Wizcrafts
Moderator
  1. @MelissaViarengo Looking at the pictures of your machine, it looks like the teeth have been filed almost entirely flat on the bottom of the foot. The entire feed is done by the teeth digging into the material. If those teeth are blunt, or missing, the foot cannot pull the material back to form stitch length. The teeth on the foot should be sharp to the touch. You can find replacement 29k presser feet on ebay in Italy. While you await your replacement presser foot, try adding some thin rubber or clear carburetor tubing to the feet. 1/8 inch inside diameter should fit on the legs. This may have enough grip to pull the work to form stitches. Add more spring pressure too.
  2. I have an old Singer 139w109 that has a 20 inch flat bed from the needle to the body, plus it has a compound feed walking foot mechanism. It was converted to take Juki U size bobbins. The wheel is on the back, but that isn't a problem. It is easily reached. This type of machine is based on the ubiquitous Singer 111 series machines. It can sew 3/8 inch of material with up to #138 bonded thread. I mostly use it to sew embroidered patches onto biker's vests. That's where the 20 inches of bed space comes in handy.
  3. You'll need to get a proper walking foot machine, then get #18 leatherpoint needles in the "system" that machine uses. For instance, my Singer 111 and 211 machines take system 135x16 leather point, and 135x17 round point needles. I tend to hunt for titanium coated needles because I sew through leather tape or glue on a lot of jobs. Titanium coating helps prevent clogging of the eye of the needle. I also keep Goof Off and a dauber close by to clean the crap off the needles when they do get full of tape residue!
  4. Welcome to Leatherworker.net As you have discovered, the machine you have is inadequate for the work you have on hand. My article that was linked to earlier today should help you understand the type of machine that actually sews leather. Within this basic deinition there are various levels of capacity in the various makes and models available. At the very least, you should look for a compound/triple feed walking foot machine. Early examples are the Singer 111w155 and 156 (has reverse), the older Juki LU-563 and newer models, like the Juki DNU-1541, and some Consew models that have triple feed, like the Consew 206RB-5. These machines can handle up to #138 bonded nylon thread and actually tension it enough to sew over 5/16 inch of leather, depending on its density. They weigh over 70 pounds and need to be fitted onto industrial sewing machine tables that have steel legs. Most tables are 20" x 48". They are usually equipped with powerful clutch or servo motors that drive the heavy steel mechanism through stacks of leather that would destroy a home hobbiest's machine.
  5. As previously mentioned, it is not a walking foot machine. Some of the best known Singer walking foot machines are the slower speed 111w155 and 156 (w/ large balance wheel pulley), as well as the higher speed 211w155 and 156 (w/ small pulley). There are also some older Singer walking foot machines that have whaat's known as a spring foot. These have a foot that simply follows the material as the feed dog pulls it back. They only had bottom feed. A proper walking foot machine has at least dual, if not triple feed.
  6. @MelissaViarengo You have the stitch length adjuster way up high on the foot driving bars. That position gives the shortest stitches. Lower the adjuster by loosening the round thumbscrew. You can set it for its maximum stitch length by raising the foot lift lever and lowering the adjuster, aka regulator all the way until it just touches the top of the raised foot. After lowering the stitch regulator, tighten the lock screw to keep it there. You should be able to get almost 5 stitches per inch in about 5 ounces of shoe upper leather. Anything less indicates excessive wear in the foot driving cam that rides inside the big round ring on the bottom of the head. There is a stud shape sticking out of that cam that rides inside the round ring. When the ring moves down, it pushes on the dtud and that causes the foot to get pushed back to pull the material.
  7. That machine looks very similar to the Consew P-1206RB. It could be the forerunner of the 1206. Maybe the specs on the page will apply to your machine.
