kgg
Contributing Member-
Everything posted by kgg
How can I get an exact match of these two wet molded pieces?
kgg replied to LMullins's topic in Leatherwork Conversation
I think to get both sides properly done and that can be consistently repeated you need to start out with a good mold. A mold that consists of two halves where the bottom half and top half can be compressed together otherwise you will never get proper fitting item. You could make a mold out of wood or have one 3D printed. I suspect a 3D printed mold would be the best cheapest route. kgg -
Is Pfaff 331 a good all-round sewing machine?
kgg replied to trikvart's topic in Leather Sewing Machines
With odd ball setups like this one I totally agree with @Constabulary. When those bells and whistles work they work very nicely and do good work but when they don't it would probably be cheaper to junk the machine rather then trying to repair them. I would suggest you try and find a machine, flatbed or cylinder arm, that has a standard setup say comparable to a Juki DNU-1541S (flatbed), Juki LS-341 or 1341 (cylinder arm ) or clones. The parts and accessories are a lot cheaper and can be readily had should something happen. kgg -
Also you need to add the weight of the packing particularly if the unit is used and it is being shipped by wooden crate. Also ask the seller to send a photo of how they are planning on packing it. If it is not properly packed up you could windup with a box full of broken parts. Also have it insured against shipping damages. kgg
To get controllable slow speed sewing and to reduce your frustration level I would suggest: 1) dump that clutch motor ---- Clutch motor: i) It is always going to be on at full speed probably revving at 1750 rpm's or 3500 rpms. ii) It is going to be annoying loud. iii) Learning how to feather the clutch has a very steep learning curve for most. 2) Install a servo motor: i) about $150 this side of the pond. ii) More energy efficient as the motor runs only when you press the "go" pedal iii) More bottom end torque. iv) ability to set the speed and no matter how hard you depress the "go" pedal the speed will not exceed that setting 3) install a speed reducer for added torque but most importantly added speed reduction. kgg
No, you well screw the machine up and have a terrible mess on your hands. You will have to: i) have the needle in the down position and just on it's way up so the hook has caught the bobbin thread ii) raise the presser foot just off the material and slowly turn the item around iii) drop the presser foot down and sew Chances are you will not be able to use V207 thread consistently in thick or tough materials or materials with pile layer like carpet. I would recommend V138 with system 135 X 16 (leather point needle) using either a size 23 or 24 needle. Are planning on doing a single fold or double fold with the leather binding and how thick is the leather binding??? kgg
Servo motor for Pfaff cylinder arm walking foot?
kgg replied to takoda's topic in Leather Sewing Machines
That is a very pretty table but seems impractical to me with limited usability for a cylinder arm machine more of a show piece. The drop leave end is nice space saving touch. I think when you are sat at the machine you will find that you are going to have to put one leg outside the left side table leg which probably is not going to be a comfortable sitting / sewing position. Also that beautiful hardwood swivel is going to be real pain in the butt, literally. The question I think is would this table arrangement work for the items you want to sew? If you plan on doing bag type work a cylinder arm mounted on a flat table like this one will not give the freedom as a "U" shaped or a table that mounts the machine so the cylinder arm overhangs the end of the table which gives clearance basically to the floor. From the photo of the motor it appears to have the standard triangle mounting arrangement as all motors, clutch or servo. A servo will give you better speed control that is much more quiet then a clutch, cheaper to operator as the motor only runs when you press the "go" pedal and provide better bottom end torque. I would suggest finding either a brushed servo motor or brushless servo motor. Like @canvassewing has suggest a 750 watt would probably work quite nicely. If you choose a brushless servo motor the more internal coils it has the better the motor. A couple of questions: i) What do you want to sew?? Fabric, Leather ii) What size of thread do want to use?? iii) Which model is this PFAFF machine?? iv) What are they asking for it?? You maybe better off buying a clone with a proper industrial table setup. kgg -
