kgg
Contributing Member-
Everything posted by kgg
I'm glad the you got it freed up. As far as I'm concerned there's nothing better then good old fashion Diesel. It works better then any of the "penetrating oils" just smells a bit. I would now flush/soak the area with synthetic transmission fluid. That will soak in and flush out the old garbage while lubing. Sorry, can't help with the amount of movement you should have. kgg
Thank you. Looks uncomfortable but I have never worn one that way, always worn one on the outside. kgg
Maybe a vise and a couple of boards. kgg
I am going to ask two dumb. Why are the clips on the front of the holster and how does it attach to your belt??? kgg
I have had great success with diesel and so so with penetrating oils. Once you give it a go with synthetic transmission oil the smell usually is gone. Another suggestion is to use heat like from a heat gun or propane touch and when it is hot hit it with oil for a fast cool down. That may free it. kgg
I would get a wire brush and scrap all round the unit particularly around the feed eccentric seam and then add a few drops of good old fashion diesel around the feed eccentric seam. Wait about 24 hours to let it soak in, a few light tabs with a hammer and without any needle or bobbin run it at different speeds for a few minutes. If it hasn't freed up start over with a few more drops of diesel. Once freed oil the heck out of it with some synthetic transmission oil. If you can't get it freed like @CowboyBob has suggest replace the unit. kgg
Have you tried unpluging the servo motor cord from the wall outlet. Some electronic items even through you have the power switch in the "OFF" position they are still drawing power and are basically in a "Sleep Mode". I would unplug and wait a few minutes just to make sure it has fully powered down and cleared it's memory. On my LS-341 clone which has a brushless servo motor and electronic control when I throw the power switch to the "OFF" position the electronic display stays light for about a minute before going blank. So there is a power draw. I would contact both the store and Artisan to clarify your warranty. Having a damaged cable could have or is causing a short which in turn could have caused an error or worst case fried the controller. If you damaged the wiring chances are you are going to be on the hook for a new cable and possibly a controller. If it does turn out to be the controller unit it maybe cheaper just to replace the complete motor setup for about $150 to $200 for 6 coil motor or $300 for a 12 coil motor or a brushed servo motor for about $175. The trouble you are having tracing the source of the problem highlights the difference between a brushed servo motor with no fancy electronics and a brushless servo motor with a electronic controller box. As you can tell I am not a fan of the brushless servo motors. I like my machines to be as simple as possible. Sewing machine, speed reducer (on some), servo motor, drive belt(s) and a go pedal. The two machines with brushless servo motors have the needle positioning disconnected. kgg
Rather then you fiddling with a new machine be it a demo unit I would go bring back the machine to the seller and ask them why the 794 needles don't fit and have them correct the problem. kgg
According to their manual Page 13 THREAD SPECIFICATIONS: Breaking down what "794s Serv 1 230 ...... SM 53-5 " means i) the 794s Serv 1 denotes the needle has a chisel point tip made for leather sewing ii) the 230 denotes the size of needle. Here is a good reference chart for the thread size vs the needle size needed ( https://www.tolindsewmach.com/thread-chart.html ) iii) the SM 53-5 is the Tippmann Boss part number for the needle. You can order these directly from Tippmann using their part number or from other vendors just by specing the needle system, needle size and shape of the tip of the needle. The needle system (794) denotes the length of the needle. All 794 will be the same length. Are all the needles the same length when you put them side by side?? It maybe as simple as you don't have the screw holding the needle backed off far enough. Otherwise I would call Tippmann. kgg
I'm not a moderator just your average joe user and probably a pain in the butt at times. I wholeheartedly appreciate the work and effort that all the moderators do to help keep the rest of us on track and this forum running. You really need to rethink what you said and your tone. It really doesn't do you any favours and may come back to haunt you in the future should you decide to stay when you do need help. Have a nice day. kgg
nicely done. kgg
Have you thought of using Chicago screws as you can get them in various sizes (diameter and length). Like @fredk I would be more concerned with using AL but then again I have had Copper rivets turn green. kgg