  8. I would lower the stitch length gib until it just hits the top of the foot when it is in the manually raised resting position. This is the highest position the foot can reach and the longest stitch length setting possible for this type of machine. With the foot lifted by the lift lever, push and pull on it to see how much slop is in the mechanism. If it has noticeable slack motion, that translates into lost stitch length. The thicker the material, the greater the loss of stitch length no matter how tight or loose the foot drive parts happen to be. Remove the needle for this item! With the foot lifted, rotate the balance wheel towards you from the top. Verify that the foot moves forward then backward. Hold the front of the foot by the legs and see if it still pulls backward under a slight resistance of your hand on it. If it fails to pull back, the feed motion cam is worn beyond viability and must be replaced or rebuilt by someone with welding or soldering skills. Otherwise, move on to the next item. Lower the foot lift lever and check to see if the bottom of the foot is in contact with the throat plate. It must be in contact if it is to sew thin materials. The movable slider on the back takes care of how high the foot lifts as it moves forward to pull the material. If it doesn't go all the way down, something is interfering with its up-down motion. It could have to do with the next item. Make sure you have a decent amount of spring pressure on the foot! Tighten the thumbscrew on the middle of the big spring along the back to add more pressure, and vice-versa. Make sure there are sharp teeth on the foot. Dull feet won't feed most materials, or slick leather. You can hammer or rub out the tooth marks later on. So, make sure that the lowered foot goes all the ways down, then lifts up to the height set by the lifter on the back. Verify that the foot feed motion cam is moving the foot backward as the machine turns over. Know that parts specific to this model (-4) are obsolete. Most people have to find donor machines to strip parts from, or have parts repaired or modified. Pray that the little gears inside the arm are still good!
  9. Please look at the package that the needle came from and let us know the designation on the needle. For instance, a System 794 or 7x4 in Schmetz S Point, or a 4-sided Diamond, or 3-sided Tri point, or an LR or LL twisted wedge point. The first 3 give a straight stitch line, but with a different visual front to back length on top. The last two are made with a left or right twist on the tip of the needle. While the needles can lay the thread differently based on their geometry, the only ones that might try to push the leather sideways are the LL and LR slanted wedges. Personally, I avoid slanted needles. My preferred needles either have a diamond or tri point, or an S point, which is an inline slicing wedge. If you sew a stitch line with each of these two types, using the same stitch length and tensions, The S point stitches will appear closer together and submerged, compared to the diamond shape needles. Then, there's always System 7x3 round point needles that poke a round hole and are made to sew fabric and synthetics, and create a straight stitch line with good visual appearance between the ends of the stitches. Now that the needle geometry has been discussed, there is something mechanical that could cause the strip to move sideways as your sew. That is a misaligned or loose needle bar and inside foot mounting frame. Normally, this frame is installed with a minimum of sideways clearance to keep it sewing straight. If some impact knocks the frame alignment out, it may sew off the center line. Look to see if your machine has an L shaped bracket screwed on at the bottom of the moving frame that contains the needle and inside foot bars. If present, make sure it hasn't loosened or moved to the left and giving too much clearance to the moving frame, which might be called the "rock frame," or such.
  10. You will be stressing out the 563, which was built in the 1980s. It wasn't made to sew veg-tan. I had one around 1988 through 90 and found that it struggled to sew pancake holsters made of two pieces of 8 ounce veg-tan leather. If your projects will be in this thickness range, you're better off with a 441 clone, like a Cowboy cb4500. I have one and it will sew anything I shove under the feet, using the heaviest thread sizes, like 277, 346, or 415. It will also sew 10 ounce belts and straps, all day long, using #138 or 207 bonded thread. The bobbins are huge and cylindrical and hold enough #138 or #207 thread to sew several days worth of belts. The Cowboy can also handle Nomex thread. All of the take-up and tensioning parts are extra beefy and made of hard and polished steel. Nomex lists for about $200/pound. But, I've been able to find it on eBay for much more affordable prices.
  11. Many of us, including me, use this type of "brushed" servo motor: https://www.tolindsewmach.com/motors.html. Unlike the one you linked to and own, which starts at 200 rpm, this motor starts turning over smoothly from zero rpm when you move the foot pedal down. There is no jerky start, nor any complicated electronics panels to replace. The only parts that experience wear are the two carbon brushes, two of which which come extra with the motor. I've yet to go through the original brushes in a motor I installed around 2014.
