Everything posted by Dwight
You didn't miss anything, . . . that IS how I do it. I have made pancakes that are nothing more than a stitched bag with slots/straps in the front or back, . . . they are not as comfortable (for me) and don't always turn out as "true" as this method is to forming it real good and close. They are equally formed on the front and back, . . . and as a personal thing, . . . I just don't like them as well either wearing or making. I make the back, . . . it is done when I lay it down, . . . stitch the leading edge and sight track stitches, . . . wet and form the holster, . . . allow it to dry, . . . finish stitching, . . . then do the dye/finish process. Works for me. May God bless, Dwight
Take a couple of pieces of scrap 6/7 or 7/8 leather, . . . put them in place for your sewing, . . . flesh side to flesh side. You need about 5 inches of thread from the needle and the bobbin. Take the thread out of the needle, . . . and sew a "line" of holes into the leather. Inspect the leather on the bottom, . . . looking for marks from the downward pressure of the presser foot. They should be there, . . . faint, . . . but should be there. Turn your machine around, . . . pull the plastic piece off the back. Look in the upper left hand corner, there is a rod there going left to right, and it has a collar around it. That collar has to be spaced so there is a 5/8 inch blank piece of shaft to the left of the collar. This needs to be pretty precise. After you have done all this, . . . check your bobbin, . . . looking down into the bobbin holder, . . . pull the string, . . . it should turn the bobbin counter-clockwise. Check your needle, . . . there should be a trough on the needle's left side, . . . and the thread hole needs to be 90 degrees perpindicular to the travel of the leather when being sewn. Now, . . . re-thread your needle, . . . leave out about 5 inches on both needle and bobbin, . . . grasp it in your left hand, . . . and begin sewing with your right hand. Gently, . . . with about the same pressure you use to turn on your turn signals in your automobile, . . . really very little pressure, . . . but gently apply pressure to the leather you are sewing. Push it away from your as you sew. That should give you some decent stitches. If all that does not solve your problem, . . . loosen the bobbin tension screw, . . . and unscrew the two top tensioners. Take off the thread from the tensioners. Start screwing down the adjusters until you see contact made with all the tensioner parts. Use a black sharpie and make a mark on the top of the knurled knobs so you can tell where you are, . . . turn both down 1 1/2 turns. Try some stitches, . . . you should get good stitches, . . . but everything pulled up to the top of the leather pieces. Tighten the bobbin screw up until you feel it contact, . . . turn it in one full turn, . . . try some more stitches. They should now be below the surface of the top layer. Adjust until you get tight stitches on the top, . . . tight stitches on the bottom, . . . and the meeting of the two threads should be very near the middle of the two layers. Let us know how this worked for you. May God bless, Dwight
I am looking for a set of letter stamps, . . . 1 1/2 inches tall. Anybody got any kind of line at all, . . . however remote, . . . holler back, please. May God bless, Dwight
Still Trying: Iwb For Ruger Lc9
Dwight replied to Fredo's topic in Gun Holsters, Rifle Slings and Knife Sheathes
There is an old axiom that says that "form follows function" and quite honestly, my friend, . . . I don't see any function there that two leather straps with snaps at the top won't do and do better. Not meaning to be mean or cantankerous, just trying to get a handle on why you would make a holster like that. Now if you mounted the top of the clips to the bottom of the holster, . . . so you pushed it down over the belt or pulled it up to get it off, . . . I could understand that, . . . makes getting on or off easier & quicker. The leather work does look good though, . . . but you also might put the back side of the nuts inside the two pieces of leather, . . . doing so will protect them from rust, . . . protect your body and undershirts from rust. May God bless, Dwight -
Newdude, . . . Try the numbers again, . . . both of them, . . . I'm home......... May God bless, Dwight
If you have a Hobby Lobby near by, . . . go there, . . . and ask where the "sewing" things are. When you get there, . . . you are looking for the wall with the scissors, needles, thimbles, etc. and you will find two tools there, . . . both with blue handles, . . . and they are snap setting tools. One is basically for line 24 size and the other one will do it all, . . . they look like funny shaped pliers. Either tool is about 25 bucks, . . . I have ruined maybe 6 snaps with that tool, . . . in about 8 years of using it. One tool is their sku: 304733 and they call it their gripper plier kit, . . . it is the "do em all" tool, . . . and looks almost identical to the other one. I usually find them hanging together or very close proximity of each other. Nothing I have ever seen at Tandy, . . . or anywhere else for that matter, . . . will do a more efficent job of snaps than this tool. May God bless, Dwight
I would like to at least take a look at it. I'm just outside of Waldo, . . . 10 miles north of Delaware, . . . 10 miles south of Marion. You can see some of my work at my website, . . . www.dwightsgunleather.com May God bless, Dwight
Personally, . . . I would probably refuse the work to put a suede lining on a cowboy rig belt. I might line the holster, . . . but he'd certainly get the Katsass lecture before I agreed to do so. A western rig that does not move a bit is about as uncomfortable as sitting across the table from both your mothers' in law (current and ex). Riding a horse, . . . walking, . . . sitting, . . . bending, . . . that inside layer has to be able to scootch around a bit, . . . and if it doesn't, . . . well it's just UGH ! As far as it's "de-bonding", . . . you can forget that if you use Weldwood contact cement and stitch the edges. It basically becomes one piece of leather. I don't use any other product, . . . and if you can find it, . . . the gel is the better of the two products IMHO (gel and liquid). May God bless, Dwight
