kgg
Contributing Member-
Everything posted by kgg
Which subclass 8B, 8BL, 8BV, 8BLV, 8BLH or 8BHC??? From your description a new BSC-8BL costs about $4500 USD plus shipping etc. Buddy Price???? Assuming the seller has a BSC-8BL his asking price of $3500 is about 77 percent of a new one. Depending on when he bought the machine he maybe trying to recoup closer to 100 percent of what he paid for the machine. My thought is if you really like the Seiko, which are good machines made in Japan, and it does what you want I would just go buy a new one rather then his "Buddy Price". If I'm not mistaken the Consew 277 is clone of the Seiko BSC but a lot cheaper price wise. If you think the Juki LS-1341 feels cheap you should try some of the clone machines. kgg
The Juki LU-1508NH is rated for V69 to V207 with a max knee lift of 16mm (5/8") for the presser foot . The cost of a Juki LU-1508NH is about $2600 USD ($3800 CAD) Your size of thread for those size of needles is for thread size range of V46 and V69. With those thinner size needles in thick material you run the risk of the needle buckle and breakage particularly on curves / turns. Here is a good cross reference chart for needle size vs thread size. ( https://www.tolindsewmach.com/thread-chart.html ) A lot will depend on how much the foam and fabric will compress down. I think a close comparison on the low end would be a Juki in the LS -1340 series of machine, a Juki LS -1341 or LS-1342 as they would cover off your needle size and maybe your thickness requirement. The cost of a Juki LS-1341 will be Plus $5000 USD whereas you can get a clone for $2000 USD and up depending on the clone you select. Basically it comes down to if you want a true Juki, how thick your pocket book is and the after sales service. Keep in mind a lot of the 1341 clones are clones of the older Juki LS-"341 " not the LS-1341 or are some hybrid version. Either way I would strongly suggest going to a dealer and testing various machines with the thread size you normally use in the max thickness of fabric / foam combination before purchasing a machine. Once you bought it, it is yours for better or worst. Buy Once Cry Once, kgg
The larger the number the thicker and stronger the thread. Thread size V69 is the cross over thread size being typically the largest thread a domestic sewing machine can handle and typically the smallest industrial sewing will handle. here is a good chart for thread size, the correct size needle and breaking strength ( https://www.tolindsewmach.com/thread-chart.html ). The typical needle system for upholstery class machines which the machines you listed fall into typically take a system 135 x 16 x (needle size) for leather and 135 x 17 x (needle size) for fabric. Don't cheap out buy good needles and good thread. kgg
In my option the best flatbed for your needs would be a compound walking foot and in this class of machine a new Brand name would be the Juki DNU-1541"S." The cost in Ontario runs around the $2500 CAD. An example would be from All About Sewing ( https://www.allaboutsewingmachines.ca/products/juki-dnu-1541-s-industrial-walking-foot-industrial-sewing-machine ). Also Japan Sewing Machine & Supply Co ( (905) 764-0100 ) who sell Juki and have their own line of clones called Kobe which would be a lot less expensive then a true Juki. I have bought a few machines from them and would suggest giving them a call they are very good to deal with. As a note: i) would be more expensive to buy a Consew 206RB-5 then it would be to purchase a Japanese made true Juki DNU-1541"S". ii) Since there is no Sailrite dealer in Canada you would have to contend with the rate of exchange / duty / brokerage / shipping costs to get a Sailrite Fabricator iii) You can get the Cobra machines through Tandy Canada iv) Cowboy machine costs would be similar to the Sailrite machines as far as importing costs. kgg
What part of Canada as there are other options. How thick do you want to sew including the thickness of any multi layers? What size of thread are you wanting to use? What is your budget? You should also read the following topic. It should answer a lot of your questions. kgg
Sorry about that my computer decide to have a fit. Here is the link: https://vi.aliexpress.com/item/1005006355613328.html?gatewayAdapt=glo2vnm4itemAdapt kgg
troubles with cb3500 threading on upper tension
kgg replied to TonyGreen3455's topic in Leather Sewing Machines
Good catch. kgg -
Here is a link to a 9pcs set like @fredk referenced from Aliexpress in Canadian dollars at $5.72 for the set with free shipping. kgg
This is a topic that I done sometime ago about the different top threading methods and may help. On my class 441 I follow the method of threading the top thread of the Juki TSC-441. kgg -
