shoepatcher
Everything posted by shoepatcher
  1. The bobbin case. Machine has no feed. needle goes up and down. makes stitch. you move the item by hand to darn up a rip or hole. glenn
  2. Would not be hard to build this. You need a round shaft, collar, spring, washer, cotter pin. Or call Collier Equipment or Bob Kovar at Toledo sewing and see if they can get the parts. part # rod #223684 collar #227227 screw #200113 spring #206628 cotter pin #202302 glenn
  3. Machines without the P have skiff feed: Feed dog moves back and forth but never drops. Used on the 335-17 binding machine for symmetric feed. 4 motion drop feed is this: Feed dog comes up to meet the needle (1)and inner presser foot. (2)then move to the back, (3)drops down and then (4)comes forward before moving up again. Also called elliptic feed. glenn
  4. You could sew leather with it. glenn
  5. call Manufacturers Supply in St. Louis. They sell clickers. See what they say. glenn
  6. Same manual will work. The 372 has smaller fittings on it like feed dog, feet. It uses smaller sized 134-35 needles. glenn
  7. The 335 can sew #138 thread. You just have to make a few modifications. Enlarge hole in inner foot and feed dog. Pfaff made a heavier take up spring. I would install that as well. I also went to work on the gap and finger on the bobbin area to have more clearance for the thread to clear on each stitch. glenn
  8. Y The speed reducer screws with the sensing in the synchronizer. You can use a servo motor, synchronizer and speed reducer but not all three. I would get rid of the speed reducer. glenn
  9. I would have the piece in the back welded first to see if it will work. Strima in Poland carries a lot of older parts. Check with them since you already have the part numbers. I you contact Pfaff in Germany and see what they have. There is also a guy on eBay in Lithuania that sells a lot of older Pfaff parts. glenn
  10. call Bob Kovar at Toledo Sewing and see if he has any Champion parts. Use to work on them. glenn
  11. take a video of the machine slowly sewing so we can see how it is jamming up. glenn
  12. the 4 class is the precursor to the 104. great machines. I would not part it out. get it set up and running. glenn
  13. Need to know exact model of your 268 to answer that question. glenn
  14. Bradbury built from 1872-1923. Built in England. Smallest arm of any shoepatcher. Were great machines. I have manual on the machine. Closest needle system to Bradbury needle was Singer 175 x 5,7. glenn
  15. HOW heavy a thread are you using. Stick with #138 and below. Will sew #207 on top but #138 is better top and bottom. glenn
  16. see www.brunoanichini.it The 29K19 uses all the same parts as the 29K 1 except it had a different needle bar. glenn
  17. what model you got?
