Members Constabulary Posted August 26, 2019 Author Members Report Posted August 26, 2019 On 8/1/2019 at 9:49 AM, Constabulary said: Surprise #4: Damn - there are even hooks for the Golden Wheel 810 / 820 that looks very much like the Singer 111 hook. They have the same needle deflector but no shaft instead they have the same "2 prong mount" as my original 51W hook and the Durkopp hook I´m currently using. So I´ll gave it a try. For less than $10 you can do much wrong. GEH-820 hook Quick update - above mentioned hook has arrived - it fits but the hook tip is touching the needle and I cannot move the hook to the left. So the GEH-820 hook does not really work for my 51WSV2. So back to the Durkopp hook. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members DrmCa Posted August 26, 2019 Members Report Posted August 26, 2019 I miss the Singer gold. Quote Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
Members Constabulary Posted August 27, 2019 Author Members Report Posted August 27, 2019 (edited) 10 hours ago, Constabulary said: Quick update - above mentioned hook has arrived - it fits but the hook tip is touching the needle and I cannot move the hook to the left. So the GEH-820 hook does not really work for my 51WSV2. So back to the Durkopp hook. I meant: cannot move the hook to the right (cannot alter the post) I also have ordered a slide plate / cover for the hook from College Sewing part number is 221215. It also works fro the early 51w model. Original slide plate is a lot nicer because it is full metal and the new one is just stamped sheet metal but it works. I will try fo fit a binder attachment to the new plate (just for playing around a bit). This is the OEM W&W foot and needle bar in comparison with the Singer parts (W&W to the right - Singer to the left). So you can well see where Singer got the idea of the 111w / 107w (f.i.) feet from. Unfortunately they are not interchangeable (screw holes do not line up) so I switched to the Singer NB so now I could use all the 111w needle feed feet and 107w feet. But as mentioned above atm I have installed a NB with roller foot. 9 hours ago, DrmCa said: I miss the Singer gold. I will add a Singer decal when the machine is fully set up. If you mean the floral design - well that's not what I really like. Edited August 27, 2019 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members shoepatcher Posted September 2, 2019 Members Report Posted September 2, 2019 Great job as usual C. Keep it up! glenn Quote
Members Constabulary Posted September 4, 2019 Author Members Report Posted September 4, 2019 Thanks a lot Glenn. Parts update: These screws for the needle plates also work for the early 51W. Stocking a few spare screws can´t be wrong https://www.ebay.de/itm/143152157578 Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Constabulary Posted November 1, 2019 Author Members Report Posted November 1, 2019 (edited) "Decal Update" Thanks to LW member EVO160K who supported me with this nice "special" decal. Actually the letters are vinyl like stickers but very well made with real gold foil (afaik). Looks a bit 3D-ish... Looks a bit different compared with thin water slide decals but I like it especially because of the Font with the long R. Edited November 1, 2019 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Moderator Wizcrafts Posted November 1, 2019 Moderator Report Posted November 1, 2019 I like that decal. Does he market them? Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Constabulary Posted November 1, 2019 Author Members Report Posted November 1, 2019 (edited) Nope! These are prototypes and afaik they will not be for sale. Edited November 1, 2019 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
