caressofsteel
Profile Information
Location
Raleigh NC
LW Info
Leatherwork Specialty
Holsters
Interested in learning about
Holster Business
Recent Profile Visitors
The recent visitors block is disabled and is not being shown to other users.
caressofsteel's Achievements
Member (2/4)
How To Find Gusset Length On Bag.
caressofsteel replied to DavidL's topic in Leatherwork Conversation
Similar to TinkerTailor, I do not make the edge length equal, make the stitch lengths equal. One way to do this is count the stitch holes on the front and then make an equal number of holes on the gusset. I use CAD software that calculates the stitch length for me but you can do this on a calculator, or measure the stitch length off a pattern. -
is there a leather close to Cordovan Shell?
caressofsteel replied to ToddW's topic in Leatherwork Conversation
Rocky Mountain Leather sells a "cordovan calf" which is cowhide finished like shell cordovan. I have not used it so I cannot speak to how close it comes to cordovan. https://www.rmleathersupply.com/products/copy-of-cordovan-calf-luxury-calfskin-leather-finished-like-shell-cordovan-hides?_pos=2&_sid=a89a1cc88&_ss=r -
Have you tried nylon thread? I have not personally tried to dye it, but nylon thread is supposed to be terribly difficult to dye. I have seen other people's projects where the leather is stitched with white nylon thread and then dipped dyed black. The thread stays white. Seems you could test this on some scraps to see if it would be a possible solution.
Design software for pattern making?
caressofsteel replied to Queipo37's topic in Leatherwork Conversation
Quickcad. It is free if you do not use the proprietary dll files. There is a learning curve but I used to use AutoCAD for work so I picked it up quick. -
Beautiful. Do not show these to my wife... Also in NC.
I have used Tandy Ecoweld and Aqualim315. Aqualim is a little thicker and better at holding the corners down but takes longer to dry. I have started either beveling corners or rounding them (3mm radius) because white glues are not as good at keeping the very tip down as barge. For the rest of the project, no issues. I have found that a 30CC squeeze bottle with a needle tip helps me get the glue to the edge of the leather without it going over or making a mess. This is one advantage of water based glues.
Hunting knife sheath
caressofsteel replied to riy's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Nice. You may want to use a french skiver on the main edges and a thinner welt; so you are not punching the holes through so much leather. Might help them go through straighter. The stitching on the front of the sheath looks great. -
I want to make a heavy duty briefcase eventually. So I made a purse for my wife as a practice piece. The design comes from Nigel Armitages's Leathercraft book. I liked the idea of making a gussetless bag. The leather is Wicket and Craig English Bridle 6oz leather with a 4oz purple suede lining. The side tabs, newspaper pocket, inside pocket and pencil pocket are all 4oz English bridle leather. The stitching holes were punched with flat (straight line) pricking irons. Angled holes would have probably looked better, but I do not reverse pricking irons for the backside. On a gussetless design, the holes have to be punched before the front and back are joined. Also, straight holes are a little more forgiving if they do not line up exactly. I used 0.6 tiger thread to sew it. And sewing the curved portions while trying to keep the holes lined up was a bear. If I had it to do over again, I would have skived the edges of the suede before stitching. The white center of the suede shows through on the edging. Also, 10oz is pretty thick for a purse. I had to skive, and re-skive, and hammer the turn buckle slot down so I could attach it. 4oz leather with 4oz suede would have worked better. Future project will include gussets. I liked the challenge of making a bag from only two pieces of leather, but I think it would be easier to design and make a bag with gussets.
The holes look large to me, but I hand stitch so I can get away with smaller holes as hand stitching does not loop inside the stitch hole. Round holes always look larger than needed anyway. Do you have a diamond needle? Also, it is rare for a pocket holster to have a reinforcement band unless it is meant for a jacket pocket rather than a pants pocket. COS
Threads for holsters, sheaths, pouches, etc.
caressofsteel replied to rodneyv's topic in Leatherwork Conversation
I have used bonded nylon and Tiger thread for hand stitching. The advantages to nylon thread are slightly more tensile strength per strand, abrasion resistance, and as far as I can tell, it is used in almost all commercial holsters. Tiger thread is polyester and expensive because it is braided. If fishing line is any indication, braided thread should be about 3 times stronger that twisted thread. Also, braided thread will lie flatter than twisted thread, so that should help with abrasion resistance. And if you are hand sewing, you are probably not using enough that cost is a huge issue (still an issue though). So that leaves the only advantage of nylon thread is that it is the de facto choice. My thinking is that if you deviate from the norms, you need to be able to explain why you are doing so. With tiger thread, that is not hard: its braided, it lies flat, it is impervious to sunlight. As a side note, I remember one short lived holster company that advertised that they used left hand twist nylon thread. They said it was plainly better than right hand twist thread, but offered no explanation as to why. They went out of business before I or anyone could figure out why that would even make a difference. COS -
I have made watch straps from 4oz vegetable tanned leather from Tandy, and 5oz Chromexcel from Buckleguy. Both worked out well. I have no complaints when purchasing from Springfield, but I have not bought a $30 side from them. I believe they will sell some leather by the square foot if you want to start small. I would recommend checking out Buckleguy.com as they seem to have the best selection of hardware for watchbands. They also sell small panels of leather. The good news is you can probably go for lower grade leather and work around the imperfections (since watchbands are relatively small). Finally, pick a style you like and start crafting. It won't be perfect, but if you like what you made, you will be motivated to improve it on the next go around.
Free watch strap templates (A4 + Letter size)
caressofsteel replied to Danne's topic in Patterns and Templates
Thanks! -
I use LibreCAD for my templates. Although I don't use it; it has a built in dimensioning tool. It is free and open source. Online documentation seems to be pretty good, although I only use it for 2D templates.
