quiet, . . . it's either/or, . . . May God bless, Dwight
If you are waiting for the oil to soften and make the leather supple, . . . you have about 2 or 3 gallons to go. Take the belt in both hands, . . . and roll it like the little drawing. DO NOT roll it with the flesh side out, that will cause serious wrinkling. I even have a small steel rod that I will lay down on my work bench, . . . and roll it back and forth inside the belt to start breaking it in. I do this before dying, . . . after dying, . . . and after the final finish. That way my customer doesn't get a leather plank they have to try to wrap around their body. Oil alone will do it, . . . but there will be so much oil in the belt, . . . it will ooze out onto the customer's clothing, . . . will not be a happy scenario. May God bless, Dwight
- 3 replies
- neatsfoot oil
- how much oil to be applied
(and 2 more)
I've had mine for several years, . . . and have to say, yes, . . . it can be finnickey. It can be a pain. But then so can a Ford, Chevy, or an Austin-Martin. No, . . . the stitch on the back is not as pretty as the one on the front, . . . but it is a working stitch, . . . not intended to be the back side of a show piece in a museum somewhere. If you want a working machine you can take anywhere, . . . get one. If you are a whiney, grouchy, perfectionist crab, . . . probably need to get something else. As for their customer service, . . . my experience has been tops. My machine clunked on me twice, . . . both times I took it to them, . . . Ben cleared off his bench with only a couple hours notice, . . . fixed me up both times, . . . at minimum charge. Hand sewing, using two needles and saddle stitching will be a lot prettier if you are into esthetics, . . . personally, I'm not. And in all the belts, sheaths, holsters, etc. I've sent out to paying customers, . . . none of them has come back and wanted it dressed up. Anyway, . . . getting off the unpaid advertisement box, . . . good luck on your decision. May God bless, Dwight
Modern Cowboy Lawman Rig
Dwight replied to Jumpout's topic in Gun Holsters, Rifle Slings and Knife Sheathes
That is one beautiful rig. I've got a west Texas nephew LEO, . . . I can just see him in that rig. I'm gonna email him the pictures, . . . and I can hear him wanting one even now, . . . but I'd bet that the department would frown seriously on it. May God bless, Dwight -
Expanding on Electrathon's post: go on a diet, . . . when your shape from rib cage to thigh is similar to a telephone pole, . . . your belts will no longer become "bent". Seriously, . . . your body heat, . . . sweat, . . . and the pressure of your body attempting to escape the confines of the belt, . . . all add up to a modification in the shape of the belt. Same thing happens with your billfold. Buy a new one, . . . nice and flat, fits that skinny little box like it was meant to. Put a couple hundred bucks worth of 20's in it, half dozen credit card type items, a few business cards, some family photos, . . . two days later the shape is changed. May God bless, Dwight
Modified Embossing Not Making A Strong Impression
Dwight replied to jimmy eng's topic in How Do I Do That?
