I respectfully disagree. I can pull the toe away from the skirt enough to see the slot cut and the liner behind it. Yes this is one of John's holsters. Heres is a closer look. Rob
Edited by RobP
  • Replies 58
  • Created
  • Last Reply
Top Posters In This Topic
Some great looking holsters guys. Lots of great info in this thread also.
Sure fooled me all to pieces . . . that being the case . . . the holes had to be cut first . . . at least that is how I would do it.
That is one pretty holster . . . are you going to copy it or make one similar??
May God bless,
Dwight
www.dwightsgunleather.com
Hi Dwight. Me trying to copy a John Bianchi holster would be like me trying to copy the Mona Lisa. I may attempt to make something similar in a cross draw in the future. I'm still practicing my tooling and round knife skills. The more I practice the luckier I get. Rob
  • CFM
On 12/31/2020 at 9:00 AM, RobP said:
I would probably glue up the holster and liner but leave the skirt part unglued until i  had the holster to a point where i could get my correct placement and angle of the loop, then cut and form the loop then glue the liner and skirt then sew. Bianchi already had the pattern so he knew where to cut the loop  we never saw his first try lol. I have made one myself, unlined so didn't have to think that hard.
:thumbsup:
5 leather patterns
Thanks guys, that makes perfect sense. Glue up the holster, locate your cut lines for the loop,  flip the skirt liner out of the way then cut your slits for your loop. Flip the skirt back down and mark through your slits/ slots onto the inside of the skirt liner. then glue up to your marks. thanks again, Rob
I really like that approach, it looks very smooth and elegant.
  • 3 months later...
On 12/31/2020 at 12:40 PM, Dwight said:
What you are missing here is that the front is not cut to make a loop.
Another piece of leather is actually added on this holster to give the appearance of a Mexican loop holster . . . but it is of the John Bianchi style . . . two pieces of leather bonded (glued) together make the body of the holster  . . . a third piece is used to go around the holster as a "loop".
That is my favorite western holster to make . . .
May God bless,
Dwight
Hi Dwight, this is more or less what Will Ghormley calls the Lawdog holster.  I made one for practice out of crappy 6-7 ounce leather.  I finished it with Neatsfoot oil and Skidmores after letting it get a tan in the sun for a couple of days.  The holster practically jumps out of the strap when I draw it.  How do you avoid that on this style holster?  If I used Vinegaroon would the extra stiffness make it stay in place?
Thanks
Thanks
Since the holster is done . . . we cannot add good quality veg tan leather . . . which would have stopped that completely.
3 or 4 good coats of 50/50 Resolene / water . . . "might" cure it.  Vinegaroon will not make it substantially stiffer.
Being very careful how and where you put it . . . a small concho (or 2) on the strap should hold it . . . and the strap should be so tight on it that you have to work serious hard to get the holster up thru it.
Honestly never had the problem.
May God bless,
Dwight
