kgg
Contributing Member
Everything posted by kgg
  1. Thank you. Good price. kgg
  2. Looks good. I would recommend flushing it with a lot oil to get rid debris from manufacturing and to make sure every surface that touches another is thoroughly lubed. What was the approximate cost with shipping / duty. kgg
  3. A wheel foot will not work with a walking foot machine. What machine are you using? kgg
  4. Maybe adding a speed reducer would help???? kgg
  5. Here is a sketch of a simple platter. i) Thread 3/8" rod about 12 " long. ii) 3/8" Nuts. Need 3 of them. iii) Platter: Can be plastic or metal as long as it is big enough and sturdy enough to hold your bias tape. iv) 3/8" Bearing: Need one v) The mounted to the table I will leave up to you. kgg
  6. When you make one have the flat plate spin on a bearing that way you will not be dragging the whole weight of the coil of binding tape and it will be easier to get consistent back tension. kgg
  7. The Juki LS-1341 is a good machine made in Japan. The clones are made in China and Taiwan. The clones depreciate at more then the real deal Juki's and are more difficult to resell. For me the best time to sell one of my clones is around the 3 years old mark while the Juki's stay. Typically the clone LS-1341 are clones of the older Juki LS-341 and the clone LS-1341 with the knob on top are hybrid LS-341 while others also have casing changes and or internal part changes. It can be a bit of a task trying to decipher what some of the clones are clones of as they may have different model numbering labels. Example: Cowboy CB341, Cobra class 26 and Techsew 2750 similar to the Juki LS-341. The Juki LS-1342 has the knob on top and comes with a narrower nose rather the standard larger nose diameter of the Juki LS-1341. My take on: i) The main reason you see Juki's at the 50 percent depreciation mark is that they typically have come out of an industrial usage setting with some beaten to death and need an overhaul. If you can find a Juki LS-1341 or LS-1342 from a hobbyist expect to pay 70 to 80 percent the price of a new one. In Ontario, Canada you can get an ex-industrial used Juki LS-1341 for about $1000 USD ($1500 CAD). ii) Also the market for cylinder arm machines is a much smaller market then the flatbed market. iii) Price of used machines in general will also depend on the available supply, demand and economy in local / state / province. iv) Buyers have a magic number in their head for purchasing a new or used machine. I think for a used machine the upper number is $2000 then it is just as well to buy a new clone from a reputable dealer for the extra dollars. It is easy enough to know the difference just by looking at it or photo's. kgg
  8. i) The binder you are using is not positioned properly from front to back and twisted. To me it seems as though it was made to be used with a particular type of binding tape with a specific presser foot setup. ii) The binder has no front to back adjustment. iii) The make shift arrangement of how you are mounting the coil of bias tape is never going to give you consistent and acceptable results. Suggestions: i) Purchase a proper bias tape platter. I prefer a platter that holds the bias tape horizontally over one that hold the bias tape a vertically. ii) Since you are close to the Sailrite store purchase a Sailrite inline binder for 1" binding tape if that is the size you want ( https://www.sailrite.com/Binder-1-Swing-Bracket ) with a swing away attachment. I have a couple of the Sailrite binders that came with a Sailrite machine that I picked up awhile ago and they are decent quality but expensive at $72 USD. As a price comparison you can get a pretty good CKPSMS branded one off Amazon.com for $20 with a swing away attachment ( https://www.amazon.com/CKPSMS-Adjustable-Single-A4B-Machines/dp/B0BH8MG3SR?crid=1AQ7CPZYU45IC&dib=eyJ2IjoiMSJ9.Vk4OlxqvhPRNsqsK4L5btm_oB3ToI8b9AUN-BxlpKNlq-4hV3Nd9ALOdzkLEDyln43jzKhLQ8ptVTstf5lcUSkSDGJkKjWxkZ1dTnVWiZnJr_CL_STfYpLxqowFJTLTtsoLsEU7Z4dj1HHfBFB7_BkINB_wnW9KhwsLChDL4ztsiJ0gJ0DOSanI4teK5lKTby1K1j4p7pqcWcje5uMH6tezCKaPNUYSRAzGcXvdyJmqci88YI0BzhJg5ZccBWEO1CHeBx4skmcN8RqYHbrM8aROf51xjDe5iO33-i_OiwSR2ljvhBvF7aou_4pcrLA2bpxNM0QqPbIRuaogpBAq7uz2mZ32xKTXbk2wGBuUpnf7phIKBiXYs_XPiYeMrZWOXYUREyAaMCYoa7pFkZ3yDaZyAz4lXRIQi2esyfFAH9YBydEv1HVwDXc5pOuqpe1Xd.1ZGLcvgIyXGofpY6xddiETTz6CkoSkul-8DmIUohh9U&dib_tag=se&keywords=CKPSMS+Brand+-+1SET+Swing+Away+single+Fold+Binder+Attachment&qid=1739146362&sprefix=ckpsms+brand+-+1set+swing+away+single+fold+binder+attachment+%2Caps%2C89&sr=8-4 ) If I am not mistaken Sailrite binders only come in single fold so you would have to purchase binding tape already folded over or use raw edge binding tape in the size for the binder you buy. How tight are you planning on doing? With a inline binder I can usually get about a 2 1/2" diameter turn and if I am careful about 2" diameter. all lot depends on the thickness of the binding tape and material. kgg
  9. Here is a good manual ( http://www.consew.com/files/112347/InstructionManuals/205RB-1.pdf ). I would first get the needle to hook set correctly first, Section 21 page 10 then move on to the feed dog and presser foot. kgg
  10. I would recommend going up to a #24 or maybe a #25. Here is a good cross reference chart for needle size to thread size. ( https://www.tolindsewmach.com/thread-chart.html ). What maybe happening i) needle eye to small for proper fitting of thread ii) depending on the thickness and toughness of the leather the hole being punched in the leather isn't large enough to allow for the top and bottom V207 thread and it is being caught / jammed into a too small a space. kgg
  11. Here is some info. A lot is going to depend on the bore of the needle bar. What machine are they for? kgg
  12. What size of thread with what size needle and how thick of leather? kgg
  13. A very nice machine. The clones of the Juki differ from the original but this fairly easy, simple change and you really don't need extra parts except for the chain and foot pedal. What part of Canada are you in?? Procedure: 1. Remove knee pad and connector from front of the knee shaft extending out from the machine. 2. Unlock and tilt the machine back 3. Loosen the connector for the knee lift horizontal shaft inside 4. Slide knee lift horizontal shaft out the back of the machine and re-tighten connector. 5. Install knee lift rod, install chain from the end of the lifting connector down to the pedal. 6. Job done Here is a link: https://www.youtube.com/watch?v=uwvWsuxPAD0 at 4:06 is what the horizontal shaft should look like at 16:29 to 16:58 installation of foot pedal kgg
  14. That's about $920 USD and new at 22000 Rand it would be about $1200. The ORYX OR341 is another clone of what appears to be a Juki LS-341. kgg
  15. There is a video of the Alder 30-70 video. Note the audio is in German. kgg
  16. I use inline/straight binders single fold and double fold from 1/4" to 3 1/2" on all my machines whether they are flatbed or cylinder arm. The main advantage of a 90 degree binder is that it should be able to do tighter corners then a inline/ straight. The disadvantages of the 90 degree binders are i) they cost a lot more then your inline/ straight. ii) you can't on most adjust the tension on the tape at binder itself. The main problem I think you are having is poor back tension on your tape and the path the binding tape travels through the binder is to wide so you are getting tape slop. Are you using your binding tape with a vertical or horizontal platter or just letting it drape to the floor?? Any photo's of your binding setup???