Yes the Sailrite Ultrafeed is a "portable" walking foot sewing machine but with the rigid carrying case the term "portable" becomes a relative term. Sort of like the old "portable" microwaves that took two people to move across the kitchen. With the machine sat in it's carrying case it turns into a very clumsy package weighting probably close to about 50lbs. Coupled that with the size of a very well constructed rigid carrying case that is about 21" long x 14" high x 10" wide and having only one top mounted carrying handle. My experience of owning the Sailrite® Ultrafeed® LSZ, with the rigid carrying case, the shine of being able to move it more then a few feet very quickly dulled. I would suggest that you makeup a cardboard box about the same size and put say 40lbs in it. Then see if you can lift it with one arm or hold it on the bottom and then walk up a flight of stairs or across a parking lot. Maybe it may fit your needs but I would suggest trying one first because once you buy it's yours for better or worst. Buy Once, Cry Once kgg
@thesoi6 Just to tack onto what @Wizcrafts has stated. I have owned a Reliable Barracuda, Kobe LSZ-1 and the Sailrite® Ultrafeed® LSZ Sailright with the their "new servo motor". The main difference would be maybe in build quality as the price varies for a new Sailrite clone from $400 to about $1400 USD plus shipping. Sailrite does have quite a good and in after sales support. These portable walking foot machines are in my opinion: i) not meant for leather work as they were designed to do sail repair work on the ocean. ii) in reality the take up thread arm isn't really meant to work consistently with V138 and you may run into needle to hook clearance problems using V138. iii) has a very small Singer class 15 bobbin can be purchased off places like Amazon, Temu, Aliexpress iv) stitch length is NOT consistent and will shorten as the thickness of the material under the presser foot increases. v) increasing the lift so to accommodate thicker material under the presser foot can be done but there can be major drawbacks and takes about an hour of fiddling around in the head. vi) the stock presser foot and feed dog are pretty rough and the original ones will leave impressions in veg tan. You can get after market smooth ones. vii) If you go with a Sailrite clone the holes for mounting edge guides and binding attachments may require the holes in the bed to be threaded as I have see that problem on a number of the Sailrite portable walking foot clones. The Consew 206rb-5, which I have owned, sells new for about $1400 plus shipping so why bother buying a " portable heavy-duty sewing machine" or " semi industrial sewing machine"? The difference between those is like trying to compare apples and oranges as both are fruit and sort of round. Don't waste your money, just get a proper industrial sewing something like the Consew 206RB-5 or a Juki DNU-1541S you will get better results. kgg
Nicely done. Recycling at it's finest. kgg
Yes I have seen it go both ways where excellant machines go for next to nothing and junkers go for almost the price of a good used machine. kgg
If you are planning on upgrading your machine keep in mind if you buy new they will typically come with a servo motor and if buying used you could buy a servo motor at that time if it has an old clutch motor installed. The only way you are going to get the speed control and punching power is with a speed reducer which will cost about $150 CAD. An off the shelf speed reducer may not still get the speed down to your liking so you probably will have to make your own. I would suggest you consider putting that money towards upgrading your machine first. The top end rpm speed isn't the main concern it is the initial startup rpm speed that you should be focused on. The brushless servo motors which have coils instead of brushes and a have a electronic control box like the Sailrite and Reliable have a typical startup speed of 500 rpm's. The servo motors that have brushes and typically just a manual speed dial mounted on the motor have a typical startup speed of about 200 rpm's. I personally like the brushed servo motors, which are becoming more uncommon, are easier to figure out / repair if there is a problem. With either style of servo motor you can get initial startup jump/jerk but a speed reducer would help smooth that out. kgg
The more coils the servo motor has the better the the low end torque range and lower startup speed. A lot of the six / nine coil servo motors have a higher startup speed. A speed reducer between the servo motor and the sewing machine will help to smooth out the startup speed on the six to nine servo coil motors. The Sailrite Workhorse at $225 USD or $321 CAD plus you can count on at least another $150 for taxes / brokerage / shipping is the same as the Reliable 6000 at $259 CAD plus 13 percent tax and whatever the shipping cost within Canada. Are you planning on putting the servo motor on a $100 Chinese Patcher or the Singer 29K Patcher clone machine? kgg
I would be interested in knowing what the Techsew 2750 Pro goes for at auction. kgg
Could the Artisan Toro 3200 be the one machine to do it all?
