Mablung
Everything posted by Mablung
…giving it a considerable advantage, as far as pleasantness to use, over Barge and Tanner’s Bond. May have to try that stuff out once I run low on Tanner’s Bond.
- 22 replies
- rubber to leather
- glue
(and 1 more)
EDC Tool belt pattern or template?
Mablung replied to AtomicLeathers's topic in Patterns and Templates
What happened with your first belt pouch? That might give you an idea for how to adjust your next pattern and make one for the belt rig you showed. That one doesn’t appear to be wet-molded, or at least not to a significant degree, so it would be reasonably simple to figure out the dimensions, based on the diameter/width and thickness of your tools and the thickness of the leather plus stitch lines plus belt loops. Might take a few tries and a few hacked-up pieces of craft foam, but you could make a pattern for that. -
Huh. I may need to give another thought to whether I dismiss that technique. I'll try it when I have time and take a look at whatever knife edge I choose with my jeweler's loupe. (Used to use the thing all the time when sharpening blades, but I've gotten out of the habit.)
Go for it, and please share your results. You may very well prove me wrong. I’m interested because I use Arkansas stones regularly, and cleaning them up and periodically washing them with soapy water starts to get a little old.
You’ll clog it up if you do that. Something other than oil can be used, but a very light oil is best.
Hm, sounds promising. That technique might have more currency than I thought.
Books, Journals, and Photo Albums Went and found the link.
As I like to say, "Whatever floats your goat"—and if that's using the pull method, go for it. I've tried it a bit and found it interesting. It does upend a bit of the other prevalent advice about checking for the burr, etc., or at least it seems to me that it does, so that will take some readjusting. I could be wrong about that, though, so test it out and see what works for you.
Glad to be of assistance! As a matter of fact, I've been thinking about how to make something like this for my wife, as her Bible binding is starting to come apart and she wants a new carrier to replace her old textile one. Haven't gotten into the design yet, so I'll be interested to see what you produce. ETA: One of the subforums has a section about books, journal covers, and similar items. There are a ton of threads discussing Bible covers; they'll have some really good information that would help you in all aspects.
He says that, but I don’t think that’s true of necessity. I’ve gotten some frighteningly sharp edges by pushing the edge forward. He also does by pulling it backward. Just be consistent and you’ll be fine. German bladesmiths used to sharpen straight razors with a circular motion; done properly, it works. Denny’s argument has some truth to it, but it’s not the definitive guide to sharpening.
Are you asking which one (hard vs. soft) will be easiest to put into a leather cover? Hard is usually easier to put into something—less give that will crinkle inside the cover flaps. It is also thicker, though, so you'll have to account for that when measuring and constructing the cover.
Are you talking about something similar to the jigs sold for sharpening swivel knife blades, or something else?
Sounds like my tutorial on sharpening is entirely superfluous for you, then, lol. You’ve definitely got sharpening straight and have been doing it much, much longer than I have. And you have the right touch to sharpen it like that. If you can sharpen your round knife that well, then you’ll have no trouble With getting your trim knife that sharp, with a little bit of adjustment technique. My birthday is coming up, so I think I will get my wife to get me a better round knife. Was thinking of one of the CS Osborne ones that still seems decent.
I forgot, in writing my comments, that you mentioned you had been going in circles. That is a legitimate technique to use, although personally, I find it extremely difficult to keep the proper angle if I do that. So I don’t use the circular technique, but you can. I will say that I think Techniques big tip, especially difficult to keep the proper angle with round knives in particular. I have used it in working on setting the bevel on my round knife because I wanted to send it out from the factory, secondary bevel, but it is harder to get the edge right if one does that throughout.
Yep. If you're sharpening Side A and thus raising a burr on Side B, you then just do the same thing to Side B that you did to Side A—except this time, you're reducing the burr back down to the bevel so that the bevel is even again on both sides. In the process you have evened out the edge, making the steel uniform. That's essentially all sharpening is. That said, there is always a little bit of burr left on the very end of the edge, if you're doing your job properly. You polish that down with the later stones (and there are some more advanced techniques meant specifically to get rid of as much burr as possible to produce the smoothest cutting edge—I haven't tried them because I just learned about them). So if you sharpen Side A by sliding it along the stone as though you're trying to cut off a sliver of the stone, then you do the same thing to Side B until the burr has been removed. Then do the same on the next stone up.
