Members Hairic Posted August 2, 2022 Members Report Posted August 2, 2022 Hello again all! Just wondering if anyone has any decent recommendations on a cheaper sewing machine that will do basically what my techsew 5100 will not do, and that's the thinner leather, I need to be able to sew some super thin leather at times and the 5100 is to aggressive in my opinion for like 1-2 oz leather, I really only want to spend like 200 bucks if possible, but I'm wondering if like the singer 4411 would work, if anyone has experience with that kind of stuff would love to hear from you, I need to be able to sew like thin leather wallets, check book wallets, that kind of stuff, and not saying its not possible with the 5100 but I know the turn out would be better with a slightly less aggressive machine. Is a walking foot needed for that kind of stuff? Quote
Northmount Posted August 2, 2022 Report Posted August 2, 2022 @Hairic Moved your post to leather sewing machines. Quote
MtlBiker Posted August 2, 2022 Report Posted August 2, 2022 5 hours ago, Hairic said: Hello again all! Just wondering if anyone has any decent recommendations on a cheaper sewing machine that will do basically what my techsew 5100 will not do, and that's the thinner leather, I need to be able to sew some super thin leather at times and the 5100 is to aggressive in my opinion for like 1-2 oz leather, I really only want to spend like 200 bucks if possible, but I'm wondering if like the singer 4411 would work, if anyone has experience with that kind of stuff would love to hear from you, I need to be able to sew like thin leather wallets, check book wallets, that kind of stuff, and not saying its not possible with the 5100 but I know the turn out would be better with a slightly less aggressive machine. Is a walking foot needed for that kind of stuff? I'm probably not the best to try answering your question, but I've tried to sew thin leather with a domestic machine and failed because the leather is rather uh, sticky, and without a walking foot and needle feed (meaning compound feed) it just didn't work out. And for the $200 budget, you mentioned, it's very unlikely you would find something that meets your needs. But... Have you read about the thing @RockyAussie (do a search under his name) designed for those heavy duty machines to let them much more easily handle thinner assemblies and threads? Might be the solution you're looking for. I don't have time right now to search for the right post by him, but if you can't find it and nobody else jumps in, I'll try to find a link for you tomorrow. Hope this leads to a workable solution for you. Quote Current machines: Janome HD3000 and Skyline S5, Consew 206RB-5, Singer Profinish serger, Techsew 2750 PRO, Sailrite LSZ-1 Premium, Consew DCS-S4 Skiver
Moderator Wizcrafts Posted August 2, 2022 Moderator Report Posted August 2, 2022 See if you can find an old Singer 31-15 and convert it into a roller foot machine. The conversion kits contain 3 parts: A roller foot, a wide single row feed dog, and a matching throat plate. With these parts installed and the machine threaded with either #46 or #69 thread, it will sew wallet interiors with ease. The rollers are usually available in 3/4 and 1 inch diameters. The smaller wheel makes it easier to make sharp turns. The visibility is incredible with the needle coming down right next to the bottom edge of the slanted wheel and no other foot in the way. Note, this setup requires some stiffness in the leather to keep the leather from puckering up with the needle, which can cause skipped stitches. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Contributing Member fredk Posted August 3, 2022 Contributing Member Report Posted August 3, 2022 I've used a Singer 99k with a roller foot attached. No other add-ons or adjustments, Sewed a 2mm leather wallet and will do soft very thin leather Quote Al speling misteaks aer all mi own werk..
Members dikman Posted August 3, 2022 Members Report Posted August 3, 2022 6 hours ago, MtlBiker said: Have you read about the thing @RockyAussie (do a search under his name) designed for those heavy duty machines to let them much more easily handle thinner assemblies and threads? Might be the solution you're looking for. Unlikely to work. The modified plate/feed dog will let a big harness stitcher handle #138 thread, and thinner material, but I doubt if it will suit what the OP wants (plus it would be well outside his budget!). I believe it can go down to #69 thread but getting suitable needles may be an issue. The Singer 4411 is a domestic machine (described by some as a "heavy duty" machine, but this is only because it has a bit of metal framing inside). If you've got one then try it (and good luck) but if you have to buy one then don't waste your money. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
RockyAussie Posted August 3, 2022 Report Posted August 3, 2022 16 hours ago, Hairic said: Hello again all! Just wondering if anyone has any decent recommendations on a cheaper sewing machine that will do basically what my techsew 5100 will not do, and that's the thinner leather, I need to be able to sew some super thin leather at times and the 5100 is to aggressive in my opinion for like 1-2 oz leather, I really only want to spend like 200 bucks if possible, but I'm wondering if like the singer 4411 would work, if anyone has experience with that kind of stuff would love to hear from you, I need to be able to sew like thin leather wallets, check book wallets, that kind of stuff, and not saying its not possible with the 5100 but I know the turn out would be better with a slightly less aggressive machine. Is a walking foot needed for that kind of stuff? This is the post mentioned above that may be what you are looking for. You can see in it that you can get down to around 4 oz total thickness but with your machine the smallest leather point needle is a 160 - 23 and that means the 138 (20m) thread is about it. Cost of the narrow needle plate set with delivery into the USA is $110 US. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Contributing Member fredk Posted August 4, 2022 Contributing Member Report Posted August 4, 2022 On 8/2/2022 at 6:55 PM, Hairic said: Hello again all! Just wondering if anyone has any decent recommendations on a cheaper sewing machine that will do basically what my techsew 5100 will not do, and that's the thinner leather, I need to be able to sew some super thin leather at times and the 5100 is to aggressive in my opinion for like 1-2 oz leather, I really only want to spend like 200 bucks if possible, but I'm wondering if like the singer 4411 would work, if anyone has experience with that kind of stuff would love to hear from you, I need to be able to sew like thin leather wallets, check book wallets, that kind of stuff, and not saying its not possible with the 5100 but I know the turn out would be better with a slightly less aggressive machine. Is a walking foot needed for that kind of stuff? You don't say where you are but a working 99k can be picked up for as low as £25. About £50 - £80 is average, £125 plus for a serviced one from a s/m dealer. I got a mint, low used, fully serviced one with a 1 year guarantee and 1 year of servicing for about £200 Quote Al speling misteaks aer all mi own werk..
Moderator Wizcrafts Posted August 4, 2022 Moderator Report Posted August 4, 2022 3 minutes ago, fredk said: You don't say where you are but a working 99k can be picked up for as low as £25. About £50 - £80 is average, £125 plus for a serviced one from a s/m dealer. I got a mint, low used, fully serviced one with a 1 year guarantee and 1 year of servicing for about £200 @Hairic- This is why there is a field for your location in your profile. When you ask for help on the forum it helps get more relevant answers if people know your location. Now, you will need to convert fredk's prices from Euros into US Dollars. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Handstitched Posted August 4, 2022 Members Report Posted August 4, 2022 I have a 'Pfaff 60' . It's a domestic machine, compound feed, but happily sews thin leather quite well ( Schmetz leather needle) . I use it for kangaroo leather ,wallets, wallet inners etc. If you can find a similar machine , like what @Wizcrafts & @fredk mentioned? Its quite handy to have more than one machine in some instances. HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