The first problem is I believe, the size of the plate. That much surface area needs some serious pressure, . . . and a solid bottom under it. Foam, wood, etc. will not do it, . . . steel would be preferred, . . . cover it with masking tape to prevent rust, etc. Secondly, . . . properly case the leather. Give it a good dunk in water, . . . submerge it for a good 15 seconds in water that is warm enough to feel warm, but not hot enough that you cannot keep your hands in it comfortably. Third, . . . cut the pieces a bit bigger than the finished product you want (I assumed you are making beer coasters). It makes for a whole lot easier handling as well as the water gets into the leather where it needs to be quicker and easier when cut into smaller pieces. When they are cut, . . . put them in the water and bend them back and forth a couple of times, . . . it works kind of like squeezing a sponge in water when you want to get it wetter, quicker. After you bring it out of the water, . . . lay it on a towel, . . . flesh side down, . . . let it return in color to just almost natural leather color, . . . it will be properly cased for your job, . . . put in under the press, . . . go for it. May God bless, Dwight- 8 replies
- emboss
- drill press
(and 3 more)
To Stitch Or Glue
Dwight replied to Kanuist's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Everything I would have said, . . . has been said. Glue it, . . . stitch it, . . . go on with life. May God bless, Dwight -
Another thing you can do is add a little alignment bar to the stamping tool. Take a collar with an allen head set screw, . . . solder a piece of a paper clip to one edge of it. Angle your collar onto the tool so that it is parallel to the edge of the belt while stamping in the configuration you want, . . . that way you only have to line up the direction, and the tip placement of the stamp. Works like a champ. May God bless, Dwight
Hey, Toolingaround, . . . thank you for the update. I have stayed away from NF simply because it DOES darken, . . . and if you want to keep the shade simple and clean, . . . can't do it with that. But the fact that they advertise it as non darkening, . . . i WILL be getting a jug of it. Gonna play with it, . . . and some day, if I live that long, I want to make a saddle for a special young lady (great niece), . . . and it will be as natural as I can make it. Thanks again, . . . may God bless, Dwight
Question About Making A Rifle Case
Dwight replied to johnggrg's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Personally, . . . I can't understand the 3 piece part, . . . one piece is how I do them, . . . plus handles if desired. You can add pouches, mag carriers, handles, hanging straps, etc. But the basic rifle case is one piece of leather and either a button for an end opening one, . . . or a zipper for a side opening one. May God bless, Dwight -
Leather will be darkened over time just by simple light, . . . daylight does it, . . . look at any older saddle, . . . and there just isn't much that can be done about it. The one single product I know of that will help, . . . Resolene, . . . as it has a UV blocker (the part that darkens the leather), . . . but it's not guaranteed forever. I did some "samples" a few years ago for a show, . . . one only had Resolene on it, . . . it is still pretty close to the original veggie tan color. Good luck, may God bless, Dwight
Latest Saddle Off The Bench
Dwight replied to BondoBobCustomSaddles's topic in Saddle & Tack Maker Gallery
I think it is just awesome, . . . especially since I prefer a seat like it. May God bless, Dwight -
I sorta use Red Cent's technique, . . . but if suede is involved, . . . it goes on my belt sander, . . . suede up, . . . I then take a good sharp beveler to the veggie tan, . . . and the edges come out really nice and clean. My drum sander is an oscillating one, . . . and it don't like suede. It can be burnished, . . . but it's kinda like riding a unicycle, . . . ya just gotta learn how, . . . and the only way is to practice. Take some scraps, . . . glue em together, . . . treat it like a project, . . . and practice with it. I usually use an oversized slot for burnishing, . . . then hold the leather slightly crossways, . . . hard to explain, . . . but it works. May God bless, Dwight
PM sent
- 8 replies
- belts
- leatherworker
(and 1 more)
For the most part, . . . I use the thread I buy at Tandy on large spools, . . . about $25 a spool, . . . I use only 346, . . . and it becomes whatever color is attributed to it in the dying process. Blacks become a very dark grey, . . . and browns always seem to take on a "one shade lighter" look, . . . but it is presentable, useable, and I really don't have any serious complaints from the customers. The 277 thread simply doesn't work for the look, feel, and quality I want out of my machine, . . . a Tippmann Boss. May God bless, Dwight
It's OK, Andy, . . . I used to be razzed for being a "bird legs" kind of guy. Still so at 6-1 and 175, . . . We can ride either yours or mine, . . . them fat legged guys won't be able to. But mine is not one you slump down in and head out for a 10 mile ride like you were in a rockin chair. May God bless, Dwight
I don't know where to look on mine for a year, . . . heck, I was tickled to find out what kind it was. Pretty much have decided to leave well enough alone. Gonna clean it and oil it, . . . plan on riding the July 4th parade with it, . . . it's an office ornament right now in my leather shop, . . . lots cheaper than paintings, . . . and a whole bunch more practical. Someone added a lot of stampings to it, . . . I look at those and just have to wonder, . . . sure wish it could talk. May God bless, Dwight
