You'll appreciate the difference you paid for the Cobra skiver when you need help with some problems that develop, or parts that wear out or get damaged from misuse. Unless you are prepared to fix parts yourself, including the band blade, buy the new machine from Steve.
10 ounces is considered lightweight when it comes to skivers. I used to have two skivers. One was a Fortuna, with a stone drive, which was best suited to shoe upper or garment leather. The other had a serrated steel wheel and worked best on veg-tan and sole leather. That machine tended to eat chrome tanned leather, as it skived it. I got rid of both machines a long time ago. The modern top and bottom drive units can handle both ends of the skiving spectrum.
I would like to get one if yours holds up. Contact me via the PM feature. I have other things in mind that you might be able to "print" for me in plastic.
Clutch Motor Bogging Down On Skiving Machine ?
Wizcrafts replied to CustomDoug's topic in Leather Sewing Machines
A 3450 RPM motor produces most of its power at very high speeds only. You would be better off with a 1725 RPM 1/2 HP, 550 watt motor. That's what was in my USM Puma skiver, which I sold years ago. -
400 watts is not even 1/2 horsepower. You should be using at least 1/2 hp, if not 3/4 hp, at 1750 RPM. For the time being, try changing to a smaller motor pulley and matching v-belt (1 inch smaller belt per inch smaller pulley). Also, oil every oil cap and hole and clean out any skived pieces from the knife area. -
Opinions On Fratelli Skiving Machine
Wizcrafts replied to simontuntelder's topic in Leather Sewing Machines
Since they are still in production in Italy, buy it and contact the factory if you need a new blade, belt, or deburring stones. You are getting the machine for a quarter of its true value. You can probably order a manual from the company. They can tell you what the skiving capacity is once you know the model number. -
You should be able to pull the top thread when you lift the tension release mechanism all the way (by pedal). Here is how I adjust my machine. First, loosen the bobbin tension until it has a smooth pull that is neither too loose nor too tight. This varies each time you change thread sizes in the bobbin! The tighter the bobbin thread, the tighter the tiop must be to pull up the knots. Back off the secondary spring until it is just barely engaging the disks. Now adjust the tension on the top disks until the knots look consistent. If you need a lot more tension to pull them higher up, use the bottom tensioner for that purpose. Finally, use the best needle size for the thread combo. If you have #138 in the bobbin and #207 on top, a #23 needle is good. If you change to #207 in the bobbin, or #277 on top, move up to a #24 needle. For #277 thread top and bottom, use a #25 needle. If the stitches suddenly change with an obvious sound, stop and look to see if the top thread has jumped out of the upper tension disks. When this happens you get a birdsnest on the bottom. Conversely, if the top thread gets wrapped around itself and doubles over the primary or secondary disks, it pulls the knots to the top and may stop the machine in its tracks after a few stitches, or may filigree the leather.
Was the leather or Biothane lifting with the needle? If so, that causes skipped stitches. Crank down the pressure screw over the outside presser foot, until the leather stays down while the needle and thread pulls out of it.
I do this on every one of my sewing machines. It is a real headache saver.
that demonstrates how to thread a similar sewing machine with a different brand name. The threading path is identical for your machine.
Pull the stitch length lever all the way down to put it into forward motion. Turn the limiter nut away from the lever to allow it to go down all the way. Pull the thread out of the needle and up through the take-up lever. Pull the hand-wheel towards you from the top (Counterclockwise) and watch the feed dog. It should move to the front with the needle and inside foot, then rise slightly above the throat plate, then move backwards, then drop down and begin this cycle again. If the motion is correct with the lever way down, move it all the way up and repeat the process. Now, the feed dog should start at the back, lift, move forward, drop and move back for the next stitch. If this happens, the machine is operating normally. Rethread the top thread through the take-up lever, then down through the formed loop, through the hole above the needle, then through the needle's eye, from left to right. Insert a piece of leather. Lower the feet if they were lifted up, until they make contact with the leather. Rotate the wheel towards you again and see if she sews at all. Report back. Time to eat dinner. BRB...
Wanted - Pfaff 6120 Or Similar Machine
Wizcrafts replied to particle's topic in Leather Sewing Machines
That Pfaff is a bottom only, drop feed home sewing machine. -
Top Thread Being Stripped & Snapped
Wizcrafts replied to Gamekeeper's topic in Leather Sewing Machines
The Juki DSC-245 series is a light duty, cylinder arm, walking foot machine. The specifications state that it is best used with no larger than #69 (T70) bonded thread, or 40/3 cotton or polyester thread. I don't know about Invincible brand thread, but I do suspect that your machine will not sew with 0.9 mm thick thread. You'll be lucky if it handles 1/3 that diameter (see thread/needle chart). -
I have mentioned this before and will repeat it once again. Golf bags are best sewn on two types of long (~36") cylinder arm machines. One has standard feed, for sewing across the ends, or across the center area. The other machine has transverse feed that sews up the arm, towards the body. It is used to join the long seam that runs from top to bottom of the bag. You can either use a lockstitch or chainstitch machine for golf bags, since you don't see the inside threads. Transverse feed machines for leather bags are usually special order machines, built on demand.
Welts, or piping have a rope-like cord inside them, to give a solid pipe result. If you use 3/16 inch diameter cord, wrapped with 1/16 inch thick leather, a 1/4 inch piping foot is a perfect match. If you try to sew with a piping foot and there is no cord inside the package, the material tends to simply compress flat, or semi-rounded. You may or may not know how a piping foot works, so I'll explain it. A piping foot has a rounded radius ground into one side of the foot, with the needle hole immediately next to the end of the radius. The rounded portion rides on top of the covered piping cord. If the foot has been properly matched to the diameter of the covered cording, the needle will hit very close to one side of the covered pipe. If the foot size is to wide, the needle is too far away from the piping. If the size is too small, the needle may go into the piping, rather than next to it. If you have a walking foot machine, your piping foot is made in two parts: the narrow inside radius foot and wide outside radius foot. The needle hole is inside the inside foot, to one side of its cutout area.
Your Grandma's Singer 15-88 is a straight stitch, low foot mount machine. There are welting/piping feet available for it. I bought a 1/4 inch piping foot for my 15-91 on eBay, several years ago. It cost me about $10. The same feet are used on all of the 15 class machines.
I feed the thread down, through the steel loop guide over the bottom disks, then around the disks twice, then back up through the guide, then to the thread check spring, etc.
Absolutely! Right now, it is converted into a roller foot machine. But, with a few minutes of screwdriver turning, it reverts to a normal presser foot/feed dog machine.
I'm currently using two turns around the bottom disks.
Those spring guide feet are available in right side, left side and varying distances from the needle. They are very useful for times when a swing-away edge guide won't work. There is also a foot with a spring or piece of steel guide on the front center. It is used to install blind zippers. As far as I know, they are only available for straight stitch machines, not walking foot.
Less bottom tension, more top tension, or a larger needle size.
I wonder how a Hiroshe hook and a Juki take-up lever would hold up with Kevlar thread.
What make and model is the machine?
Singer 29-4 And Landis 12 G Thread/cord Questions
Wizcrafts replied to Rossr's topic in Leather Sewing Machines
I am pretty certain that your Landis sole stitcher requires right twist thread. This is the opposite of what modern leather sewing machines use. I would use either 6 or 7 cord, Barbour's Irish Linen thread, which you can buy from the Campbell-Bosworth company. The ancient Singer 29-4 can sew with up to 3 cord linen, or #69 to #92 bonded nylon or polyester thread. I use #69 nylon for motorcycle vest patches and #92 for zippers.