  17. Did you get in contact with Techsew and how did it work out? kgg
  18. My experience is that you can not burnish chrome tan. I use a soldering iron after lubing the edge. kgg
  19. Very nicely done and a great use for those old circular saw blades. What did you use to cut out the shape of the old saw blade? kgg
  20. A couple of questions: i) What size of thread are you using? ii) What size of needle are you using? iii) how thick of material are you trying to sew? iv) Does it happen on straight runs or when doing curves? kgg
  21. At the max of 3 layers of 8oz the leather would be approximately 3/8" thick. i) That means if you purchase a upholstery class machine and depending on the toughness of the leather you would be at the max sewing capacity. Another factor that you did not mention is the max size of thread you want to use. If you hand sewing chances are you are using a thread larger then V138 probably closer to V415 or higher. ii) Typically upholstery class machines at max sewing capacity will handle up to V138 thread. The Juki DNU-1541 S is compound feed ( needle/ presser foot / feed dog moving the material ) ans is an upholstery class flatbed machine. Costing new about $1800 USD plus shipping. The Cowboy 3200 is a compound feed ( needle/ presser foot / feed dog moving the material) 10.5" cylinder arm Class 441 machine which is rated for up to V346 thread and up to a 1/2" thickness. Costing new about $2200 USD plus shipping. The Cobra Class 4 is a compound feed ( needle/ presser foot / feed dog moving the material) 16.5" cylinder arm machine Class 441 machine which is rated for up to V415 thread and up to a 7/8" thickness. Costing new about $2900 to $3900 USD depending on the accessory package and shipping. Another alternative would be a Class 441 that can handle V415 thread but is a manually operated one arm bandit like the Tippman Boss (~$1000 to $1200 USD), Cowboy Outlaw (~$1400 USD) or the Master Tool Cub (~$2000 USD) plus shipping. Another thing to take into account is the needle system as the class 441 machines use 794 needles while the uphosterly class machines typically use 135 x 16 needles. A rough comparison between the two needle system would be the 135 x 16 would be a 1 1/2" finishing nail versus a 794 would be similar to a 3 1/2" finishing nail meaning there is going quite a difference in the hole size in the leather. kgg
  22. Funny thing I NEVER use sewing machine oil in any of my machines. I use a formula of synthetic motor and synthetic transmission oil. If I am flushing a old machine out I use a formula with more transmission oil to get into the bearings and remove any dirt/ etc. I find the synthetic oils lubricate surfaces much better, reduces friction and quiets a machine down particularly an old machines. A old sewing machine mechanic who worked at a factory where machines were used 24 / 7 used straight transmission oil to keep the machines cooler so they could keep up with the sewers. To answer your question an oil at your spec is similar to 5W oil at 20 C based on the chart ( https://imgur.com/DDA5MJW ) kgg
  23. @Dwight , @Hildebrand I'm sure once things settle down @Johanna will let us know the site is up and running properly. Please keep in mind rebuilding a site after a hack can be very time consuming and we are lucky it is functioning at all. kgg
  24. For the reasons @Wizcrafts gave the simple answer is NO. I would suggest a walking foot machine like the Juki DU 1181N. A new complete setup, machine, servo motor and table is about $1400 USD used???? I use my Juki DU-1181N to cover off the thinner stuff the Juki DNU-1541S doesn't like.
  25. I think I would use: i) an off the shelf hollow linear shaft as they come in various outside and inside diameters. I guess a shaft with a 3/4" ( 20mm) OD and a 3/8" (10mm) ID would work. If the shaft isn't large enough add some form of a grip. These shafts are really available off places like Aliexpress and are mostly used for linear movement. An example would be ( https://vi.aliexpress.com/item/1005008313729816.html?spm=a2g0o.productlist.main.1.7f1edY5sdY5swH&algo_pvid=da5d617e-a98c-46cd-b478-14026027a4f7&algo_exp_id=da5d617e-a98c-46cd-b478-14026027a4f7-0&pdp_npi=4%40dis!CAD!26.96!13.48!!!133.20!66.60!%402101e9a217380630172501546ef44e!12000044581316320!sea!CA!3463193163!X&curPageLogUid=rV9wvFNWFsW5&utparam-url=scene%3Asearch|query_from%3A ) ii) 3D print a shaft with comfortable outside diameter for my hand with the correct inside diameter to accommodate the stamp. Cost would be pennies to make. Me being me I would do the 3D printed method. kgg
