Leescustomleather
Everything posted by Leescustomleather
knife sheath Custom Knife sheath
Leescustomleather replied to YinTx's topic in Gun Holsters, Rifle Slings and Knife Sheathes
My main goal in this construction was to have a sheath that the knife blade fit snugly, for positive retainment and also, I really like the way it feels. -
This is just a mock-up but I think you can get the idea, it also minimizes contact of the knife handle with the beltloop -
When accommodating a guard that large I will make the belt loop a separate piece, and then make a spacer from a couple of thicknesses of 9-10 oz Vegtan with the beltloop as the outer most piece and attach it that way. Love your work!!! -
I put down some smooth soft wood like fir or pine and move it with the leather -
If you have a drill press you can mount an awl blade in it with the motor off and use the leverage provided by the press to easily push the awl through, and as an added bonus it will go through perfectly straight. A little bees wax on the awl will make it easier to remove. I am a Bladesmith and have to pierce three layers of between 8 to 10 oz vegtan on a regular basis. -
stitching chisel tooth spacing uneven??
Leescustomleather replied to thekid77's topic in How Do I Do That?
The chisel has 10 tines not nine that is your problem -
I would line the jaws with some Vegtan to protect your work
not leather Olivewood and resin neck knife
Leescustomleather replied to Leescustomleather's topic in Leatherwork Conversation
Olivewood is quite dense and hard, so full stabilization isn't needed. Redwood burl is soft and can absorb moisture so to be used for knife scales really requires treatment, and thanks. -
Thank you , I keep trying to improve my work. -
Thanks -
Leescustomleather posted a topic in Leatherwork Conversation
A little knife I finished today and liked how it came out. I hope this is ok to share, I am still pretty new. -
Help with choosing a conditioner
Leescustomleather replied to captain's topic in Leatherwork Conversation
If you really want to use a particular product buy some and try it in a spot that will be inconspicuous. I just checked my tin of saddle soap, and it says it cleans and renews leather furniture on the back. Not for suede. -
Good for you -
I think you can't go wrong with Feibing's saddle soap. Both clean and condition your leather at the same time -
Hunting knife sheath
Leescustomleather replied to riy's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Nice knife, nice sheath! I struggled with getting my hole through the welt square to the edge also. I mounted a sewing awl blade in my drill press with the motor off and used the lever action of the drill press to easily push the awl blade through perpendicular to the edge, A little beeswax on the awl blade will help it to pull back out. Also, much easier on my hands too. -
Thanks this is a scrap from an old saw blade, An unused plumbing fitting and a dead branch
First Fixed blade sheath
Leescustomleather replied to Bert03241's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Nice job, very clean. -
Where do I find this glue for wallet construction?
Leescustomleather replied to xlr8tn's topic in How Do I Do That?
You might want to check Goods Japan Website -
Swivel knife recommendations?
Leescustomleather replied to AdamDavis's topic in Floral and Sheridan Carving
Check out these, he is on Etsy LeatherStampsTools He has a lot of top-of-the-line tools, I own quite a few of them but have yet to spring for a swivel knife body. I realize that my comment is not very helpful but if you go look, I bet you will enjoy seeing what he has to offer. He is also a sponsor on this site -
Edge paint and use a 1/8" metal rod to apply it. I use brass dip it into the paint and then rub/slide it along the edge. I will give you very fine control of where the paint goes. I know it sounds wierd, I learned it from A Japanese leather smith but I couldn't read his name
I'm glad you found the solution, thanks for sharing!
- 15 replies
- plough gauge
- strap cutter
(and 1 more)