Advice For 1St Belt Project
Dwight replied to emr454's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Eric, . . . You probably will not like the finished product, . . . as traditionally belt blanks generally run 8 oz. Doubling that makes a very stiff belt that is a full 1/4 inch thick. I'm wearing one right now, . . . but only because it carries my full size all steel 1911 for me. You want, for a woman, especially if it is going to be for 1 1/4 belt, . . . to be down in the .140 to .180 range for her doubled belt, . . . and a lot of ladies don't like it that thick. May God bless, Dwight -
Need Help With The Dremel Leather Burnisher
Dwight replied to renegadelizard's topic in Leather Tools
Renegade, . . . I don't have the same tools you have, . . . but I do have these (see pics) and they do a wonderful job for me. Obviously, . . . they are home made. I generally will sand all edges "flat smooth" with a belt sander I have, . . . or sometimes (not very often) I'll do the sanding with the little drum sander you get for a Dremel. It can get aggressive at times, . . . or if you sneeze, . . . it won't be pretty. After sanding, . . . I bevel using Tandy # 2 or # 4 bevelers (depending on effect desired, . . . thickness, . . . etc). I then dampen, . . . and the key word there is dampen, . . . not wet, . . . just damp. The best way to see what "just damp" is like, . . . make up a 4 inch piece of 8 or 9 oz leather, . . . two nice straight edges, . . . bevel them, . . . then lick them. Yeah, . . . human saliva ! Turn on your Dremel, . . . about 1500 to 1700 rpm's works best for me. There very often is a grain direction in your leather, . . . it will come out pretty if you go left to right, . . . not so pretty if you go right to left. Look for that. Press lightly, . . . like you are running your finger around the rim of a coffee cup looking for a crack. Your leather will turn darker brown as you get the fibers laid down, . . . and if you do it right, . . . when the piece dries, . . . the color will be very near the original hue, . . . not the darker burnished brown. I go on then to dying, . . . inspect my edges, . . . sometimes touch up the burnishing here, . . . then I put the final finish on it. Depending on what the item is, . . . I sometimes come back and do a "final" burnish / polish, . . . and at this place, . . . I'll lightly rub on some natural beeswax before burnishing. I have almost always gotten compliments on the edges using this process. May God bless, Dwight -
Considering that hands were made for hamburgers, . . . machines made for stitching, . . . I don't do much of that "hand stitching" thing. But when I do, . . . I use the sewing tool with the little spool on it, . . . and the wooden handle. Aboard my Navy ship it was called a sail needle. Anyway, . . . never put the thread on the spool bobbin, . . . just cut off a hunk of string 3 times as long as needed for the stitching. Pull it through the first hole so that 1/2 of the length is on each side of the first hole, . . . Then I take the first 3 inches of the thread, . . . it is always the piece shoved through the new hole first, . . . it is the piece that gets ugly, groadie, grubby, dirty, what have you. I've never done a full belt this way, . . . but I've done big stitch jobs, . . . and my string is still pretty white when I get done. But then again, . . . I also only use the coated string sold at Tandy's, . . . that may be part of the difference. May God bless, Dwight
I bought my rafter square at Harbor Freight, . . . $1.99 maybe, . . . it is basically a 6 inch long x 6 inch wide triangular square. It has all kinds of neat degrees, angles, and other markings on it. It's main qualitys, though, . . . first it is "square", . . . and one of the sides has a lip off each way. I lay down a piece of leather I need squared, . . . use a straight edge to make the first straight line. I lay that straight line on the edge of my work desk, . . . run the square up to it on the outside, . . . and bump the square's lip against the edge of the work desk. The leather lays between the square and the work desk edge, . . . with all three of them lined up, . . . the lip the desk edge and the leather straight edge. Off to the right is the cutting edge. Take a look at this little drawing, . . . says it better than I can. AND IT WORKS !!!! May God bless, Dwight
Pouch Holster Help
Dwight replied to glockanator's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Whatcha makin' glockanator? Pouch holster to me is a bag from Walmart that had my lightbulbs in it. They are especially useful for High Points. May God bless, Dwight -
Leather Thickness - 1911 Avenger Design
Dwight replied to Abram's topic in Gun Holsters, Rifle Slings and Knife Sheathes
One of the "nice" features about an Avenger holster, . . . you can add reinforcement around the mouth, . . . which will very effectively strengthen your holster. I have a Rhodesian IWB I made some time back with no reinforcements at all from just barely 6 oz, . . . it stays open for re-holstering with no problem. I do, however, use Resolene as my finish, . . . I finish both the inside and outside of these type holsters, . . . which does help make them fairly stiff. When I first made this holster, . . . I vacuum formed it around my commander size 1911, . . . slipped it out, . . . let it dry, . . . and have been very satisfied with it. I would say your 4-5 should work if it is up in the thicker side, . . . say up around .075 thickness. May God bless, Dwight -
Bottle Jack Press .... Why Not?