I agree with @dikman this is a binding machine. I did look at the spec part of your "Made in China" advertisement: 1) particularly the "Presser Foot Lift" at 15mm. Allowing for a necessary 3mm (1/8") gap from the presser foot to the top of an item being sewn leaves 12mm as a very max sewing thickness, not necessarily leather. Your 12 oz of leather would have a total 4.78 mm ( https://www.weaverleathersupply.com/pages/leather-thickness ) so you would be well within having enough space under the presser foot. 2) the video on the "Made in China" advertisement. Shows this machine as what appears to be needle feed machine not a compound or walking foot machine made for Fabric applications. 3) The only reference I could find about the needle system was it takes system DP 17. The DP17 is the same as needle system as 135 x 16 for leather and 135 x 17 for fabric. I could not find any reference to the max needle size but looking at a PFAFF 335 manual it max out at a #16 (100 metric) which means it can handle V69 thread. 4) Here is a good reference chart for needle to thread size ( https://www.tolindsewmach.com/thread-chart.html ) My personal opinion is that this machine is meant to do "Fabric" work of flat binding with no major thickness changes like going from 1.6 mm to 3.2 mm (4 to 8 oz leather) using a max thread size of V69. The machine probably could handle V92 in certain types of materials. Just because you can stuff a # 22 or 23 needle in the needle bar that can take V138 doesn't mean it will have the necessary needle to hook clearance. I think this is the wrong machine for sewing leather of that thickness. To do the job properly and consistently with V138 thread in 12 oz of leather you need in a cylinder arm a Class 341 or 1341 machine like a Juki LS-341 or 1341 or clone. kgg
Leather Sewing Machine Drive Belt Sizing (thickness)
kgg replied to DG1's topic in Leather Sewing Machines
I don't think link belts will give the proper surface contact with the stock pulleys of the motor, speed reducer or the sewing machine. kgg -
Thank you. It has got to be the photo as the belt is a 44 inches belt as measured from the center (#3 of 5 tongue oblong holes) to the belt side of the buckle. The keeper is 3/4" wide. He likes to slide the end of the belt into the first loop on his jeans so that is why I extended the tongue. I have never done it but I guess it could be done with a good skiver or maybe using some leather binding and a binder attachment to add a nice finished edge. kgg
If anyone is going to give a belt a run for it's money, it's my brother. What do you use when gluing leather together?? kgg
I did build a basic no frills leather belt for the brother and just never uploaded the photo's. For this project I used a Techsew 2750 Pro which had no problems sewing two layers of 6.5 oz chrome tan, groaned on three layers but wouldn't do four layers of 6.5 oz of chrome tan. The belt construction: 1) two 1.5" wide strips of 6.5 oz chrome tan. 2) the strips were contact cemented together with Lepage Heavy Duty Contact Cement. This step required two coats of glue as the first coat soaked into the leather. I was going to buy Barges but when I read the instructions it said it may require two coats on porous material. Is Barges that much better then Lepage Heavy Duty Contact Cement??? 3) the belt blank was then sewn with V138 Bonded Polyester along the edges 4) I then 3D printed two hole templates,one for the buckle end and one for the tongue end. I went to get a template and was shocked a the price of templates from free paper ones to $50 acrylic. The problem that I seen with the ones I looked at was they all just laid on top of the leather. This means they can wonder left to right. I guess you could tape them in place on the leather. So me being me I 3D printed two templates that the leather sits in so there is no wonder left to right as I bang the punch through. The buckle end would not have been a problem. The front was another matter when I tried to punch the five 5mm x 8mm oblong holes for the tongue end on a test piece. I got really nice oblong holes equally spaced that looked terrible. Like a duck waddled down the strip of leather. One was cantered left, one to the right and the others weren't much better. 5) Well since chrome tan can't be as far as I know be burnished like veg tan and I am lousy at edge coating I had to come up with something to sort of smooth out the belt edges. So I figured that burnishing lay's the fibers flat and burns the edge. My idea which seems to sort of work would be to try good old fashion "Udder Smooth" on the edges and run my soldering iron with a flat brass insert attachment over the edge. I cranked the soldering iron up to 840 F. See if the brother destroys this 12 - 13 oz real leather belt. Any and all comments are appreciated. kgg
