CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. A roller foot lets the leather slide through easier than the standard foot. Yes,we stock the bobbin case & bobbins for it. Bob
  2. I'll have to agree @ $300.00 it's a great price & we work on alot of these & have all the parts,needles,thread,servo motors & etc in stock. Bob
  3. We sell the same machine & I'm very fimiliar with it too.The next step would be to check the needle bar height.You need to take the needle plate off & turn the machine around in the direction it runs & when the needle goes down all the way & starts to go up you need to make sure the top of the eye of the needle is about 1/8: below the hook. Bob
  4. just posted earlier today http://leatherworker.net/forum/index.php?showtopic=43014
  5. No way will either one of these machines that were made to sew shirts,dresses @ high speed & other lightweight stuff will sew holsters with the size of thread you need to use. Bob
  6. If you do not have enough foot pressure to hold the leather down it causes the leather to lift as the needle pulls out this will cause skip stitches.When you keep the leather down as the needle pulls out this allows the needle to make a loop large enough for the hook to catch it. How thick are you trying to sew right now? Bob
  7. I'd say it's worth $500.00,it will sew close to 3/8",the knob your talking must be for the stitch length. Bob
  8. Tachgirl, We have a chart here:http://www.tolindsewmach.com/thread-chart.html Bob
  9. The rotary machines won't sew as heavy as a oscillating shuttle machine.You MIGHT beable to use #69 thread if you tighten up the tension alot.Parts will be almost impossible to find for this too since it's so old. HTH Bob
  10. Yes,it's a good machine that has a bobbin slightly smaller than a 563 & takes the same feet & needles too.Wiz has one he modded & sews to 3/8" with. HTH Bob
  11. They all are good machines BUT I wouldn't even think of buying the 211 alot of parts & some screws have been discontinued on it & they are special to this machine.The stitch length is the same adjustment as the 111w which even though it's an older machine ALL the parts are still available & since it has a larger handwheel it will sew slower,parts are very low priced for it. The Pfaff is probably the best & the 545H4 is the one with the higher lift,the 545H3 has a foot lift real close to the 111w, 1/2",there is quite a few common aftermarket replacement parts for the Pfaff on the market. HTH Bob
  12. Well there'sw the zipper feet were either the left or right toe is off,we also have edge guide feet that have a builtin edge guide that will let you sew 1/8",3/16" or 1/4" from the edge.Then there is the cording or piping feet that come in sizes 1/8-3/4" HTH Bob
  13. No all DBx1's are the same length.Maybe you need to lower your needlebar alittle,try just holding the needle down alittle a couple of mm & see if it works.
  14. Tighten your foot pressure alittle.Needle length won't affect this lifting of the material,it do to #1not enough foot pressure #2 trying to sew to thick or hard of material. Leather needle might help alittle.
  15. Do to the rotary hook design in the Consew 230 it won't sew the heaver threads & thickness as the 31-15 will. The 31's are a great workhorse of a machine no matter how old it is you can still buy parts for them. The Consews rotay hook makes it a higher speed machine like 4000 stitches per min great for sewing thin stuff like shirts,drapes & etc. Bob
  16. They usually have 3-sets of gears in them,the stitch length is controlled by a knob under the left end of the machine,you it has 3 detents on it that stops on each different stitch length,you pull the knob it out or push it in to change the stitch length. Bob
  17. You might be trying to use to large of thread,this machine is limited to the largest size of #92 or smaller like #69 or #46 HTH Bob
  18. I can get gears f/12 pr in.It can use #138 & sew close to 20oz Bob
  19. Kevin, It's a tossup.The Adler of course is made in Germany very good quality but parts are very costly & any attachments you need will almost usually have to be handmade,the 618 is a very common machine,feet & parts are much lower cost & there's more of a selection. We do stock some knockoff Adler feet but they still cost almost 2x as much as the more common 618 feet. You might want to try sewing on both & see which one you like better. HTH Bob
  20. Jeremy There stitch length is controlled by gears,usually real short like something like 14,16,18,22,24 pr in. They were made for shoe uppers. Bob
  21. Doug, It's a light duty tailor type of machine.Some parts might be hard to get. It's best to stay away from a Mercury unless it's cheap enough that you can use the table. I found the old dealers price from 1995 HTH Bob
  22. For 207 use #23 Here's a chart: http://www.tolindsewmach.com/thread-chart.html So how do you like the bigger machine? Bob
  23. Have you oiled everything on it?Don't forget to open the side cover on the left & oil all the pivot points. Now this type of machine has a walking foot & they push each other up & what happens is there will be more resistance when the back (or outside foot lifts) because there's some foot pressure on it.Lift the foot up & spin it over by hand & let me know how it works. Bob
