shoepatcher
Everything posted by shoepatcher
  1. take a video of the machine slowly sewing so we can see how it is jamming up. glenn
  2. the 4 class is the precursor to the 104. great machines. I would not part it out. get it set up and running. glenn
  3. Need to know exact model of your 268 to answer that question. glenn
  4. Bradbury built from 1872-1923. Built in England. Smallest arm of any shoepatcher. Were great machines. I have manual on the machine. Closest needle system to Bradbury needle was Singer 175 x 5,7. glenn
  5. HOW heavy a thread are you using. Stick with #138 and below. Will sew #207 on top but #138 is better top and bottom. glenn
  6. see www.brunoanichini.it The 29K19 uses all the same parts as the 29K 1 except it had a different needle bar. glenn
  7. what model you got?
  8. 767 manual will work as well. was used in auto industries. Looks like you have a Efka computer motor. That has all the functions. You have a 720 top control panel as well. That color machine made in the late 1980's. glenn
  9. 30-10 or 30-70? which? you must first check the needle bar to make sure it is at the correct height. 30-1 different than 30-70! One determined that needle bar is times, you then remove shuttle from the shuttle carrier to time the hook. There is an eccentric on the lower drive rack that you move to time shuttle carrier. I might be able to walk you thru it over the phone. glenn
  10. That looks like a Juki 562 which was a copy of a 111 w155 with reverse. Goldsworthy was the the Pfaff dealer in Ontario until they went out of business about 10 plus years ago. glenn
  11. Nice job on the rebuild. glenn
  12. Paint in good shape. leave it. glenn
  13. Weaver 205 clone an option. I have sewn on one. 90% as good as the original. I have a genuine 205 with toys. 969 Pure is a great machine. You buy the best you only cry once! glenn
  14. The Adler 120-7A, 8A had a 40mm lift on it Could sew heavier than Randall Campbell and 969 DA. That was an absolute beast. glenn
  15. From the color of the machine, it was made in the early 1980's to late 1980's. I had a Pfaff 1245 that color. glenn
  16. The flat screw on the other end of the shaft that has the wing nut for adjusting the walk is off. That has to be loosened. I always replace that screw with an Allen screw 1/2" x 24tpi. Easier to adjust and you can tighten it down more on the shaft. Once loose, set walk with wing nut to lowest walk and slightly tighten straight slot screw to get the walk adjusted. Next go to highest walk with the wing nut. (letter H on the gauge) and adjust it so foot just comes up under needle clamp. You will get the knack of it with a little practice. glenn
  17. Is Graham Forsythe still involved with it? glenn
  18. No I would say 1999-2000 was first year. glenn
  19. Located where? glenn
  20. Need to see pics of it. Like Constabulary said, needle system #81 e
  21. Good you have the post covers and the bobbin cover. 12 " post damn! Service should be the same on this as and 51 post with roller feet, glenn
  22. No. 1508 came out before 2000. I got one in the late 1990's. First year they were made. Still have it. glenn
  23. The feed dog looks wrong. It should be all the same height front to back on it. Check the adjustment screw underneath to adjust height of the feed dog. it has 4 motion feed meaning feed dog comes up, moves back, drops down and then comes forward to complete the cycle. i would remove the throat plate and take a video of the feed dog moving. glenn
  24. ok I had worked with 267 machines. Sorry glenn