$500 Consew Cylinder head Ontario Canada
kgg replied to James 1945's topic in Leather Sewing Machines
The problem with the Consew in Ontario is they are not a popular / common brand probably because they are a lot more expensive then other brands of similar capabilities. My experience with selling the Consew's that I have owned over the years is that they are very difficult to resell at any price point. You basically got to give them away. As a note it is cheaper to buy a new Consew 206RB-5 from a USA vendor and have it shipped then it is to buy new one in Ontario. The base price of new Consew 206RB in the US would be about $2000 CAD ($1450 USD) vs $3200 CAD ($2300 USD). kgg -
A couple of questions. 1) What machine are you using? 2) What size of needle are you using? 3) What size of thread are you using? kgg
I'm assuming you purchased it new so I would suggest giving the vendor a call. kgg
When I realized the date of the original post I edited my post. kgg
@Bugg like @Constabulary has suggested we need a little more info. kgg
I agree with @AlZilla thoughts on tools. This type of dog lead looks really pretty but from my experience it should not be used on trying to control a larger or more powerful dog. Also be careful in choosing the correct weight and width of leather. I find using two layers of 6 or so ounce leather glued together gives a nice smooth surface on both sides. I also stitch both edges the length with V138. I figure this would be good up to about an 80lb dog. Also use #9 copper rivets at the clip end and for connecting the loop to the lead. If you need to make one for a real puller I would suggest incorporating a nylon webbing between the two layers of leather. Just my thoughts. kgg
First question is what size of thread you want to use, then what do you want you stitch to look like and availability. 1) Thread sizing chart from Toledo Industrial Sewing Machines ( https://www.tolindsewmach.com/thread-chart.html ) 2) Here is a quick look at the appearance of what the needle point will give. I grabbed these from the Techsew website ( https://www.techsew.com/en/blog/needle-buying-guide.html ) i) LR Point --- appears to be the more common point ii) R Point iii) S Point kgg
What size of needle are you using with the V346 thread. Here is a good reference chart for needle size versus thread size. ( https://www.tolindsewmach.com/thread-chart.html ) As a note you may have to go up a size depending on how thick and tough the leather is.
Nice simple functional solution. No problem, all good. I get those senility moments all the time. kgg
What size of needle are you using with the V346 thread. Here is a good reference chart for needle size versus thread size. ( https://www.tolindsewmach.com/thread-chart.html ) As a note you may have to go up a size depending on how thick and tough the leather is. kgg
Using what you have lying around. Just got to think outside the box. Cost ---- zero dollars. Us frugal people (cheap skates) got to stick together. Any chance of a photo of the vac hookup?? kgg
Great topic as I am am in the process of setting up a Con Sew DSC-4 skiver and installing that is what I was sort of planning on doing. I will be going with the shop vac method since I already have one in the area the skiver will live. My skiver table has a square hole in the table with a metal shute. I really like the setup of the hose on the bottom of your table. I think I will 3D print a new piece to cover the hole and accept the mounting of the vac hose to the opening similar to your setup. kgg
If you have to buy a vacuum I would consider: These would be my choices on this side of the pond. i) Small Wet/Dry Shop Vacuum 10L at $70 from Canadian Tire ( https://www.canadiantire.ca/en/pdp/maximum-vkd811sw-5-5-peak-hp-stainless-steel-wet-dry-shop-vacuum-with-hose-and-accessories-30-l-0540252p.html?rq=vaccum+cleaner ) ii) Compact Lightweight Bagless Corded Canister Vacuum at $87 from Canadian Tire ( https://www.canadiantire.ca/en/pdp/bissell-aeroswift-compact-lightweight-bagless-corded-canister-vacuum-cleaner-0438173p.html?rq=vaccum+cleaner ) Between the two choices the quieter setup would be the canister vacuum. I would mount a Power Bar to the bottom of the table so the power switch is close to the front edge of the table. Then plug both the skiver and the vacuum into it. With both the Shiver and vacuum power switches in the "ON" once you flip the power bar switch both will come "ON" or "OFF" at once. Cost once again from Canadian Tire for about $9. So for about $80 CAD (45 GDP) for a shop vac setup or $96 CAD ( 54 GDP ) you would have a simple setup. kgg
