shoepatcher
Everything posted by shoepatcher
  1. 767 manual will work as well. was used in auto industries. Looks like you have a Efka computer motor. That has all the functions. You have a 720 top control panel as well. That color machine made in the late 1980's. glenn
  2. 30-10 or 30-70? which? you must first check the needle bar to make sure it is at the correct height. 30-1 different than 30-70! One determined that needle bar is times, you then remove shuttle from the shuttle carrier to time the hook. There is an eccentric on the lower drive rack that you move to time shuttle carrier. I might be able to walk you thru it over the phone. glenn
  3. That looks like a Juki 562 which was a copy of a 111 w155 with reverse. Goldsworthy was the the Pfaff dealer in Ontario until they went out of business about 10 plus years ago. glenn
  4. Nice job on the rebuild. glenn
  5. Paint in good shape. leave it. glenn
  6. Weaver 205 clone an option. I have sewn on one. 90% as good as the original. I have a genuine 205 with toys. 969 Pure is a great machine. You buy the best you only cry once! glenn
  7. The Adler 120-7A, 8A had a 40mm lift on it Could sew heavier than Randall Campbell and 969 DA. That was an absolute beast. glenn
  8. From the color of the machine, it was made in the early 1980's to late 1980's. I had a Pfaff 1245 that color. glenn
  9. The flat screw on the other end of the shaft that has the wing nut for adjusting the walk is off. That has to be loosened. I always replace that screw with an Allen screw 1/2" x 24tpi. Easier to adjust and you can tighten it down more on the shaft. Once loose, set walk with wing nut to lowest walk and slightly tighten straight slot screw to get the walk adjusted. Next go to highest walk with the wing nut. (letter H on the gauge) and adjust it so foot just comes up under needle clamp. You will get the knack of it with a little practice. glenn
  10. Is Graham Forsythe still involved with it? glenn
  11. No I would say 1999-2000 was first year. glenn
  12. Located where? glenn
  13. Need to see pics of it. Like Constabulary said, needle system #81 e
  14. Good you have the post covers and the bobbin cover. 12 " post damn! Service should be the same on this as and 51 post with roller feet, glenn
  15. No. 1508 came out before 2000. I got one in the late 1990's. First year they were made. Still have it. glenn
  16. The feed dog looks wrong. It should be all the same height front to back on it. Check the adjustment screw underneath to adjust height of the feed dog. it has 4 motion feed meaning feed dog comes up, moves back, drops down and then comes forward to complete the cycle. i would remove the throat plate and take a video of the feed dog moving. glenn
  17. ok I had worked with 267 machines. Sorry glenn
  18. pics of the machine? glenn
  19. Having just finished rebuilding a Consew DSC-2 skiver, I believe a lot of the parts will work on Fortuna skivers since they are a copy of the Fortuna. I know Fortuna made various models, but it is a possible source for parts. I tell everyone, " A part is better than no part". Something to consider even if they are Chinese made clone parts. glenn miller
  20. I wanted to find out how many of our members own and use a Singer 97-10 harness machine. Please respond so we can figure out how many are still out there. Thank you in advance. glenn miller
  21. Safety clutch adjusted with Allen wrench as to when it disengages. check that it is not to tight so it disengages to quickly.
  22. If you want the Cadillac, get what I have- DA 669. it replaced the 69. It can be changed very easily to a binder machine. Not cheap!! glenn
  23. Ok you will probably need to change out the feed cam on the bottom from 4 motion drop feed to skiff feed, new throat plate, feed dog. It uses singer feet so you can get those on line. The binder will not be cheap if you have to have it made special. WE use Atlanta Attachment, Tennessee Attachment and WS Bessett here in the States. UK? Are there any binder companies in the UK or Europe?
  24. Standard Rivet I believe is still in business. Contact them. glenn
