kgg
Contributing Member
Everything posted by kgg
  1. I can only say the photo of the thread to the top pin looks like an 8 oz spool of inexpensive Chinese thread. Your video doesn't work. kgg
  2. My suggestions to try: i) Your top threading is incorrect. a) The first guide after the top pin should be at the 12 o'clock position b) you have the thread wrapping around and over the pin in the first top thread tensioner. It should go between the tension disc of the top thread tensioner and straight down to the next set of discs for the thread takeup. Section 9 THREAD THE MACHINE HEAD of the manual. If you don't have a manual I have attached a screen shot of the proper threading and a pdf of the manual. ii) This machine is a unison / compound machine made for medium to heavy weight materials. The material you are using looks like a thin fairly stiff material similar to ripstop or a very tightly woven fabric. a) bulk up the material b) reduce presser foot tension c) make sure the fabric isn't being sucked into the needle plate hole d) use a leather point needle to cut the material rather then a fabric needle which will try to separate fibres before punching through d) Wrong machine for the job try using a domestic sewing machine or needle feed needle. kgg instruction_eg.pdf
  3. Glad to be of some help. kgg
  4. Very nicely done. My suggestions on speed reduction: i) if you need to slow down the machine and reduce servo motor "speed jump" you should add in a speed reducer pulley. Most of the brushless servo motors have a minimum startup speed of 500 rpm and a pulley size of 50mm. With some of the brushless servo motors the initial increase in speed from 0 to 500 rpm, speed jump, can be a problem. With your arrangement by increasing the size of the hand-wheel pulley size from 2 3/4" (70mm) to approximately something just under 4.5" say 110mm you did gain some reduction in speed. Example A: i) Without the new hand-wheel pulley the speed of would have been 357.1 rpm with a minimum startup speed of 500 rpm at the servo motor. ii) With the new hand-wheel pulley the speed would be reduced to 227.3 rpm with a minimum startup speed of 500 rpm at the servo motor. To help with smoothing out the speed jump with the side benefit of increased torque install a speed reducer pulley between the servo motor and the new hand-wheel pulley. Example B: 1) With the new hand-wheel pulley and a minimum startup speed of 500 rpm at the servo motor. i) install a 3:1 speed reducer pulley having a typical size of 6" large pulley and 52mm" small pulley the speed of the new hand-wheel pulley will be reduced to 78 rpm If you had just used the original hand-wheel pulley size of 2 3/4" (70mm) and a minimum startup speed of 500 rpm at the servo motor the speed would have been reduced to 122 rpm at the hand-wheel. kgg
  5. When you get the Singer 15-90 freed up be aware it is an old domestic drop feed sewing machine. Nether the Singer 15-90 or the Singer 29-k2 are meant to do tack work. The Singer 29K2 was last made around 100 years ago finding parts could be difficult or near impossible to find so you may windup with a boat anchor. I would suggest you read this article about what sewing machine you should be looking at for your needs. Buy Once, Cry Once kgg
  6. Just so you know the Juki DLN 415 is a needle feed high speed garment (fabric) machine not meant as leather sewing machine except for maybe some very thin upholstery class leather. The max needle is a DB x 1 (16 x 231) x size 22 needle so it good for max V92. I would tilt the machine back and see it the reverse lever mechanism isn't jammed or seized-up. Here is a pdf of the manual. Juki DLN-415 Instruction Manual.pdf
  7. Nearly 5 months, that's way to long a time-frame. Why so long?? Why not do a video dump of the course so individuals can review then pick and choose what parts maybe appropriate for them? Since your company is in China ( https://jinglinmachine.com/?srsltid=AfmBOoq11e89sz6k-gwr_MvnnFWrXn2mTgNU2aJrJ60DGEhRVdGXQ5W6 ) the cost of your equipment would probably be prohibitive if subject to tariffs for US customers at I believe 145%. Example: Your EC-17 with a letter holder would be $600 (assuming USD) subject to tarrifs would cost 600 + 870 (tarrif) = $1470 USD versus a Weaver Foil and Hot stamp machine ( https://www.weaverleathersupply.com/products/foil-and-hot-stamping-machine?utm_source=youtube&utm_medium=product_shelf ) would cost $870 USD. kgg
  8. The only way I know is hot stamping. The tradition way of stamping only works with veg tan. This article may help. kgg
  9. You should try Old English which is still spoken in some NFLD. communities at speeds that would put an auctioneer to shame. Simple Example: "Come to he the once" in modern English it means--> I'll be right there.
