PastorBob Posted February 2, 2023 Report Posted February 2, 2023 @Tim Schroeder Thanks for the inspiration on building a tool holder for my stamps, etc. I took 12" long pieces of 2x4 and laminated them together to get 24ish inches wide. I then placed a piece of 1/4" plywood on top and drilled the holes (lots of drilling - nearly 300 holes), then used 3/4" Knotty Alder x 4" around the border. Not real happy with the way the miter edges turned out on the Alder, nor the chipping along the top of the plywood when I ripped it, but it is serviceable. The below video captures the holder as I am loading it with stamps. I think it is sped up by 6 times normal. Quote In God's Grace, Pastor Bob "While we were yet sinners, Christ died for us." - Romans 5:8 www.PastorBobLeather.com YouTube Channel
Members Tugadude Posted February 2, 2023 Members Report Posted February 2, 2023 HOLE-Y cow! That's a lot of holes. Nice way to display them. The ones where they stand up seem to be popular but they have to be more difficult to locate the ones you need. Quote
Members Charley1 Posted February 2, 2023 Members Report Posted February 2, 2023 I make a lot of blocks for holding/storing reloading equipment and tools. I use 3/4 inch red oak, laminated to the thickness I need. Layout the holes, drill them on my drill press using a fence I made. Follow with using a roundover router bit on the edges, then finish with polyurethane. They sell pretty well. Here's a block made for some RCBS Little Dandy powder measure rotors, and a block for die/turret storage for a Lee Classic Turret Press. I've made blocks for leather stamps and tools in the past, guess I need to start making them again. Quote
Members Brokenolmarine Posted February 2, 2023 Members Report Posted February 2, 2023 I made mine with scrap 4x4 fence post and some shelving board. It fits on my bench. I told the wife this past week that it's almost time to make a new one, that will extend the width of the bench so that I can put some L brackets on the ends HOOKED under the end of the workbench to avoid drilling the bench to secure the tall structure. Also, the extra width will provide MORE space for stamps. I'd add a few additional shelves and rethink hammer storage, and add slots for mallets. Quote
Members BlackDragon Posted February 2, 2023 Members Report Posted February 2, 2023 This is my current setup for tooling. I used scrap pieces of wood cut to various sizes for each type of tool. This way I grab just the ones I need from my side table and set them on my worktop. Quote
Members Beanwood Posted February 2, 2023 Members Report Posted February 2, 2023 2 hours ago, Charley1 said: I make a lot of blocks for holding/storing reloading equipment and tools. I use 3/4 inch red oak, laminated to the thickness I need. Layout the holes, drill them on my drill press using a fence I made. Follow with using a roundover router bit on the edges, then finish with polyurethane. They sell pretty well. Here's a block made for some RCBS Little Dandy powder measure rotors, and a block for die/turret storage for a Lee Classic Turret Press. I've made blocks for leather stamps and tools in the past, guess I need to start making them again. That one looks awesome - I've tried similar in the past, and never made them look that good! Quote
Members doubleh Posted February 2, 2023 Members Report Posted February 2, 2023 That is a lot of stamps. I glued some left over two-by stuff together, ran it through the table saw to clean it up, drilled holes in it, and glued a piece of 1/2" plywood to the bottom to close the holes. Then I applied two coats of Min-Wax poly varnish to it and it's held up for many years. Quote
Members DwightT Posted February 2, 2023 Members Report Posted February 2, 2023 My tool rack is similar to @Brokenolmarine's, probably because I copied and adapted his from when he posted it before. It mostly works, but there are some tools that don't have a home on the rack. Maybe I have too many tools? Nah. No such thing as too many tools. Quote
Members Hags Posted February 3, 2023 Members Report Posted February 3, 2023 These are 2 I have come up with. The one for the stamping tools is 2 layers of 1x6 with holes in the top board. The other is a 2$ knife block from goodwill that I drilled to hold various tools I use for punching holes, corners, ect... Quote Not so retired RN. Living on the Washington Peninsula.
Members Brokenolmarine Posted February 3, 2023 Members Report Posted February 3, 2023 Dwight, I like the mod to my design of adding the rod for the lacing and thread for hand sewing. I'll have to add that to mine when I expand the design to cover the width of the workbench, great idea. I'll use a wooden dowel. I think I have several. Very Nice! I'm liable to add TWO 4x4 blocks to the bottom with an inch break between the groups of holes so I can cluster the types of stamps together. Shaders, Basketweaves, Camos, etc. Then slots for the cutters, bevels, etc on the next shelf, and the top few shelves for dyes, paints, etc. Probably summer. Quote
