CowboyBob
Contributing Member
11 Followers
Contact Methods
  • Website URL
    http://www.tolindsewmach.com/
Profile Information
  • Gender
    Male
  • Location
    Toledo,Ohio
  • Interests
    We sell New & Used
    Leather Sewing Machines
    Parts,Needles &Thread
LW Info
  • Leatherwork Specialty
    Can help w/sewing machine questions & supplies
    People needing help with machines
Recent Profile Visitors
63,429 profile views
CowboyBob's Achievements
Leatherworker.net Regular
Leatherworker.net Regular (4/4)
  1. @LMP The cotton thread doesn't have a very long shelf life B4 it starts to weaken & start breaking when sewing,but Yes you can try it & the lube would help as long as it is rotten.
  2. @Steve855 It's called a drip pan all it does is keep the oil off of your pants & floor that drips off of the machine.
  3. @JukiFan There are quite a few reasons for skipping but one very overlooked one is a wore our needlebar,from tightening the needle set screw over many years the hole gets enlongated to the left side forcing the needle to set @ an angle so the thicker your sewing as the needle goes in it will pull it away from the hook causing skipping.The test is loosen the needle set screw & note how far it moves left to right.
  4. I've worked on 1,000's of stuck machines over the years & this is what I do.Mixup alittle used motor oil & diesel fuel 1/2& 1/2 lube both bushings every couple hrs with a couple of drops & tap on the bar with a solid piece of metal drive pin as big or bigger than the pressure bar using a hammer(light to medium taps) & eventually it'll break loose.
  5. How much play does the arm have that the opener fastens to?BTW it only needs to barely open just alittle,you could be trying for too much.
  6. Here's a manual for a machine like a 337 205RB-1.pdf
  7. Usually the smallest you can use for 138 is size140
  8. Thread underneath the base(on the left) instead on going between it.
  9. Only the 16-188 has the foot that pulls,the 16-141 has a spring loaded foot.Also convert the machine to use the 135x16 for leather,it measure approx 1 & 3/4" long & probably has already been converted.
  10. It mounts in one of these three holes already drilled & tapped in the bed, usually it will be the front one.
  11. Yes,same length.
  12. You have a belt pulley,feed cam & needlebar crank to take all the screws out of & then you have to get in there & clean the 50 yr old crud off of the shaft so it will slide out the tight tolerances that these parts are in.I usually slide shaft in & out,clean,slide,clean,cuss!
  13. This one is as close as you can get for one.Your model is a copy of the Singer 111w except your has reverse. 111w Navy Repair manual.pdf
  14. Great looking work.We have used the 1.5 amp 9000 rpm version of this motor on Singer 29 patchers in the past & they work pretty good.You have to use a stronger foot pedal with it as the motor will fry a standard pedal.
  15. When we sell one of these we always buff off the feet if they are sewing leather & do the same on the Consew's too.They don't mark then.AFAIK there are no smooth feed dogs for them.
