RockyAussie Posted January 22, 2024 Report Posted January 22, 2024 Sounds good. Thanks for correcting me on the LS 1342 as against the LS 1341. Just check the sump, it should for some reason have a bung which has a washer that can get to leak easily. I checked mine the other day and all of the oil has seeped out. Ruined the edge of the stuck on table strip. Quote
toxo Posted January 22, 2024 Author Report Posted January 22, 2024 On 1/22/2024 at 11:14 AM, RockyAussie said: Sounds good. Thanks for correcting me on the LS 1342 as against the LS 1341. Just check the sump, it should for some reason have a bung which has a washer that can get to leak easily. I checked mine the other day and all of the oil has seeped out. Ruined the edge of the stuck on table strip. Expand Thanks for the heads up re the sump. Don't know why the Juki 1341 doesn't have the hump jumper. Maybe the clones have a higher lift for thicker material? Quote
Members Wepster Posted January 22, 2024 Members Report Posted January 22, 2024 @toxoyou ordered your machine from Alibaba? Might I please have a link to the url you ordered from? I see so many machines on Alibaba. Quote
Members Constabulary Posted January 22, 2024 Members Report Posted January 22, 2024 (edited) On 1/22/2024 at 4:55 AM, RockyAussie said: Main thing of difference is that the top feet feed and needle system on the 1341 has a rectangular setup that allows the stitches to remain evenly spaced whether thick or thin leather is fed through. Expand It sounds quite interesting as it would eliminate the pendulum effect of the needle bar but I´m not sure about this.That would mean the pivot point of the rock frame is NOT on the top side of the rock frame as on almost most other triple feed machines. I think I have to check the 1341 parts list for that.... Edited January 22, 2024 by Constabulary Quote
toxo Posted January 27, 2024 Author Report Posted January 27, 2024 A little bit closer. If one of those Houthi missiles get it I won't be best pleased. Quote
Members dikman Posted January 27, 2024 Members Report Posted January 27, 2024 That's pretty impressive that they're keeping you informed of the progress. Quote
toxo Posted January 27, 2024 Author Report Posted January 27, 2024 On 1/27/2024 at 10:06 PM, dikman said: That's pretty impressive that they're keeping you informed of the progress. Expand That's not the half of it I have a video of everything I've asked for 10.5mm stitch, 3mm stitch, same hole backstitch, speed reducer, slow stitch, fast stitch, and more and pictures. I spoke to her every day on WhatsApp. If only I can figure out how to get the video sizes down I'll show you. I suppose I can put em on YOUTUBE and post the links. The only glitch was a vibration on the first video but because they were dismantling straight after they hadn't tightened the bolts. They did another after sorting the bolts and it was gone. Quote
toxo Posted January 28, 2024 Author Report Posted January 28, 2024 https://youtube.com/shorts/uaZYioWcaXI Quote
