Members EmilHandmadeKnives Posted August 30, 2022 Members Report Posted August 30, 2022 Hello folks! I'm so happy I found your forum. My name is Emil, I'm a knifemaker located in Poland. I started making knives and leather sheaths about 6 years ago, however I'm a bit tired of hand sewing. Usually I am using veg tan leather 3-4 mm per layer, and sewing mostly 3-4 layers. It gives me about 10 mm - 15 mm material, that I have to stitch. 15 mm is extreme for me, most of my sheaths are between 9-12 mm thick ( about 1/2"). All the time I'm using 1mm waxed slam thread. I decided to buy my first leather sewing machine, just for sewing my sheaths. It's still small part of my work, but really time consuming. Last 10 days was making research, and I'm getting crazy As I am located in Europe it's not easy to get second hand Cobra or Cowboy, it's world of Adler, Claes, Singer, Minerva etc... My budget is limited to about 1000 EUR / USD. I found that perfect machine for my use should be Juki 441 or Adler 205, however these machines are too expensive for me. I also found some other interesting models, but I'm not sure if they are "strong" enough to deal with my leather goodies: - Adler 269-373 - Claes 214 - Adler 105 And now I have question to you. What do you think about machines from the list above? Could you suggest me something else that won't ruin my budget? I just want to mention that I have good service of heavy machines in my neighborhood, and they can help me with some modifications or repairs. Best regards, Emil Quote
kgg Posted August 30, 2022 Report Posted August 30, 2022 1 hour ago, EmilHandmadeKnives said: My budget is limited to about 1000 EUR Another option I would put into the 441 class that you may want to investigate importing is a new manual sewing machines like the Tippmann Boss, Cowboy Outlaw or the Weaver Cub. These will handle the thickness that you are looking to sew. Not the Chinese Patcher aka the Tinkers Delight. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
PastorBob Posted August 30, 2022 Report Posted August 30, 2022 1 hour ago, EmilHandmadeKnives said: My name is Emil, I'm a knifemaker located in Poland. I started making knives and leather sheaths about 6 years ago, Welcome to the forum! What beauties you have made, both knives and sheaths. I like the mottling on those sheaths. Gorgeous! @Wizcrafts can shed some light on your questions. Quote In God's Grace, Pastor Bob "While we were yet sinners, Christ died for us." - Romans 5:8 www.PastorBobLeather.com YouTube Channel
Members Cumberland Highpower Posted August 30, 2022 Members Report Posted August 30, 2022 Some good looking knives. I'm going to be honest, your knives look great. You need an equally superb sheath to match. A hook and awl machine is what you really need for a quality product. Yes, I read your limitations/location/Euros, etc. Europe doesn't seem to be a great place to find harness stitchers either.... the Adler 105 on your list would work for you. Make sure you buy a 105-64 and not some other sub-variant like a 105-25 or 105-5. Dont' get carried away on thread size. Seems like the D point needles sew best on that machine. it throws the same quality stitch as a Juki 441 or Adler 205, etc. Quote
Moderator Wizcrafts Posted August 30, 2022 Moderator Report Posted August 30, 2022 The Adler 105 is a bottom feed only machine. The teeth will leave marks on the bottom that you will either have to try to smooth out, or explain away. Those teeth are required to grip the leather and pull it to space the stitches. The denser and thicker the stack of leather, the higher the foot pressure must be to keep the leather from lifting with the needle. The higher the foot pressure, the deeper the tooth marks on the bottom. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Cumberland Highpower Posted August 30, 2022 Members Report Posted August 30, 2022 (edited) 1 hour ago, Wizcrafts said: The Adler 105 is a bottom feed only machine. The teeth will leave marks on the bottom that you will either have to try to smooth out, or explain away. Those teeth are required to grip the leather and pull it to space the stitches. The denser and thicker the stack of leather, the higher the foot pressure must be to keep the leather from lifting with the needle. The higher the foot pressure, the deeper the tooth marks on the bottom. You're not taking into account sub-classes of the 105 Wiz. The 105-64 is a needle and bottom feed (works great on leather). The 105-5 is a bottom feed only (might be the version youre thinking of). 105-25 is a bottom and foot feed. Ive owned all 3 variants and have a 205-64 at the moment. You can find plates that do away with the lower feed dog if you look, I have one on my 205-64 I bought from the member here on leatherworker UWE. Smooth lower feed dogs are available also. I feel pretty confident the 105-64 would be just what he needs on all that flat leatherwork. Edited August 30, 2022 by Cumberland Highpower Quote
Members Dwight Posted August 31, 2022 Members Report Posted August 31, 2022 I noticed you did not have the Tippmann Boss in your lineup there. It would be a very good first machine for you. It's not only a good machine . . . the manufacturer is really great . . . we've had a 20 + year relationship . . . been nothing but good. It was may first machine . . . making holsters, belts, knife sheaths, even billfolds and other "things". For knife sheaths . . . I wouldn't even think of going any other way . . . it is tough to do belts . . . especially longer ones . . . It is in your price range brand new . . . although I don't have any idea what the shipping would be. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members bladegrinder Posted August 31, 2022 Members Report Posted August 31, 2022 Being a knifemaker, when I started searching out a machine I searched knifemaker forums and it seemed I found quite a few people saying the Tippman boss can be really finicky at times. I read enough that I took it off my list of machines to consider. this is just my opinion but I was researching on and off for a couple years before I bit the bullet and bought a Cowboy 4500. Quote
Members EmilHandmadeKnives Posted August 31, 2022 Author Members Report Posted August 31, 2022 Thank you guys for your comments, finally I found experienced community that shares knowledge. Currently my first choice is Adler 105-64, I will try to find one in good condition. I hope I will be able to find smooth lower feed dog for this machine Tippman Boss is not available in Poland, and purchasing new one from US + taxes + shipping will be too much for such simple machine. Anyway, if someone has anything to add, just don't hesitate. I will appreciate any help, because it's still kind of magic for me. Cheers, Emil. Quote
Members Michiel Posted August 31, 2022 Members Report Posted August 31, 2022 An alternative in the same price class could be the adler 220 its a flatbed but has triple transport. (And is as vintage as the 105-64) An affordable free arm machine with triple transport for heavy thread is difficult to find in europe …. regards, michiel Quote
