327fed
Everything posted by 327fed
Yes that is 0.030 inch. Thanks.
.030 waxed thread. I have the awls and the chisels. Just not motivated. If not for a good friend I would say forget it.
I hate to hand sew but I have some work my Consew 225 won’t handle. I need to sew 2 layers of veg tan, 10-11 oz plus a thin pigskin liner. All I have and can seem to find is what they call “doll needles”. These come as a set of 3 or 4 sizes of 2 each, most too small, plus a curved set. I would like to find an online source that would have a pack the same size. Thanks.
Wal Mart has 2 sizes of these table/bed lift kits. Really solid for hand work but I have seen them broken with beds, etc. Handy to put away and fold the table.
Would need that long embroidered Porter Wagoner coat to cover that for concealed carry. Great idea.
I have been putting some pigskin lining in some holsters. I cut the lining bigger, glue it and then trim. I always end up with a ragged edge on the lining., especially after edge burnishig. On straight places I can use a fabric circle knofe, but the rest looks bad. Suggestions?
This only stinks when you are working it wet. The NFO and Mop and Glo covers it up pretty welll.
I got a couple of imported veg tanned sides a year or so back (really all I could get) that came from Venezuela I believe. When I wet them to form or stamp the leather smells distinctly like cow manure. Surely the extended tanning process washes any off the hide. Is there a tanning process that uses manure as an ingredient? I have washed my hands half a dozen times this afternoon and still smell it. I have lots of direct first hand contact with cow manure and this is for sure the odor. re
Scholdfield45
327fed replied to Scholdfield45's topic in Gun Holsters, Rifle Slings and Knife Sheathes
https://leatherworker.net/forum/applications/core/interface/file/attachment.php?id=131472 -
Butt cuffs with and without cartridge loops.
It is the last post in the thread below. Shows up for me. r on the side. This is difficult for me.
Yes, I posted this question over on "computer help" and never got a response : What is the 1.5 MB max? Per post, hour, or day? I posted a 500 MB photo in one post, then tried a 1 MB in the next post, it denied the second. I shrunk the 2nd so that it was below 1 MB and it went. If I wait an hour can I post pics again? I have taken pics with my ipad and they are too large. I have taken pics with my phone and they are too large. I now take pics with an ancient Canon camera and sometimes they go, sometimes not. I realize there is software that shrinks pics, I dont have it. Sometimes I am able to shrink files with my Canon Camera to under the 1.5 MB and still cant post. Sometimes I try to post 2 pics in the same post, the total of both don't exceed 1.5 mb. and they don't post. Sometimes I try to post 2 pics neither exceeding 1.5 mb, and I cant post them in consecutive posts. I know this is off topic here but thats why I asked it March 9 in Computer Help section and got no help. I am not a computer professional that does leather on the side. This is difficult for me.
We don’t have Menards around here. Sounds like a good place though.
I bought 5 sheets of this black plastic sheet, 1/4 x 4 ft x 8 ft and a couple 5 ft x 10 ft. Was thinking of making a cutting table from it. System wont let me post the 2nd picture . Is this HDPE? Wish it was white.
The smallest one Harbor Freight sells now is a 12 ton floor model. Cheap enough but overkill. Dont know where you are located but I have seen several hydraulic and arbor presses on Facebook Marketplace lately. Seems like arbor presses are higher than hydraulic ones.
https://www.hobby-machinist.com/threads/small-bench-top-hydraulic-press-10-ton-x-8.95311/ Here is a shop made press with a Porta Power cylinder to press. I would probably get the tiniest Harbor Freight bottle jack, make a little carriage with a spring, extend the press frame to allow the Jack to fit inside the press. I will send a pic of my monster press later for example.
I just put a piece of 2 x 6 under the work, use a stamping pad under the leather (not sure what these are, black rubber that cushions the stamp and work) and a small steel plate laying on top of the stamp to spread the pressure out as the press has a 1 inch arbor that does the pressing. I use a steel plate with the arbor press too on the larger stamps. For the larger stamps and especially the nylon/deldrin/3d printed ones you need to have this. You really don't need to use the whole force of the press or you will deform the leather piece or break the stamp. Just barely get it tight. That is hard for me to do as I am used to doing metal work where you use all the force of the press. You could make a hydraulic one with a bottle jack and some channel if you have a drill press and a welder. Used to be some plans floating around, probably a table top one would be better for a leather shop, although mine is free standing.
I have an imported arbor press. I assume it is a 2 ton as it has a "2: on it. I wet coasters and stamp them with a 2.75 inch brass stamp. It presses it fine. I have a bracket I hook it into the wall (sitting on the floor) and sometimes use a cheater pipe depending on my mood and how weak I feel that day. I have a 6 ton hydraulic I use too and it does it barely trying.
How bout a go cart throttle cable? Build a pedal or buy a go cart one. https://www.amazon.com/DKiigame-Throttle-Cable-Manco-8252-1390/dp/B074WB4271/ref=asc_df_B074WB4271/?tag=hyprod-20&linkCode=df0&hvadid=312034016842&hvpos=&hvnetw=g&hvrand=10716392868253116165&hvpone=&hvptwo=&hvqmt=&hvdev=t&hvdvcmdl=&hvlocint=&hvlocphy=9013241&hvtargid=pla-571772624617&psc=1
I was fitting my friend Hugh for a shoulder holster for his Colt Woodsman and he gave me some terrific sourdough bread this week.
You will have 70 degrees and 40 percent humidity when we are at 105 and 80%.
