Your machine must be modified to use system 190 Pfaff needles. They are 3/16" longer than system 135x17. These needles are good, but bend and break more often if there is anything misaligned between the layers being sewn. If all your work is properly aligned and secured, system 190 needles will allow you to exceed 3/8 inches of thickness sewn. But, since they bend and deflect so easily, make sure that the hook doesn't hit the needles as you sew.
Sometimes I use staples on the edges.
Does This Machine Have A Walking Foot Mechanims?
Wizcrafts replied to TsThorsell's topic in Leather Sewing Machines
Yep, walking foot, probably compound feed (triple feed). -
Why The Need For A Single Row Feed Dog W/ Rollers?
Wizcrafts replied to CustomDoug's topic in Leather Sewing Machines
Right. My bad. The roller occupies a single bottom width of between 1/8 and about 3/16 inches, depending on the size and who cast it. The feed dog can only feed material when there is pressure from the top, via a presser foot. Since the narrow footprint roller is all the pressure on top, it makes sense to use a feeder that lies directly under it, as the other teeth have nothing to work against. However, you can leave in your original feeders if the roller makes good contact with the left-most row. You may or may not get the best feed, depending on the width and aggressiveness of the teeth, and distance to the needle hole from the right edge of the left-most row of teeth. The feeder in a roller foot conversion lies directly next to the hole, allowing you to place the edge of the roller very close to the needle. -
Gifted A Domestic 6 Sewing Machine Can Anyone Help
Wizcrafts replied to SarahW's topic in Leather Sewing Machines
Domestic (home) sewing machines are not designed to sew leather that is thick, dense, or large, or requires thread larger than B69 (T70). It doesn't matter what brand name is on the body. If it has drop feed only, and neither a roller or walking foot drive, it is not going to feed leather properly. The result of trying to sew leather that is beyond the handling/feeding capacity of a machine is one or more of the following. Skipped stitches Shorter than usual stitches, or stitches going into same hole and not moving along Top thread knots on bottom, or bunched up on bottom, or wrapped around bobbin Bent and broken needles Bent take-up lever or cranks inside head Shuttle hook knocked out of time Needle bar knocked up, out of time with hook. Ruined leather goods -
The cast iron treadle base for Singer patchers are specific to those models, in long and short arm setups. No other treadle base will work at well as the proper one for that model.
You can buy replacement parts from Toledo Industrial Sewing Machines (an advertiser here - see banners), or from Gregg at Keystone, or any other sewing machine dealers who place banner ads on this website.
If you are contemplating buying the motorized machine and converting it to a treadle base model, locate the base first. They are hard to find in the size used by the long arm patcher machines. Also, the base is very heavy and will be expensive to ship.
That motorized patcher on a pedestal stand is worth more than one on a cast iron treadle stand. The stand and motor would cost about 250 to 300 alone.
I have the same model 29K172 and wouldn't sell it for under $1200, on the cast iron base.
Servo Motor Swap: Brake Or Needle Positioner
Wizcrafts replied to LewSchiller's topic in Leather Sewing Machines
I have two Family Sew motors I bought from Bob Kovar and neither has the brake engaged. Perhaps they have an adjustment screw inside the case. One could locate and turn that screw until the brake was off by default. I already see the question coming, so here is my answer in advance. I use my right hand on the flywheel to stop the machine from running on when I take my foot off the pedal. This works fine for me at the speeds I typically sew at. If I have cranked up the speed to git-er done, I slow down as I approach the end of the stitch line, then halt the machine by hand brake. I suspect that some brake-fitted servo motors have more range of adjustment available than others. Those could be set up to allow more foot movement before the motor begins to turn over. This would allow more motion to disengage the brake. That is how I setup my clutch motors. -
I have this motor powering a huge, 20 inch bed walking foot machine and find no need for a speed reducer. The motor is equipped with a 2 inch pulley and is already able to punch through whatever I have placed under the feet. Of course, a reducer wouldn't hurt anything aside from one's top speed. The motor runs at about 3600 RPM, tops. A 2" motor pulley feeding a 4" flywheel pulley makes the machine's top speed about 1800 RPM, or stitches per minute. This maxes out a 30 stitches per second. With a 6:1 reducer system, the new top speed would become 600 stitches per minute, or 10 per second. This is okay for the kind of leather sewing crafters do, where slower is better, but not for upholsterers, where time is money.