  12. Way back in the late 1980s, I had a job setting up a sewing operation that required applying edge binding to the items being sewn. I started out with an over-the-counter folder and some bias tape in 3 foot lengths from a store. The results were a disaster! I called my industrial sewing machines dealer and he recommended that I contact a guy who custom built folders and other sewing machine attachments.I got together with that fellow, showing him a sample of the material I was working with. He designed and built a double folder attachment that fitted onto or across the bed of the Juki LU-563 that I was going to use. The folder was made to double fold bias tape that was sold on huge rolls. It was 1.25 inches wide and I believe was polyester material. The roll sat on top of a platter that was mounted onto the right-rear end of the table. The platter rotated freely under adjustable spring tension. I set it to prevent the roll from free-wheeling when I sewed fast. This setup worked flawlessly. The edges were about 5/16 inch down from the top and were sewn a little over 1/16 inch above their bottom folded edge. The material being covered measured about 1/16 inch thick along the edges. It was an orange honeycomb material that I made into safety vests worn by road workers when they were on the job on highways and byways. I also 2" wide sewed yellow Reflexite strips across the front and back, plus sewed a patch on the back identifying who they worked for. This eventually morphed into reflective vests for transit works and Police officers. The bottom line here is that if you need to sew edge binding onto goods for sale, go the extra mile and have one made or modified to work with your preferred edge tape and sewing machine. A fully matched set of parts will work more reliably than miscellaneous parts from hither and thence, made by sum yung gui hung lo.
  13. To use leather as edge binding, it should be as slippery as possible so it flows through the binder attachment. Glazed pigskin lining leather that Tandy Leather sells in the US and Canada comes to mind. It is very thin, usually under 2 ounces thickness, strong (I use it for wallet interiors and holster linings), and slippery on both sides. It would probably work well in a double-fold binder. Sometimes, getting leather to work in a folder attachment just doesn't work out as you hoped for. Here's a Plan B for you. I have a buddy nearby who makes high-end holsters, rifle slings, guitar straps and tooled belts. He manually installs thin lambskin edge binding on many of his projects by laying it flat on the outside, grain side against the outside edge of the project (grain to grain). He uses 1/4 inch wide double-sided leather tape to hold the lining to the project, along the very top. He bends and folds the lamb ski to follow the contours of the project, then sews it on just below the bottom of the double-sided basting tape. This ensures that the needle just misses the 1/4 inch sticky tape. After he has sewn the edge strip onto the project's from side, he applies another strip of tape to the visible bottom edge of the lining material, then pulls it up and over the top edge of the project. He pulls it tightly over the top and presses it down to the inside of the project. The edging on the back should hang below the stitch line done on the front side. The tape should hold it in place. Once he is satisfied with how the edging lays on both sides, he takes it back to his sewing machine and sew through the front side, just under the double-folded edge. This captures the longer piece that is folded over to the inside. He cuts the width of the edge leather so that is folds nicely and tightly on the front and hangs just far enough down on the back for the needle to capture it. A typical binding from him would have about 1/4 inch folded over on the front and 3/8 inch protruding on the back side. Sometimes, he uses precision scissors to trim the back side after it's sewn on. When the sewing is finished, the edges are double-folded on the outside and single folded on the back. The grain side is all the customer sees on either side. The above method may be unconventional, but his customers like it and haven't complained about it getting in the way, or coming apart. I believe that he uses about 2 ounce thickness lambskins as edge bindings. He doesn't need a binder at all. He uses his left toe presser foot on his Cobra Class 4 stitcher, with a #23 needle running either #138 or #207 bonded nylon thread. His machine has been modded with a narrow feed dog, with a smaller than stock hole, and matching throat plate to prevent soft leather from getting pushed down into the bottom feed parts. If you want to try using his system to apply lambskin edging, purchase quality skins that are as long as possible. Aim for about 1.5 minimum to 2 ounces maximum thickness. I buy the double-sided basting tape from Wawak.com. Other companies may carry a different brand that has a greater or lesser holding strength. Note, if you will be sewing through double-sided basting tape, use titanium coated needles with as large an eye as possible. Keep a small glass jar filled with Goof-Off nearby and use a small wool dauber to dip in into the liquid solvent. Rub the wet dauber over the needle every now and then to dissolve and remove any adhesive residue from the tape. Failure to clean the needle will result in the top thread sticking in the needle's rib and eye, leading to skipped stitches and ratted top thread.
