Everything posted by AlZilla
A few years back I needed to slow my 80+ year old drill press down to mill out some AR lowers. Sparing you the details of why, I replaced the existing motor with a 1.5HP treadmill motor and just screwed the control panel from the treadmill to the wall next to my drill press. It works great. The only bugaboo is it starts and stops slow, because you really don't want your treadmill to go from 0 to 100 or 100 to zero in the blink of an eye. Here's an instructable where the guy has adapted these motors to all sorts of things, including a sewing machine. See Step 11. https://www.instructables.com/Use-a-Treadmill-DC-Drive-Motor-and-PWM-Speed-Contr/ Thoughts? Comments? Anyone done it?? Treadmills can be found for free or dirt cheap.
@toxo, I see what you're thinking. Holsters can go either way, flat on the back, or not, depending on the design. Usually when I make an IWB holster, I stitch it up and wet form it in a vacuum so it's fitted on both sides. Some designs definitely have a flat back.
Gotcha. I can't understand that either, then.
That's not what he's saying. In the 10th post down, OP says "Dye, Cut, Stitch, Mold, Finish. " He'd like to dye after stitching and molding but doesn't want to muck up his contrasting thread color.
Quite interesting, thank you! It's further away than I thought (150 miles) and priced at $250 so I don't think I'll be chasing it. I've been wanting a chainstitch machine but this probably isn't the one.
This is listed for sale near me and I can't figure out what it is. I suspect it's not worth me pursuing but who knows. It seems to have an internal motor and an oil pan so it's obviously meant to work hard. Just don't know what it is, but somebody here will. [it seems to lack a tension arm?] The seller says "Singer Sewing Machine commercial grade for Sails,Leather, seat cushions this is a work horse."
Swapping clutch motor to servo motor, please assist
AlZilla replied to Ana1234's topic in Leather Sewing Machines
Well, especially with my 3.5" hand wheel, which I laid a ruler across and eyeballed. I thought 57 vs 52 was pretty close. Any of those pulleys could be slightly off exact claimed spec. These are really not precision parts we're playing with. I think with all the data in this thread, anybody could get a very close estimate with high confidence. -
I went to the pulley calculator and entered in my setup on the 2 set calculator. At 200 rpms it says I should have 57 rpms at the hand wheel. I counted 52, so close enough. Then I raised the motor speed to 5000 on the calculator and it says I should have 1429 rpms. I'd be pretty confident in 1400 or so top speed, based on that. There's a real world data point for you. -
@Ana1234. if you have any level of mechanical expertise (as in you can change the oil in your car or hang a picture straight), swapping out a motor will be easy. As stated, the weight of that old clutch motor is probably the biggest issue. You'll have to locate where the speed reducer will sit and drill the holes. Belts are always my bane on something like this No matter how much I measure, I always seem to miss it by a half inch and make another trip to the store ... -
Charted Differences Between Singer 111w, 152, 153, 154, 155
AlZilla replied to cynthiab's topic in Leather Sewing Machines
Well, THAT was a lot of work for somebody. Thanks! -
Reading back through here, it seems like you want very precise control of your stitches, as did I for leather work. I was in your rabbit hole not so long ago. Went to the servo with a small pulley. I wanted more reduction so I added this: https://www.ebay.com/itm/164574739671 I understand you're not in the US, but you should be able to find one like it. This is a 3:1 reducer - a 6" pulley to a 2". My handwheel pulley is about 3.5" and I counted 26 stitches in 30 seconds. My servo bottoms out at 200 RPMS, even though it's advertised as 0 - 5000. All this is on a Singer 111w153, so along the lines of what you're looking at. Has anyone mentioned https://www.blocklayer.com/pulley-belteng ? Now, there's a rabbit hole. Honestly, just do both at the same time. You have to remove the machine head and flip the table up twice if you do one and then the other. -
For what it's worth, I have 2 machines with servos and speed reducers. I can land the needle anywhere I want, in any position. Never tried a positioner but I think I like it to stop where I stop it. -
The tan wallet with that nice rolled under edge is by far nicer than the raw edge on the green one. Especially that inside corner where it's all scrunched up on the green one.
That is quite a document. I'm going to spend some quality time with it this week, for sure. Thank you.
That is some really nice looking work. It must be quite satisfying. I *think* I recall you saying you hand stitched. I'm curious how long it takes to make one of these and wondering if you cut the straps as needed, have a bunch of lengths precut or maybe just order lengths of strap. Also curious if you're working with pre dyed leather or dyeing it as needed. Lots of questions, I know ... Thanks
Makarov Holster with Carved Oak Leave and Bound Edge
AlZilla replied to Littlef's topic in Show Off!!
Well, I'm late to the party, but very nice work. The edge binding, the welt, all make a nice looking holster. Mostly, I haven't seen or heard of prototyping in foam sheet. I have got to try that out. I bet it's a much better stand in for leather than poster board. Oh, and the oak leaves are worthy of envy, too ... -
I've gotten quite a few accessories from Chinese vendors, including presser feet for my 111w, and been generally satisfied. I think part of the key is the specific vendor. Most of my purchases have been through amazon or ebay and the seller has been either Cutex or CKPSMS. Yeah, I'd pay more for a good quality US manufacturer, but as you say it's usually not an option.
My favorite method for many things ...
Absolutely, I intended no criticism. The scene itself is quite nice. Just trying to understand. The whole laser thing is on my backburner as maybe a way to mark or cut out patterns.
Curious how deep this laser engraving runs? Is it detectable to the touch? Or is it just flat? I don't care for laser engraving on firearm because it just seems like flat, lifeless Paint By Numbers. Maybe laser engraving on leather could be further tooled?
Singer 111W Tight/Stuck Stitch Length Wheel
Yep, that's how I'd count them. The first hole would be zero, basically. Now you know it's dialing all the way back. As for why it's hanging in the other direction ... I haven't a clue, sorry. The Sewing Machine Sages here will have to sort it out. If it were me, I'd start by looking at the chain of things that happen when you're adjusting the length. There's got to be a burr or some roughness in whatever it is that adjusts the stitch length. -
@cynthiab Have you set it to the max stitch length and counted the stitches? Maybe you're getting 5 but the indicator doesn't go all the way. That's the case with my 111w153. You could just run a few inches in paper or cardboard without thread. Locking up on the other end, I have no idea. -
Light weight press for making stitching holes quickly
AlZilla replied to SteveOz's topic in Leather Sewing Machines
That is a great idea. I think I'll use it but I'll have to look for a used drill press since the one in my shop tends to be covered in oil most of the time. I can see it being very useful. -
That is a beautiful edge finish. Thanks for sharing it.
Yeah, be real careful about taking their temperature. I lost a little pal a few years ago and I really, really wouldn't want a reminder of that loss. I've cried more over that little guy than any human being I've ever lost. I still do.
