10 minutes ago, AlZilla said:
Don't forget to look at whatever else is on the circuit. A 20 amp, 120 volt circuit handles 2400 watts MAX, but you also allow 20% for overhead so your continuous MAX would be 1920 watts. National Electric Code defines "Continuous" as 3 hours, I think. Double check me if you get close.
Not to insult your intelligence, but in case you or someone else don't know, here are the formulas:
Watts = Amps * Volts
Amps  = Watts / Volts
Volts = Watts / Amps
2400 watts = 20 amps * 120 volts
20 amps = 2400 watts / 120 volts
120 volts = 2400 watts / 20 amps
Nope no insult here. I knew the formula's being a diesel technician. I think I will just run a dedicated 20amp circuit to the sewing machine.
Thanks.
  • Replies 113
  • Created
  • Last Reply
Top Posters In This Topic
I have a class 3, wish I'd bought a 4, but happy none the less. The motor died a few months in, new one free of charge in a few days, running fine for approx 4 years now.
Not so retired RN. Living on the Washington Peninsula.
I did wonder ...
Maybe it'll help someone else one day.
- Voltaire
- Aristotle
Thanks.
I wouldn't spend money to run a dedicated circuit. I run mine on the same circuit as a deep freezer, a mini fridge, a couple of led shop lights and also a Portable air conditioner running sometimes.
I haven't had any problems. your machine isn't going to pull that much.
Ok thanks. Did you mention that earlier in this thread. Or I might have read it in another thread.
Bladegrinder what do you use for sewing machine oil? If you dont mind me asking.
Thanks.
24 minutes ago, AlZilla said:
I did wonder ...
Also I just recently got a ebike & been playing around with the formulas a bit more than usual.
Thanks.
A bottle of oil came with mine, yours should too I would think. I did buy some extra off Amazon, I use it around my shop on all kinds of stuff.
Thanks. I did not know if I should buy some high tech sewing oil or just use what comes with the machine.
11 hours ago, DieselTech said:
All you guys with Cobra class 4 machines, How many bobbins do you all keep with your machine?
Thanks.
I am just a hobbyist and found a 10 pack of extra bobbins was nice to have . I keep 2 each of my popular colors or thread size available , so if you run out or coming close you don't have to stop and go through the winding process. You will need to do some searching to find a reasonable price but I found it was worth a extra dollars. I always have a few if not more empty and  ready to go , so I can do a one off without wasting thread.