  14. @toxo I went through a big fight with binder attachments before I got the one that worked for our applications. It was custom built for the job and the edge binding we picked. The results was a perfectly placed double-folded edge bind on both sides. If you can't find someone to build you a binder, choose the width based on the material you will be running through it. Decide if you want a single or double folded edge. Most binding material is either cloth or synthetic bias tape. If you want to use vinyl, consult Sailrite company in the USA. They make portable and industrial sewing machines for the boat trade and offer bias tapes and folders that work properly. They can probably set you up with attachments, platters and tapes that work.
  15. Evidently, that particular machine appears to be industrial. That is unusual for the Viking brand. The only manual I found is linked to in my earlier comments. There is a fee to be paid to download the manual. I haven't found any other info about that machine. The original question was asking if it can sew leather. From the picture posted, it is a flat fixed foot bottom feed machine which is typical for garment sewing machines. I would be surprised if it can hold down any leather denser than soft chap or garment leather. The tensioner looks like it is only strong enough to handle thinner threads that are typically used in garment sewing. However, most of those machines can tension up to #69 (T70) bonded thread, with a #18 (110) needle. This would at least allow you to sew leather garments with it. Your main problem will be climbing up onto higher layers and thick seams. You'll have to lift the foot with the knee lifter, if that's what's coming out of the bottom. A photo taken from the top and left or right will help figure out its drive system and probably capabilities. But, experimentation goes a long way.
  16. A #23 needle is the right size for #138 thread on the top and bottom. Look closely at the leather under the needle to see if it is lifting with the needle as it ascends. This almost always causes skipped stitches. If it is lifting, add more foot pressure. Inserting the needle backwards has the same effect. Make sure the rib side is on the left and the scarf side faces due-right. If the check spring is set wrong for the work, it can cause skipped stitches. The bottom stopper should halt the downward motion of the check spring as or just after the tip of the needle enters the top of the work. The longest it should allow downward motion would be as the eye shows just under the bottom layer. The other settings are spring tension and slack adjustment, via a set screw inside a curved slot. Try changing the position of that screw.
  17. Make sure you hold back the starting threads, or at least the top thread, for about three stitches. Ensure that the needle isn't too small. Move up a size or two to see if that helps bring the top thread up into the leather. Choose the correct size needle for the thread combination. Do standard troubleshooting stuff. Start by checking the hook to needle timing. Adjust the hook or needle bar height if it has been thrown out by the impact of sewing rubber. Remove the throat plate and clean off any residue on the bottom of it. Also, check the feed dog and clean it if necessary. Re-time the machine. Change the needle to a leather point needle. Make sure you've threaded it correctly and that the top thread stays inside the tension disks and doesn't lift up as you sew. Center the check spring if it was turned to one end or the other end. Finally, make sure that there is a modicum of tension on the bobbin thread; not too much or too little.
  18. You didn't offend anybody I know. I often learn about people being dead after I wish them happy birthday on the book of faces!
  19. I own a Cowboy cb4500, which is a Juki 441 clone. It easily sews over 24mm thick stacks of whatever you have under the feet. It is a heavy duty sewing machine with two feet: inside alternating and outside presser feet. I would not refer to them as meant for delicate materials! The bottom appearance will vary with the presence or absence of the feed dog and its size. The stock feed dog is very wide and has a large oval hole in it. Soft stuff will be pushed down into that hole and may look dab compared to the top layer. To get around this problem, a couple of enterprising people have come up with narrower feed dogs that have smaller needle holes. I use one of these all the time. One maker is in Australia and the other is in the USA. They sell the narrow feed dog with a matching throat plate that is just wide enough to let the feed dog move freely. If you buy a 441 clone, then add the aftermarket narrow feed dog and throat plate, you will still be able to sew with #277 bonded thread, using a #200 (25) needle. The geometry of the needle matters too. you could experiment with different leather point shapes, and even a round point. Or, you might find somebody who owns such a machine in Hungary and send them some sample stacks of leather and foam to sew for you. Ask them to sew a separate line of thread with different needle point shapes. If they lack a particular shape that is available, maybe buy them a pack of 10 of those needles. The main needle shapes I've used in my 441 clone are Schmetz "S" point (inline wedge), tri-point (3 sided), diamond point (4-sided), and round point. I believe that some companies make traditional tilted wedge points, called LL or LR. They produce slanted stitches. I just don't have any of those.
