Everything posted by motocouture
Satchel
motocouture replied to kncorey's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Really nice bag, lotta stitching! -
Thanks mate! Great idea on the contrasting piping, too! Thank you so much! With winter coming, wish I was down in AZ! Much appreciated! Thank you! Looks like your in the same general area of Philly : ) Thanks! Yes, the main reason being I don't have a suitable sewing machine for this work (although I do for garment sewing), and also because I really enjoy the 'zen' of hand stitching. I'm using 0.6mm tiger thread, with size 004 needles, and about 8-9 spi (will have to check the exact mm size of my pricking iron). I have used 0.8mm tiger thread with 002 needles with the same pricking iron on another project, but for aesthetics I prefer the thinner thread on this one.
Todays Project
motocouture replied to GunnyStewart's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Love seeing the step by step pics, thank you! BTW, I use "Picture Resizer", an app on my iPad to resize photos straight from my photo album really quickly (I lost patience with the whole emailing to myself thing : )- 16 replies
- watch strap
- watch bamd
(and 1 more)
Correct, no gussets, just lapped side seams for the front and back pieces. Was a little tricky to finesse the pattern so that the length and curve of the front / back lower edge matches the rectangular base, while giving the right 'lean' on the front / back (had to dig out some very rusty high school geometry & trig). Thanks! For the zipper, I buy RiRi zipper tape by the yard, and then add the zipper pull. That way I don't have to worry about the exact length, and can use any offcuts for smaller projects. Also, below is a photo of the half lining and zip interior. Little messy at the moment, but will tidy up the zip end later (cover with grosgrain ribbon). I'm not doing a full lining or pockets for this one, since it's a prototype, but it would probably be straightforward to add in pockets using the decorative stitching line. Thinking chèvre or kangaroo might make a nice lining for the 'real' one.
I figure if I keep it simple I have less to mess up I'll have to research the Stohlman way, sounds interesting. Yep, going to be turned (eventually) - pic below of the front and back of the bag. Trying to do as much on the flat as possible. Experimented with using some 3M 45 spray adhesive to lightly coat one side to hold the overlaps while I punched the stitching holes down one side, then untacked and did the same on the other (to avoid using an awl too much once the sides are stitched into a 'cylinder'. I might have to start looking into a splitter....
I'm sure you're being far too hard on yourself! Couple of pics below on the piping progress. I just took a 30mm wide strip, hand skived it down (splitter is looking more appealing by the day), glued and folded in half. No internal welt or cord. I cut slits in the corners so it could bend ok. Was worried about having a clean width of piping showing (cos I was a bit off when I glued the piping to the base), so I figured if I punched the stitches now while I can see the piping, then glue the sides of the bag, I can use the holes on the back of the base as a guide for an awl. Btw, the slight staining around the stitch holes is braiding soap (David Morgan's recipe). I use a small amount to lubricate the stitching iron, which makes it really easy to pull out, and also seems to make the thread go through the hole a little easier.
13-inch Slim/Flat Document Portfolios
motocouture replied to oakenlander's topic in Satchels, Luggage and Briefcases
These are really nice. I've been doing some research for a while, trying to find sleek, slimline document holders for meetings at work, and there's surprisingly little out there. Great work.- 2 replies
- portfolio
- englishbridle
(and 4 more)
Fingers crossed! Thanks! I'd love to take the credit, but that truly belongs to the designers of the luxury bag that I'm using as inspiration....I like the sleek look it gives. Thanks Brian! I have a dream of working in croc someday. If I ever do, I'm sure I'll be bugging you then you can get out more
Figured since I made something for hubby, time for a project for myself . Using some scrap Horween Essex (thanks @nstarleather!) to make a prototype handbag, before using my nice Parisian Blue Horween. Hand stitched in 0.6mm Colonial Tan tiger thread, and paracord core in the handles, hardware from the Buckleguy. Will post pictures as I (slowly) progress. Aim is to stab myself less than @YinTx
Nice! Thanks for walking through the process you used to repair it.
