Industrial sewing machines do not use home style needles. Industrial needles are totally round at the top, whereas home needles have a flat side to align them inside the needle bar. You must read how to properly align the eye and scarf of the needle and make sure the top is fully seated in the bar. Needle size depends on thread size, top and bottom. Your soft leather may be fine if sewn with #69 or #92 bonded nylon or bonded polyester thread. You should use a leather point needles only for leather. Use a #16 or #18 needle with #69 thread, or a #18, #19, or #20 needle with #92 thread (same sizes on top and bobbin). The needle "system" is determined by the make and model of the machine you buy. The system is determined by several factors involving the diameter of the upper shank, length from shank top to top of eye, length of eye opening, and overall length. There are also different types of leather points. First get your machine, then worry about needles, bobbins and cases and oil. Four thicknesses at what thickness per layer? One sixteenth of an inch? 3/32 inch? If the total thickness exceeds 5/16 inch, some non-walking foot machines may not handle it well, if at all. It would be best to find a machine for sale and take your leather there, to see how it handles your work. You may have several disappointments before you find the right machine.
Those plates look really nice, Leatherkind! I tried grinding the bottom of my stainless steel stirrup plate and couldn't remove enough steel to allow the feed dog to move freely. I almost cut right through the right edge! I still have to drop the feed dog to use it. It is probably going to snap under a heavy load. I have ideas for better plates and maybe your plastic parts can be models for a high-end Lapeer Michigan metal shop I have business dealings with. They can scan/copy a prototype part into the $10,000 CAD program they use and have several huge Haas computer driven milling machines that run constantly.
Perhaps a needle feed industrial machine, equipped with an accessory roller foot, will do the soft leather work. Then, switch back to a standard steel foot for the satin and broadcloth. A walking foot machine will eat up the satin and light fabrics. A straight stitch machine will not feed the leather properly, unless it is converted into a roller foot system machine. A needle feed machine keeps the layers together as the needle pulls the material for each stitch. These machines must have a presser foot with a long slot down the middle, to allow the needle to move forward and backward. Juki makes great needle feed machines.
Another Rat's Nest Problem With The 211G155
Wizcrafts replied to miaoreo's topic in Leather Sewing Machines
Problem: top thread lifts out of center of top tension disks, causing thread knots and loops to appear under the bottom layer.. Solution: You might want to try what I did to keep the thread inside the top tension disks, if they have a pin on the right side holding them in position. Take your top thread out of everything on the machine. If you have a top post, ur a 3 hole guide, loop around it as needed to get a smooth pull off the thread stand and spool. Then feed the thread under the pin on the right side of the disks, then bend it sharply up and around the center of the disks (raise the presser foot to relieve the tension). Then feed it down to the check spring and through the take-up and guides. You will need to reduce your tension spring setting to compensate for the sharp turn, but the thread should stay inside the disks from now on. -
I bought two from Toledo Industrial Sewing Machines: the first in mid-2009 and the second in mid-2012. While they bolt into the 3 original holes perfectly, the shafts sit closer to the table. So, I needed to subtract one inch from the belt length, after accounting for the difference in pulley diameters. Since the SewSlow has a 2" pulley and the original had a 3" pulley, I ended up with a 2" shorter belt than the one on the clutch motor.
I buy all of my bonded nylon thread from Toledo, Ohio, from Toledo Industrial Sewing Machines. I use sizes 138 through 277, depending on the thickness to be sewn and strength required. For instance, for a rifle sling, #138 will do fine. A top stitched 8-10 ounce belt looks good with #207 thread (or 277 on top and 207 on the bottom). A serious holster usually needs #277 for the best strength per stitch, in the event of a struggle for the gun. Extra thick (3/4 inch) holsters and sheathes are best sewn with #346.
I got my machine for $500 cash, with a clutch motor. Then, I bought the SewPro 500GR (aka. Toledo SewSlow) servo motor for better slow speed control. I use it almost every day, for sewing on jackets and biker vests. Anything circular is easier to sew on a cylinder arm machine. Examine your pattern to see if it lends itself to a flatbed or free arm machine.
If it is black thread, it may have been double-dyed, turning it into a coil spring.
Cobra 4500, Cowboy 5100 Bulk Needle Supplier
Wizcrafts replied to Boomer's topic in Leather Sewing Machines
Have you contacted our supporting dealers: Leather Machine Company, Toledo Industrial Sewing Machines and Techsew? They have ad banners that rotate on top of every page, as you reload the pages. Needles are also available from Keystone Sewing, who is a contributor to this forum. -
Don't get rid of your Consew Billy. You may need it to sew vests.
Get a Bernina roller foot and some #69 bonded nylon thread. Or, try a Bernina Teflon foot. Either foot is better than the standard steel feet.
Almost any home sewing machine can be modified to sew about 8-9 ounces of leather by changing to a roller-equipped presser foot and threading it with #69 bonded thread. Use a #18 leather point needle, maximum, and increase the top pressure until the leather stops lifting with the ascending needle. The upper tension will need to be increased to pull the knots up. Sew slowly into veg-tan leather. Pre-lubricated bonded nylon thread is your friend in such situations. Have some appropriate tools on hand to re-position the needle bar or reset the timing, when they go out from the pounding and tugging.