  20. I refurbished one of those Model 127s in 2019 and I got it to sew with #92 bonded nylon thread using a #19 or 20 leather point needle, into a 10-12 ounce piece of bridle leather, at 5 to the inch! I sold the machine for $200 to the first person who asked about it. Here is a YouTube video showing the author cleaning her Singer Model 99. The details should be the same for your machine, except for the different shuttle type.
  21. For now, oil everything that moves and keep a rag onder the foot until sewing time. Twist every adjuster to get them past any high spots. You can even back off the pressure spring to make it easier to turm the balance wheel to break it in. Also, if there's a foot rotation lockscrew on the front of the head housing, back it off until it's needed. Oh, if the bobbin winder wheel is engaged, disengage it by rotating the eccentric screw on its housing. That adds some stiffness to the mechanism when it's on.
  22. A well oiled older industrial sewing machine is a lot like an old Harley. They also mark their spot!
  23. Labeling a leather point of any shape with a garment point designation is misleading. Leather cutting points tend to slice the fibers in cloth, webbing and serged patch borders. However, if any leather point has a snowball's chance in Hell of sewing cloth without destroying it, it is a diamond point needle. The shape is closer to round than the usual sideways slicing edge we have in leather points. I haven't tried sewing patches on with a diamond point, and don't recommend it without testing it first on a disposable patch with the same type of edging. I do use diamond/tri point needles on occasions when I want to sew close stitches that lay on top of leather projects, from end to end, versus S points that give a submerged appearance on the ends.
  24. Darren, Greg died in March of 2021. Here is the notice.
  25. Hey, Dwight! I'm your Huckleberry! I've been sewing patches for bikers for a decade now. I use a patcher, a flat bed and a post machine depending on how the sewing needs to be done. Here's the breakdown. If the patch is on the back, or upper fronts, and there is no pocket or zip open liner behind it, I use a long bed flat bed Singer 139. It doesn't have reverse, but I sew all the way around the patches. No reverse is needed as the starting stitches are covered by at least 6 to 8 going over them. If the vest (cut) or jacket has a pocket to deal with, I use my Adler 30-7 long arm, big bobbin, high lift patcher. It easily gets into pockets and zip open linings. If the sewing is around the vicinity of the arm holes, I tend to use a post machine. It's much easier to turn the vest around the post with the excess hanging down that to fight with a flat bed or patcher. An example of when I use the post machine is when I'm sewing flags or club names, or office positions onto the upper shoulder, in the narrow area between the front and back seams. I use double-sided leather tape from Wawak to hold the patches in place for sewing. If the back is extra flimsy, or is made of denim, I also use a long body office stapler to keep the patch and material lined up. Next, I prefer to use #69 bonded thread with a #18 needle, unless it is on a jacket or padded vest. Then I'll use #92 with a #19 needle. As for the needles, I have learned to use round point needles when sewing any patch that has a serged or embroidered edge. This is because a leather point needle will slice the closely sewn edge thread whereas the round point just goes between them. The leather under the patch doesn't care about the needle. It is garment leather. If your machine takes a needle system that is available in titanium coated needles, buy those whenever possible. This really comes in handy if you are sewing through double-sided tape. I also keep a little can of Goof Off and a dauber near my machines so I can clear any glue or tape residue off the needle. If your patcher has a lube pot, fill it with clear liquid silicon to keep the top thread from sticking to the eye of the needle. While at Wawak, buy some steel thread snips. Put magnets on the body of your machines and let them hold the snips and threaders, bobbins, etc. Wind extra bobbins in advance so you don't have a lot of downtime when you run out of bobbin thread. Prewounds go a long way if they are available for your machine(s). That's all I've got to say about tha-at!