  10. I feel your pain. Interesting design so the belt is now multilingual. kgg
  11. Another alternative is find someone with a 3D printer and they show be able to do one up in the size you need. The cost of the actual 3D print would be less then $2.00 in materials but getting the design replicated is going to be costly. kgg
  12. Hoffman Brothers in Des Plaines, Illinois. https://hoffmanbrothers.com/ kgg
  13. I can understand that. I find it gets a little harder as you become an old geezer like me. kgg
  14. Overall a good brand name flatbed machine however they are getting really long in the tooth, old. If the machine was used in a commercial environment be very very careful as chances are it was beat to death and have someone check the machine out even if it is being sold by a vendor. You don't want any unexpected repairs. Some photo's would help determine it overall condition. That said if was owned by a hobbyist from the beginning it could be a very good machine. What are they asking for the machine??? What is your realistic budget???? If it is the one in the Kijiji add for $750?? https://www.kijiji.ca/v-other-business-industrial/oakville-halton-region/juki-563-industrial-sewing-machine/1714150747 If it is then right off the bat you will need to change the motor from a clutch motor to servo motor so add another $200 to the price so now you will be up to $950. The reason for the motor change is unless you are use to using clutch motors the learning curve can be very steep. A servo motor is a lot less noisy, more energy efficient as they are not running all the time and it will give you the controllable speed needed for sewing leather items. It is an ex commercial machine and has been used a lot by the wear on the flatbed. Ask for a picture of the underside of the machine particularly the timing belt as if it is worn out it will probably cost another $200 for it's replacement. kgg
  15. Nicely done. kgg
  16. Good idea. But can't you just 3D print one which would cost less then $2? kgg
  17. There are two basic styles of machines cylinder arm and flatbed machines. The term "free arm" I think came from the introduction of the Singer model 222k Featherweight back in the 1940's that had a "free-arm sleeve". That reference to the style then got further shorten to "free arm" by the domestic sewers. There are basically three common forms of how material fabric or leather is moved along to the rear of the machine. i) by the feed dog along with a drop down presser foot that just keeps tension on the material as the needle enters. Typically seen in domestic sewing machines. ii) by the feed dog along with a presser foot that keeps tension on the material but moves in coordination with the feed dog to move the material along. Typically referred to as a walking foot machine. iii) The same as walking foot with the additional feature of the needle also moving the material along. Typically referred to as a compound or triple feed. To short answer to your question of whether a walking foot flatbed machine will sew bags and purses easily the answer is No. Things that are flat like a wallet or belt is best sewn on a flatbed machine and things that are round are best sewn on cylinder arm machines. Keep in mind that you can sorta kinda turn a cylinder arm into a flatbed machine with a flatbed attachment but you can not turn a flatbed machine into a cylinder arm machine. If you come across a machine but are unsure of it's capabilities just ask but include the model of the machines you are looking at. I am sure someone can give you the pro's and con's for most models and manufacturers. Example: Flatbed Juki DU 1181n (walking foot) Juki DNU 1541S (compound feed) Cylinder Arm Juki LS 341 or LS 1341 (compound feed)
  18. You using the 3D printer for what it was intended to do, make work easier. kgg
  19. Typical setup is on the right front corner area. kgg
