alpha2 Posted June 7, 2022 Report Posted June 7, 2022 Rocky, Yes, it's counting up when the power is on. On the airplanes, there always a tach meter that counted when RPMs rose above above a certain point, but the rentals liked to have the timer start when the master switch was turned on, and off when shut down. Got to bill for taxi and run-up time, not just flight time. Quote So much leather...so little time.
Members chrisash Posted June 7, 2022 Members Report Posted June 7, 2022 (edited) In the UK we tend to record Take off to Touch down and charge for that Taxi and engine tests are free. A good benefit when using main airports with long taxiways and runways, Engine hours are for the engine logs and checks Edited June 7, 2022 by chrisash Quote Mi omputer is ot ood at speeling , it's not me
Members BDAZ Posted July 3, 2022 Members Report Posted July 3, 2022 Just installed my n arrow plate and feed dog and will be running it on #92 thread for an order for some narrow woman's and children's belts. I am very pleased with the test stitching. Are there any down sides of leaving the narrow plate in place when switch back to 138 thread with a 23 needle? I can't see why not but welcome comments. Great job on this item!! Well made and easy to install. I was having trouble when I first tested it. I realized I had forgotten to thread the needle!! Bob Quote
Moderator Wizcrafts Posted July 3, 2022 Moderator Report Posted July 3, 2022 21 minutes ago, BDAZ said: Just installed my n arrow plate and feed dog and will be running it on #92 thread for an order for some narrow woman's and children's belts. I am very pleased with the test stitching. Are there any down sides of leaving the narrow plate in place when switch back to 138 thread with a 23 needle? I can't see why not but welcome comments. Great job on this item!! Well made and easy to install. I was having trouble when I first tested it. I realized I had forgotten to thread the needle!! Bob Since I changed over to the Aussie narrow feed dog and throat plate I've left them in. We sew holsters with them just fine using #277 thread. This set should have been a factory option. The real advantage is that narrow straps don't get pushed into the slot like on the standard plate and soft material isn't pushed inside the feed dog as easily. I think that we could use another feed dog that fits in the narrow throat plate, but with a smaller hole that clears a #23 needle, maximum. The other day I needed to use my raised holster plate. The narrow feed dog cleared the bottom with ease. No need to lower it. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members howie696 Posted July 3, 2022 Members Report Posted July 3, 2022 Just wondering how do I purchase a set for the 3200? TIA Quote
RockyAussie Posted July 3, 2022 Author Report Posted July 3, 2022 18 minutes ago, howie696 said: Just wondering how do I purchase a set for the 3200? TIA Just PM me here with your address details and I will get back with the costs and details. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members BDAZ Posted July 6, 2022 Members Report Posted July 6, 2022 On 7/3/2022 at 1:04 PM, Wizcrafts said: Since I changed over to the Aussie narrow feed dog and throat plate I've left them in. We sew holsters with them just fine using #277 thread. This set should have been a factory option. The real advantage is that narrow straps don't get pushed into the slot like on the standard plate and soft material isn't pushed inside the feed dog as easily. I think that we could use another feed dog that fits in the narrow throat plate, but with a smaller hole that clears a #23 needle, maximum. The other day I needed to use my raised holster plate. The narrow feed dog cleared the bottom with ease. No need to lower it. Good news! I usually allow around 1/4" for stitching but now I'm going for 1/8" with the new setup. Works a treat! I have also purchased some 92 thread and 19 needles to expand the work I can take on. I just had a job to replace the canvas strap on an expensive Dooney and Burke shoulder bag with leather. I was able to almost exactly match the stitching with the new setup and the new strap looked OEM. Customer was thrilled! Thanks Rocky!! Quote
Members sbrownn Posted July 6, 2022 Members Report Posted July 6, 2022 On 3/6/2022 at 3:22 AM, RockyAussie said: Looks a bit like my first efforts when I was working out how to make them. I eventually made the needle plate shaped to allow smaller gussets and stuff to run through. As in this pic - Something you can do pretty easy but the dog foot may be a whole other story.....There is not a lot of metal in the web to support this shape and CNC cutting I think you will find will not give you the strength needed to resist the pressure of the foot bending the feed dog down and into the needle plate. This is why we decided to go with the casting and hardening process as the original machine makers have as well. If you stick to the light weight work it may be alright maybe. You can do as Wiz said and use a washer instead IF you can get the right thickness to suit what adjustment is needed. Some machines can go out of adjustment and they can be hard to get every thing back where they should be. With this shim with the slot method the more in and down it goes the more the adjustment plate is angled forward and thus limiting the reverse length stitch to where it may need to be. Depending on the thickness of leather that gets used on a given job the amount that the adjustment plate needs to be angled may differ from a thinner or thicker job and this gives a quick and easy way to do any correction that may be needed. Some Adler machines along this line used an angle iron shape with adjustable pins that allowed you to limit both the forward and reverse stitch lengths. Myself... although my machine does do a good job at reverse stitching I never trust that I am going to get the needle back in the hole exactly where I want it to go so I just lift the foot and go back by hand a few times. If the machine does it it can spear and cut the threads a bit more than I do. Note: most of the stuff I make is out of crocodile and pretty high end so maybe I am over fussy. Excellent reply. Quote
RockyAussie Posted August 18, 2022 Author Report Posted August 18, 2022 On 7/7/2022 at 12:11 AM, BDAZ said: Good news! I usually allow around 1/4" for stitching but now I'm going for 1/8" with the new setup. Works a treat! I have also purchased some 92 thread and 19 needles to expand the work I can take on. I just had a job to replace the canvas strap on an expensive Dooney and Burke shoulder bag with leather. I was able to almost exactly match the stitching with the new setup and the new strap looked OEM. Customer was thrilled! Thanks Rocky!! Thanks for the feedback @BDAZ Thank you as well @sbrownn Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
alpha2 Posted August 21, 2022 Report Posted August 21, 2022 On 8/18/2022 at 5:55 PM, RockyAussie said: Thanks for the feedback @BDAZ Thank you as well @sbrownn SShhhh! Don't tell my wife I can repair her Dooney & Bourke purses! Quote So much leather...so little time.