I neglected to specify that you should loosen the bobbin tension screw until there is just a slight pull on the thread. This will give the top tension a little breathing room for adjustment. Ya see, if you screw the top spring all the way in, there is no room left for the disks to move apart and free the thread, when you raise the feet to remove the work. Also, insert the bobbin so it feeds backwards into the slot in the bobbin case. This helps prevent your tightly wound bobbins from unloading into the case as you speed up and slow down..
Bob, at Toledo Industrial Sewing Machines stocks 1 pound spools of thread in quite a few colors, in sizes 69 through 277, plus basic colors in #346. I got some #207 red-orange thread from him a while ago, which I use on Harley patches and jacket repairs.
Pre-load some tightly wound bobbins with #207. Buy pre-lubricated thread and use it top and bottom, Wind the top thread once around the post on top of the machine for added resistance. Set her up with a #24 leather point needle and screw down the pressure spring on the presser foot. You'll probably have to screw down the upper tension spring in all the way to pull the knots up into the bottom layer. Sew slowly, at about 1 or 2 stitches per second. If you are careful, you can turn out some pancake holsters on that machine, with #207, pre-lubricated thread. Don't expect the machine to perform flawlessly using this setup, or for very long. You will be pushing it beyond its 9th life.
I think the S2 button option determines the direction. You would button down hard, then button up to S2. There, you would button up or down to change the direction. Someone will correct me if I am mistaken, or if the S designations don't apply.
Techsew 2700 - Adding A Speed Reducer After The Fact.
Wizcrafts replied to Phatdaddy's topic in Leather Sewing Machines
The reducer should be fitted as directly inline, laterally and vertically, with the machine's pulley as possible. However, the lateral position is more important, to minimize shake from an off-center pulley. You will probably have to relocate your bobbin winder assembly so it makes contact with the new belt position. -
Four things affect the length of the drive belt, when changing motors, or motor types. Pulley diameter Pulley width inside Belt width Motor shaft horizontal position under table, in relation to original. A standard sewing machine setup uses a system 3L belt and pulleys. The top is 3/8 inches across, and the inside tapers inward. If the new motor has the same pulley diameter and 3L width, and if the shaft occupies the same horizontal position under the table, the original belt will fit. But, if the new motor has a smaller profile and its shaft is closer to the body, you may lose 1 inch of adjustment. If the motor pulley is also an inch smaller than the original, you lost another inch of belt.
In my case I brazed metal onto the puck end of the bell crank lever, then sanded and polished it for the best fit short of binding in the ring bar. The stitch length jumped from 7 or 8 per inch to 5 per inch, just from that one correction. However, I have encountered some patchers that were improperly setup for foot lift during the pulling cycle. The foot needs to lift off the leather in order to move forward. Then, it must drop all the way down, onto the material and exert enough pressure to pull the work back the stitch length, as set by the sliding stitch regulator on the back of the foot bar.
New Machine > What Do I Need > What Is The Best Setup?
Wizcrafts replied to Csr111's topic in Leather Sewing Machines
I once saw a walking foot head on eBay, where the seller had mounted a home sewing machine motor and small ribbed belt to the back and used it to drive the machine, via a foot speed control. The machine itself sat in a custom made box. This was an example of a 60 pound portable walking foot machine. Maybe you can build a box to hold it and mount a 1.5 amp motor to the back to drive it? -
Maybe a Singer 132K6? I had one of those, decades ago. It sewed a half inch, with up to #277 thread, using a #25 needle
My advice to you is to buy a complete walking foot machine, already equipped with a good servo motor, setup and tested on leather. -
What Can You Tell Me About This Machine
Wizcrafts replied to Cowhorses's topic in Leather Sewing Machines
That machine, like all others of this type are made for sewing shoe and boot uppers. They basically have a limited amount of lift that cannot be exceeded and tiny bobbins that empty quickly. Patchers like this one are best limited to #69 bonded nylon thread, or maybe #92 bonded polyester. There is a class of Adler patchers that has higher sewing capacities, but they are hard to find for sale and very expensive. -
The LU-563 goes back to the mid-1980s. It has a double capacity hook and bobbins and compound feed, with a reverse lever. I had one in my previous life and found it adequate for wallets, vests and belt edges. Are you just buying the head, or is it complete, on a table? If it's just the head, you are in for some sticker shock as you gear up to use it. Here is what you need to use this machine: Machine head, with proper hinges for table mounts Steel legs table, with proper cutout and rubber mounts for machine base, plus, holes for a flex light, motor, fold back peg, a belt slot, and a parts drawer Motor and switch box, with power cables and cable clamps.. V-belt of proper length to go from motor pulley to machine flywheel and be within adjuster range on motor. Bobbin winder assembly Thread stand assembly Oil pan to fit machine and table cutout Knee lever assembly for this type of machine Flex lamp If all of the above come with your Juki and you are buying it for no more than about $500 to $600, you are doing okay. Otherwise, expect to pay $250 to $400 more to get the table, motor and other aforementioned parts needed to finish it off.