  20. To handle 2 layers of 9 oz you need a class 441 machine. You could probably get away with a Class 341 / 1341 but it probably wouldn't handle the the addition of the welt. So you need to move up to a Class 441 machine. The premium one is a Juki TSC 441 but the cost is prohibitive at around $10,000 USD so most go for the clone machines which to name a few the Cowboy 4500 and the Cobra Class 4. The base machines like the Cowboy 4500 will set you back about $3000 USD and the Cobra Class 4 will come in at about $3400 USD. From the base price you would add the accessories like needle positioner and table top, etc plus shipping which probably would add another $300 or so depending on where you live. The Class 441 machine probably will be over kill for most belts. Keeping in mind the difference in the size of holes the needle will make in the leather. The Class 441 has a needle diameter of about the same size a 2 1/2 " finishing nail would make. So you in reality you should consider two machines depending on the thickness of leather: i) a Class 341 / 1341 for belts, wallets, etc and ii) a class 441 for the holster type work. It will really come down to what 90 percent of you work will involve. Where are you located US, Canada, Europe ???? If you are going to get a Class 441 machine go with the standard arm length of about 16", the small 9" on the 3500 probably will only give you about 7" or so working area. Join the club. You can drive yourself nuts researching the various machines available, their specs, flatbed or cylinder bed, are they a clone or a hybrid machine, manual or motorized, whether they have a needle positioner, a table top etc. Ask yourself two simple questions: i) What are you going to be sewing the most??? Buy a new machine for that type of work while buying a used one for the other type of work. ii) What is my budget? If money is no object buy Brand Name machines like Juki, Dürkopp Adler. If it is more of a hobby buy a clone. Keep in mind that no one machine will do everything and you can sorta kinda turn a cylinder bed into a flatbed but you can't turn a flatbed into a cylinder bed. Buy Once, Cry Once, kgg
  21. I agree the first video does show long cables but the second video shows the control box and servo motor as one unit with the wiring from the motor directly into the control box. Looks like two different servo motor setups being advertised. @friquant which layout did you get?? The one with the long cables or the one with the on/off switch mounted to the front of the table??? Second related video in advertisement: https://www.amazon.com/live/video/0b443a3824a2418a9770702b7017ddf6?ref_=dp_vse_ibvc1 kgg
  22. Very nicely done. Ain't templates wonderful grand things. kgg
  23. Basically whatever you can stuff between the cutters it will cut.
  24. That may work but besides longevity the diameter maybe an issue with the bending ability of the belt around to such a small diameter and premature belt wear. It's worth a try but I would alter your design to add a larger diameter surface face on the motor side of the pulley with blades to help keep the motor cool while running. With that size of servo motor pulley (35mm) and a 4" (104mm) handwheel with the servo motor running at 100 rpm the speed at the handwheel will be reduced to 33.7 rpm. The controller will handle the speeds but it's configuration on the motor was done to reduce the manufacturing cost with no consideration of easy access to the settings. You are going to be on your knees trying to change any setting. kgg
  25. The design of the servo motor you referenced has fins on the motor of the pulley probably for motor cooling as the control box blocks / restricts air flow into the motor. Options: i) If you can't find a 45mm pulley with the correct taper I would check with a machine shop or supplier. ii) have a 45mm pulley modified by either re-machining or by using a brass taper bushing. iii) If you got this off off Amazon I would personally return it and get a more conventional layout, one where the control box is mounted on the front underside edge. I think having to reach underneath the table to the far back of the table to change settings could be very inconvenient. iv) If you do find a pulley chances are it will not have the cooling fans which may affect the life expectancy of the servo motor. I think buying and installing a speed reducer would be the simplest solution. Based on the motor you referenced. The motor pulley is 3" in diameter and if you install a 3:1 speed reducer which typically has a 6" large pulley and a 2" small pulley you will reduce your speed at the sewing machines handwheel. If my calculations are correct by 75 percent. Example: i) servo motor 3" pulley running at 100 rpm ii) 3:1 speed reducer installed iii) 4" sewing machine handwheel pulley The 4" handwheel will spin at 25 rpm. kgg
