Everything posted by Frodo
HI, I have been busy working. not a lot of time to be on a forum. Here is a range bag I made..The elk hide to the veg tan end panels did not turn out the way I wanted. inexperience on a sewing machine other than that I think it is OK for my first go at this kind of project 24'' x 12'' x 12'' it is lined inside with veg tan, the outside gussets are the anchor points for the inside pockets
2 pcs 8 oz veg tan sandwiched between 2 pce 3 oz elk hide and a wet form veg tan piece with elk hide lining double stitched
With some fantastic help and pattern from Dwight. I made the holster. I made the belt and cartridge holder with out a pattern. I am going to add a layer of 2oz suede on the inside of the belt. and I need 3 rivets to finish Belt is 2 layers 8oz veg tan, holster is 2 layers 8 oz veg tan cartridge holder is 2'' wide 8oz with a 1'' strap.
poppas got a brand new bag
Frodo replied to Frodo's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I used 2 dyes. antique mahogany and black [mahogany is cut by 50% rubbing alcohol] dyed the whole thing mahogany, did not touch up uneven dye areas dipped a sponge in black dye, then rubbed off half the dye, I died the edges black and the top edge black by holding the sponge on an angle so that i died the top and edge at the same time, randomly then just rubbed the body of the leather here and there.. then sealed it all with goof proof water based finish -
Plonkers knife Sheath
Frodo replied to Frodo's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Really? Damn i was afraid of that, thats what I get for trying to do something different thanks for letting me know that. -
Anyone interested in a group buy from alaibaba for snaps, rivets, etc? I volunteer https://leatherworker.net/forum/profile/85578-chuck123wapati/ to collect the money and make the purchase. You just volunteered Chuck. LOL
Please delelete one of these double posts -
I used a 9 ply waxed poly string that is used to tie off cables I REALLY like this string. Beautifly damascus blade
1911 shoulder holster
Frodo replied to chuck123wapati's topic in Gun Holsters, Rifle Slings and Knife Sheathes
he guy stuffed the gun down his pants. no holster idiots are idiots and you cant fix stupid I agree that Glocks are junk, I 'm a 1911 man -
Glock will not fire unless the trigger is pulled holster has a trigger guard cover, so it is impossible for the glock to fire putting the gun in or removing from a holster -
I was searching for union lockstitch but fell down a rabbit hole
I like what you did. I have been looking around and talking to a couple of cop buddies And was told to look up a jackass shoulder holster ..double mag pouch on one side with your holster on the other. The GOOD thing about this rig, is your holster off your belt can also be on the shoulder just by adjusting the straps..chicago screws -
So it sounds like the barracuda is not my machine. If I go second hand. with a $600.00 budget. what brand name am i looking for that is a narrow slotted jump foot machine? holsters,belts knife sheathes are the goal, My patcher is tearing up veg tan. it is great for other stuff
Will the Reliable Barracuda sew holsters? 1/4'' leather? 0r 3 1/8'' pieces totaling 3/8'' ?
I likely thumbs up !!!!
I have an idea . if you were to use just 1 strip of leather. fastened to your pants the route of the strip would be from [left side] holster up, then around the neck, down the right back side to a belt attachment in the front the other end of the strip would be from holster down to belt at midway between front back see 4th grade drawing -
Chuck, https://www.strapworks.com/ProductDetails.asp?ProductCode=MSC&msclkid=9f2599a2e8e413e01f43c789f60203a1&utm_source=bing&utm_medium=cpc&utm_campaign=ECI - Google Shopping - All Products (existing) [Priority%3A Low]&utm_term=4582764467485901&utm_content=All Products (existing) instead of a belt loop, why not use a suspender clip. if you use a loop, then it is the hassle of threading the belt, if you use the fastner on the loop like you have. it may or may not break the loop these clips will attach anywhere.i am thinking of making a shoulder rig using webbing that stretches for a tighter fit -
distressing
Frodo posted a topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
I am working on a method to distress leather to look old.. i think i am pretty close, so i wanted to ask the forums opinion tell you what i did. and get some fed back. first, i used a sponge sideways to [black] dye the side edge of the leather and to let a little on the top then i rubbed the dye on cardbord to dry the sponge out. then i rubbed the dryed out sponge onto the leather next i used a cloth and rubbed brown dye over the black dye then with a clean cloth rubbed finish over it does this look like an old wore out piece of leather in need of some tlc ? -
This could be for spreading glue/mastic, possible tile setter? we use a trowel with notches very similar