My suggestion would be to cut your teeth using a flatbed machine with a standard inline Single fold binder attachment and Double fold binder attachment then experiment doing the edging on various scrap cloth and leather. For this you can buy inexpensive binding attachments off Amazon for about $10 to $15 and you will not need to change the feed dog or presser foot or the needle plate. Size your folder based on the width of the finish tape size you need. Example: 10mm fold over i) you need a 20mm tape and a Single fold binder attachment tape to get you approximately 10 mm fold over on fabric (depending on thickness of fabric)with a raw edge. ii) you need a 40mm tape and Double fold binder attachment tape to get you approximately 10 mm fold over on fabric (depending on thickness of fabric)with a raw edge. The most important thing I can say is make sure that the material you are trying to edge stays snug up against the tape in the folder and the space between the needle / presser foot and the edge of the binder is keep to a minimum. Slow sewing to maintain contact in the binding attachment will help prevent binding tape wonder. I have a set of the 90 degree binder attachments that I never use. I use the inline style (Single & Double fold ) binding attachments (1/4" to 3 1/2") on both my flatbeds and cylinder arm machines. For what I do I never have found the need to change the feed dog or needle plate to do binding on a cylinder arm. As a note: The main advantage a 90 degree binder attachment has over the inline is the ability to do tighter turns. kgg
I think you need: i) the right size of folder for the size of binding tape, ii) the folder has to have the correct size opening / pathway for that thickness of binding tape, iii) the correct amount of back tension on the binding tape.
Personally I would remove the cotter pin on the catch arm pivot point, the catch arm that catches the side of shaft and see what going on. Maybe the hole in the larger piece at that point has worn the pin or the hole in the larger piece has been enlarged. What do you have to lose? kgg
Here is a decent video on how the safety clutch works. ( If your machine will not reengage as @CowboyBob has suggested due to parts being seized I would suggest removing it and soaking it in diesel for a day or so then oiling it. If it still will not work either replace it or as a very last resort tack weld it in place. If you tack weld it in place you will not have a safety and if you jam the machine up you probably or more then likely going to damage / destroy other internal spots. kgg
Nice you should get good use of it. kgg
Yes, when my eyesight was good enough. When I was a member we had access to all military small arms (semi and full auto), ammo and training. Back then the DCRA competitions were limited to military ( commonwealth countries only), Canadian police forces and DCRA members. The DCRA was limited to military, ex military or reservists and police. All firearms and ammo had to be military compliant and no scopes. I am surprised you managed to get across the border without some of those pretty silver brackets. kgg
Nice old iron. Others have given good advice. My only comment is finding the boat type bobbins can at times be difficult so don't loose / damage the one you have in the machine. What is the going price roughly these days??? kgg
I see a lot of wasted overhead space. I'm sure you could figure out how to hang stuff from the ceiling. I see you have what appears to be a Dillon RL-550C. Dillon makes really decent presses, you should get excellent results. I have 5 Dillon presses for my other addiction 1-RL 550c, 1-XL 750, 3- Super 1050. kgg
Nicely done. kgg
The pin usually has a larger diameter on one side and by the looks of the pin you tried to knock it out the wrong way. I would try knocking it back, then cutting the damaged section off of the pin and use a drift punch to knock it out the other side. In the end you may wind up drilling it out. A 3" nail will work as a replacement pin. kgg
Not uncommon. What I would do is: i) remove the pulley BUT mark it's position on the shaft as it is easy to put it back wrong and you will be out 180 degrees. ii) check and see if there is a high spot in the groove. Depending on findings you may have to lightly grid it. But this could be as simple as reinstalling the pulley not as far in on the shaft as it's original position. It could have been installed to far in at the factory or by the guy you got it from. Don't forget to lightly oil the shaft or the groove in the pulley. kgg
Chances are what oil came with the Consew was Sewing Machine Oil like Lilly White. Sewing machine oil is not 3 in 1 oil. I know I am the odd man out on this point but I never use sewing machine oil in any of my new or used sewing machines. I use a combination of synthetic motor oil and synthetic transmission oil. The amount of each varies depending on whether I am flushing a machine or just normal oiling. kgg Good one. I like that. kgg