kgg replied to garethkerlin's topic in Leather Sewing Machines
Since I'm in Ontario, Canada I went with KOBE which was considerably cheaper then what a Cobra, Cowboy or even a Techsew would have cost. -
Sounds like the lady is emotionally attached, which is understandable, but I think she is being unrealistic as you can get a new one for $2900 USD plus shipping. At auction I think she would be lucky to get 50 to 70 percent of a new one, $1500 to $2100 (pristine condition). As a note I am selling my 2750 Pro in pristine condition and less then 3 years old for $2800 CAD ( $1940 USD) which is about 63 percent the cost of a new one. kgg
You got to be very careful these days and go with your gut. Sad thing is if it is a scam which I highly suspect it is how many people are going to get suckered? kgg
This may give you some idea as to what they would cost new and from there you could decide what they would be worth to you. The embosser is from Ivan Leathercraft out of Taiwan and can be bought new on sale for $405 USD (https://www.ivan.tw/products/final-sale-professional-leather-strap-embossing-machine-1 ). A similar splitter to the one in the photo can also be bought Ivan Leathercraft for $350 USD ( https://www.ivan.tw/collections/machines/products/deluxe-leather-splitter ) What are they asking for the embosser and splitter??? kgg
Here is a link to a good chart that cross references needle size to thread size ( https://www.tolindsewmach.com/thread-chart.html ). I have owned a Reliable Barracuda, Kobe LSZ-1 and the Sailrite® Ultrafeed® LSZ Sailright with the their "new servo motor". The main difference would be maybe in build quality as the price varies from $500 to about $2500 CAD. These portable walking foot machines are in my opinion: i) not meant for leather work as they were designed to do sail repair work on the ocean. ii) in reality the take up thread arm isn't really meant to work consistently with V138 and you may run into needle to hook clearance problems using V138. iii) has a very small Singer class 15 bobbin. Those can be purchased off places like Amazon, Temu, Aliexpress iv) stitch length is not consistent and will shorten as the thickness of the material under the presser foot increases. v) increasing the lift can be done but there can be major drawbacks and takes about an hour of fiddling around in the head. I was able to increase the factory setting of a Kobe LSZ-1 from 6.35 mm to about 12mm but that little machine did one task, edge binding and was reset before I sold it. vi) the presser foot and feed dog are pretty rough and the original ones will leave impressions in veg tan. You can get after market smooth ones. vii) the holes for mounting edge guides and binding attachments may require the holes in the bed to be threaded as I have see that problem on a number of the Sailrite portable walking foot clones. To get your speed down you can add a Sailrite® WorkerB® Power Pack Motor System for about $300 USD ($450 CAD) but by the time you get it into Canada with the rate of exchange / shipping /taxes you would be looking at about $600 plus CAD. Which would be about two thirds of what you paid for the machine initially. Another option would be to add a custom speed reducer using the existing 90 watt motor and some inexpensive pulleys. kgg
And Happy New Year to everyone. kgg
That's a shame. But aren't knitting needles pointie on one end with some made out of metal (stabbing instrument) and isn't boiling hot water needed for tea (scalding potential). Imagine if you wanted to bring a class 441 machine to class someone could sew their hand to the machine. Damn bleeding hearts. kgg
Very cool machine, definitely made for volume and consistency not as automated as some belt machines. The way I figure it there are two basic levels of handcrafted just depends on the market you are going for: i) Belt blank cut and dyed by hand, sewn by hand, belt ends cut by hand, holes punched by hand and embossed by hand. Should command the highest price for a quality belt as each one of the same style will be slightly unique and the labor / skill involved with making it. ii) Belt blank pre-dyed, cut with a strap cutter, sewn by machine, ends and holes punched with a machine and embossed by machine. Provides consistency and improves efficiency which reduces the cost per belt.The drawback is the cost of equipment. kgg
My thoughts are the Artisan Toro 3200 is a class 441 machine with a chopped down cylinder arm as the original Juki TSC-441 machines have a 16" cylinder arm. When I was looking for a Class 441 clone machine, couldn't justify a true Juki TSC-441, I drove myself nuts looking at the specs of a lot of machines. I finally just went with a standard Juki 16" clone using standard readily available parts that can be had from a lot of suppliers and figured it would be a lot easier to sell down the road. That said if the price was right and it was in great shape it maybe worth a consideration. What are they asking for the machine???? kgg