Dwight replied to RoosterShooter's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I used a press for a couple of years, . . . heard about vacuum, . . . tried it, . . . sold the press, . . . end of story. My vacuum bag and pump just work wonders with leather that cannot be done on most presses, . . . including a full length impression of a rifle or shotgun for a custom leather gun bag. But, . . . to each his own, . . . and to the OP, . . . good looking press, . . . I did mine out of 2 x 4's and steel plates, . . . there's some pictures on this site, . . . just search for press or me, . . . you should be able to see it. May God bless, Dwight -
Generally, . . . I make the belt, holster, pouch, . . . whatever, . . . it is fully "manufactured" so to speak. I then dye the thing, . . . but I do a quick burnish on the edges first. Dye it and let it dry, . . . usually leaving it at least 24 hours before I mess with it again. Again, . . . burnish the edges, . . . using mostly a Dremel and the tools in the picture. I also have a similar rig on the end of a 1725 rpm motor, . . . used mostly for long pieces like belts, . . . works faster that way. I do a final check out after the item is finished, . . . and usually "touch up" the burnishing. I only use water and beeswax during the earlier processes, . . . will use whatever is used for the final finish, . . . finger applied, . . . for any final touch up burnishing, . . . Resolene, Bag Kote, whatever is used. I have never had a complaint on any of my edges. May God bless, Dwight
Dummy Guns For Holster Forming?
Dwight replied to Sandman0077's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I don't often encounter that problem, . . . but have in the past. Being an old model maker / carpenter / woodworker, . . . I have successfully made an LCP, . . . a Smith model 29, . . . a Glock 35, . . . and a little Keltec. You need basically a side view, . . . top view, . . . and butt view, . . . a pair of calipers, . . . a good printer, . . . a calculator, . . . and a little luck. You will have to "mine the internet" in some cases, . . . but there are sites that will give you the length, width, weight, thickness, etc of just about any weapon out there. Look long enough, and you will usually find one with a cartridge or other item in the picture where you can get a hard cold dimension, . . . and all other measurements are just multiples of that one. It is your base, . . . May God bless, Dwight -
Tippmann Boss - Help With Timing Please
Dwight replied to niftycurly's topic in Leather Sewing Machines
I had a similar experience a couple of years ago. Turn your machine around, take off the back. Up top is a steel round rod, . . . with a collar on it. That collar has to be 5/8 of an inch from the left side, . . . no more, . . . no less. Somehow, mine had slipped, . . . it was about 3 inches to the right of correct position, . . . would not sew. Ben and I talked on the phone, . . . finally wound up driving it up there, . . . he took the back off, . . . "Here's the problem" May God bless, Dwight -
First thing, . . . take out the bobbin, . . . pull the thread out of the machine. Now, . . . does it function smoothly with a doubled piece of 7 oz leather running through it? With your stitch adjustment set for the longest stitch, . . . you should be able to measure something like 4 1/2 stitches per inch. Four is good, . . . 5 is good too. That means that the mechanical needle movement, leather movement, shuttle & bobbin movement are doing what they should do if the stroking is smooth and "catch free". If it isn't, . . . then you have a mechanical problem. I had one once where a collar slipped, . . . gave me some SERIOUS fits. If that is all good, . . . put your bobbin back in, . . . re-thread your machine. I usually use one size bigger needle than needed, . . . just so my thread flows very smoothly through the system. Placing the needle correctly takes some getting used to. I usually use a stick pin that will not go through the hole, . . . and line it up at a 90 degree angle to the travel of the leather, . . . then tighten down my needle clamp. The needle needs to be all the way to the top in it's slot. Make sure the full length groove on the needle is to the left. Won't work the other way. As mentioned earlier, . . . you want some drag, . . . but not much on the bobbin, . . . it just cannot free float, . . . I usually loosen both top adjusters for free float then give both one full turn to start