I'm now using Family Sew 3/4 hp servo motors. They have speed limiter rotary switches on the front, which are very easy to access. Curiously, the rotary switches on my motors are wired backwards to US and Canadian sop. They go faster counterclockwise, rather than the opposite! These motors have much more torque at very slow speeds than my 2 SewPro 500GRs. Plus, they have a much higher top speed than the SewPro. I put one on my Singer 31-15 and, depending on the rotary switch setting and my foot position, I can sew from about 1 stitch every few seconds up to 25 per second. I happen to buy these motors from Toledo Industrial Sewing Machines. I am guessing that many other sewing machine shops sell them as well, possibly under different brand names. I paid about $110, plus about $15 UPS shipping. The other one was installed on a machine I had custom built. That is a 20" long bed, Singer type 139 walking foot machine. I usually run it at the slowest setting, or the first step up from there. Since I use it mostly for patches, this is all the speed I need. But, a twist of the knob can send the poor machine into overdrive, like used be on my 1956 Olds Rocket.
I own a 15-91, which I'm trying to sell from my shop. It simply cannot properly sew with anything thicker than #69 bonded nylon. Also, it lacks the penetrating power to punch holes through more than 3/16 inches of veg-tan belt leather, without me hand-wheeling it to get it started (and keep it sewing slowly). It then becomes a challenge to keep the leather from lifting with the needle.
Choosing A Fabric Sewing Machine?
Wizcrafts replied to PredatorEdge's topic in Leather Sewing Machines
Melco makes hat hoops for their commercial embroidery machines. If you search classified ads for your state, you may turn one up for sale, used, in the $5,000 range (well under half price). Older models with 6 needles can be found at that price. -
I own a Singer 15-91. The first thing I had to do after lubing it was to rebuild the potted motor and replace the wires. This became a messy and expensive operation. Then, the foot speed control lost its slow speed range and had to be replaced with a new one. This doubled the cost of the machine before it ever sewed a stitch for me. Your $100 investment could easily double if these items need replacing. Besides, decent running models that have already been rebuilt sell for $200 and up.
Go to your nearest Joann Fabrics and take a look in the Viking sewing machines section. You will find exactly the machine you described, under either the Singer or Viking brand name. The least expensive ones (around $800) require a computer to be connected to the machine to do embroidery. The installed manufacturer's software and downloads from compatible pattern makers loads in to computer, then drives the machine. Without the computer, they only do the usual multitude of fancy or straight stitches. Note, I don't recommend using any of the newer plastic body machines for sewing leather, unless it is very thin (no more than 1/16 inch), and using normal domestic sewing thread, not bonded nylon. These machines are fragile! -
Upper Thread Breaking On Thicker Veg Tan
Wizcrafts replied to charter's topic in Leather Sewing Machines
I use liquid silicon lube, which is sold in quarts or gallons, from industrial sewing machine dealerships. -
Try using a Schmetz #23 leather point needle. Also, run the thread through a lube pot, or buy some pre-lubed thread. This makes it easier to fight the friction and heat. Crank down the pressure spring or springs on the feet. If the leather lifts with the needle it causes skipped stitches and frayed thread. Try using a double toed foot. Reduce the bobbin tension, then balance the top tension. -
These are fickle machines. The angle you sharpen on must be correct and go from the tip of the blade, upward about 3/8 inch. This usually means you start with the blade some distance from the foot, so the tip barely gets sharpened. Then, begin moving the blade towards the foot and backing off the sharpening wheel, to create a long taper. Finally, use your deburring sticks on the inside of the spinning blade to get rid of inside burrs. That's how I sharpen the blade on my Fortuna. The rest is a balancing act between the height of the drive wheel, the presser foot and distance the edge of the blade is to the right of the foot. Moving it farther away makes it easier to feed.