Then you've got what you need already, including the procedure (just gotta call it to mind!). If you're used to sharpening your round knife, you'll just have to make a few adjustments to your grip and angle when sharpening the trim knife. I have to work myself back through the angle and approach whenever I change the style of knife I'm sharpening.
The edge of that trim knife looks like it has a consistent bevel, as best as I can tell. But it’s not nearly as sharp as it could be, which I can tell from how dully the bevel reflects light. Even the body of the blade behind the bevel reflects more. You need to work that blade up through some finer stones and strop it well. A knife truly sharp enough for leather work will glide through the leather—that is, the blade is FRIGHTENINGLY sharp. Watch the video in one thread in the sharpening forum about sharpening the round knife. Great explanation of the technique. At the end, the guy demonstrates the edge of his knife on some 10 oz. veg tan saddle skirting—the knife slides through like the leather is butter.
https://leatherworker.net/forum/forum/221-sharpen-it/ Link above. Obviously you’re not totally new to sharpening, if you know to feel for the burr. I will say, though, you’re wasting effort and possibly causing angle changes just through natural human inconsistency by raising a burr a second time. The general wisdom is that once you’ve raised the burr on one side and then cleaned it off so that both sides of the bevel are even, you’ve maxed out how sharp you’ll make the knife at that grit level. Then it’s time to move up to the next stone up, in whatever set you’re using. (Since you said you’re using a “coarse” stone, I’ll assume you’re using an oil stone of some species or a waterstone around the 800–1000 grit mark.) Each successive burr-remove-burr again cycle just removes more metal but does not refine the edge further. The next stone up will refine the edge by taking off finer bits of metal, on up to polishing stones and stropping doing exactly that, polishing and smoothing the edge. While still honing the blade, keep doing the burr-remove cycle, but pay attention to the consistency of each bevel. Keep the angle right and keep the pressure consistent. Raise the burr on one side, uniformly across the edge, then remove it uniformly. Then check the edge again to make sure all is consistent, then move on to the next stone. After working through your stones, polish on the strop. Use jeweler’s rouge, then green buffing compound, then leather without any compound (if you want—lots of people stop with green and get a wonderful finish on the edge that way). If you have done your job patiently, you should have a mirror-polished edge. That takes time, patience, attention, patience, elbow grease, patience, practice, and patience. It can be especially challenging with a round knife, because the geometry requires the blade be sharpened in portions, rather than the whole edge at once. (Or at least, you will likely find it much easier starting out by doing portions—trying to sweep the whole edge across the stone consistently in every respect with every stroke is extremely difficult to get right.)
The heat treat of my Al Stohlman head knife isn’t great, so sharpening can be a chore. Stick to it, though, being exceedingly careful with the edge angle and working the burr carefully, and they’ll sharpen up adequately. It’ll just take some time and patience. I think the steel is D2, which is relatively hard. You would probably find the discussion of knife sharpening under the Sharpening forum helpful. Lots of good videos and tips.
That sounds a bit like a step in the carbon infusion process for creating Wootz steel, described in another thread about round knives. That's interesting.
Ah, I must have missed that this was for a customer. Hey, if he wants it and is willing to fork over the dough, you make it. Agreed it's a lot for a .45 ACP. I enjoy the round but wouldn't want to carry that behemoth. I'd almost want it dropped into a crossdraw position along the left side, like a sword baldric. That would make the draw easier, far more like drawing a short sword than a pistol. That draw technique would create some problems of its own, but it'd be a bit easier than the chest draw. Hm. Interesting.
Holy crap. What’s the draw like from that rig? One heck of a draw length. I like the setup, though.
I haven’t used it as a resist specifically but have used it a little bit as a finish coat. It’s already fairly thin and dried very rapidly, without leaving residue. The sheath I used it on just looks like it had some extra gloss added to the color, but it seems to resist water well nonetheless. I would guess, therefore, that it doesn’t need to be diluted, but I haven’t tried specifically yet. Do follow up with your results.
Well, I can’t blame you for the eBay one disappearing, then, as that was the only one in that price range I found. Wasn’t willing to pay the price asked for a few others I found. Anyway, I also like shoes, especially the kind that fit well and don’t cause joint misalignment. And bonus points if I can say I made them myself.
Oh, it really is easy. I didn’t make the pattern from scratch, but adapting one was simple. So you’re the one who swiped the cheap copies I found! Man, I had internet issues and missed getting one. Lol. Anywho, these things are not hard to make at all. Go for it! Glad I motivated you to try. Thank you! They are very comfortable. The next iteration will be even better.