out. Take a typical piece of your work (mine is usually something like two pieces of 7 oz veggie tan) and start sewing, . . . sew 10 stitches, . . . stop and cut the threads. Look to see where your threads come together. If they are squarely in the center between the layers of leather, . . . then you only have to make sure they are tight enough to hold correctly, . . . or are pulled down into your thread gouge. Personally, . . . I like my threads tight, . . . not everyone does, . . . I also like using 400+ thread, . . . I like the bold look, . . . big stitches. Work with it, . . . it'll get there. Do 10 stitches, . . . check it, . . . adjust as needed. Do 10 more, . . . check it adjust as needed. Keep at it until you get what you want. Also, . . . never put sewing machine oil on your machine. That is for Singers, . . . not for a Boss. May God bless, Dwight
Vacuum Molding
Dwight replied to jlsleatherworks's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Vinyl bag made from JoAnn fabric clear vinyl. ($20) Vac pump from Harbor Freight. ($110) Hose fitting from on line vac supplier. ($15) Misc fittings from local hardware store + hose. ($25) Like electrathon said, put something flat behind it, I use a white cutting board sold at Wal Mart for about $10. With this rig, . . . I don't usually have to help it much, . . . push the "ON" button, . . . 5 seconds later turn it "OFF". Repeat once or twice if the mold is not enough detail the first time. Only one I had much trouble with was a WW2 / over the shoulder / chest carry rig / suede lined / for a Glock 35. I had to leave it in for about 10 seconds. May God bless, Dwight -
You did not say how or if you finished the belt, . . . if it doesn't have a serious final finish, . . . a dip in neetsfoot oil will probably solve all your problems. Take an 8 x 11 baking pan, . . . pour about an inch of oil in it, . . . snake the belt through the oil, . . . hang it up to dry. Don't linger in the oil, . . . a couple of seconds is all it needs. About 48 to 72 hours later, . . . you should have one nice silent belt. Rub it inside and outside, semi vigorously with an old terrycloth towel, . . . and you should be good to go. May God bless, Dwight
Try Ryan's suggestion, . . . and while you are at it, . . . lighten up on the pressure. It doesn't take a lot of pressure to mold a holster. Also, . . . what thickness do you have on top? You should have two layers, . . . each 1" thick, . . . at least that is what worked for me. May God bless, Dwight
Rifle Case Lining - What To Use?
Dwight replied to yehagirl's topic in Gun Holsters, Rifle Slings and Knife Sheathes
The best favor you can do for your gun loving friend is do a canvas in, canvas out gun bag, . . . if you want to stiffen it, . . . sew a layer of quilt batting in between. OR, . . . if you want it really stiff, . . . go to Tandy's and ask for their "bag stiffener", which is used for that very purpose on hand bags. Get your zipper there too. You can buy just the exact length you need, . . . plus the slide piece, . . . much cheaper usually than buying a complete zipper some where else. Flannel is a NO-NO for me and my guns. Any oil on the outside of the gun will instantly transfer to the flannel, . . . can make an oily stain all the way through if there is enough oil, plus that oil stain inside will attract dust, grit, sand, dirt, dead bugs, and assorted other trash you do not want associated with a gun. Canvas makes a good liner, denim (think blue jeans) material is good, and JoAnn's sells some really nice vinlys that would make good interiors for a gun bag. Whatever you use, . . . make sure it is a lint free type material also. May God bless, Dwight -
The one thing that never changes in this world is that "change is inevitable". My great grandfather lost his life's savings, everything: chose the wrong side in the civil war. His son in law passed on after he did a major vocational shift. Cars killed his "blacksmith" trade, so he became a farmer, but not knowing anything about them new fangled machines, he relied on horse and mule power until he died. My father was drafted for WW2 and released, his reading and writing skills were not sufficient for their needs, but were enough to get him by for 64 years. Uhhh, . . . change is here, . . . just make believe it is the front porch swing, . . . flow with it, . . . don't like going backward, . . . it'll go the other way in a few seconds, . . . you can be happy then. May God bless, Dwight
