insole stitcher needle size 45x230 = which thread?
Wizcrafts replied to Con's topic in Leather Sewing Machines
This is a needle "System," not a size. The system seems to be rare. I have only found these needles for sale in Germany (online stores) and then only in "size" 26. This is a very big needle that can sew with up to #346 bonded nylon thread. -
I just keep a small precision screwdriver on the end of the table and use it to pry the bobbin out on one side.
You can buy an anti-backlash spring and drop it into the bobbin basket. It raises the bobbins and prevents bobbin rotation run-on after sewing at high speed and stopping quickly.
First, make sure the machine is threaded correctly and that the needle is aligned correctly! The rib should be on the left and scarf on the right when you are in front of the arm. Also, make sure you are using the correct needle system! The original was System 29x3 and 29x4, which are obsolete. The modern equivalent is System 135x16 and 135x17 (common walking foot needles). If this is already set, then the timing of the hook is probably out and needs to be readjusted. Open the throat cover plate to expose the hook so you can see which way it needs to move to intersect the needle at the right moment. When timed correctly, the hook intersects the needle above the eye, inside the scarf area, after the needle has reached bottom dead center, then moved up slightly, then halted, or just starts to move down again. If the hook passes the needle before or after these events it skips stitches. There is a hole in the lower base, on the right side. This is a screwdriver hole. Inside there is a crank shaft coming down that meets one going through the arm, which drives the shuttle. There is an eccentric screw holding the shafts together and there is a locking nut on the back of them. It is tricky to get a box end wrench under the arm and into the lower section, but it is doable. Loosen the locknut slightly, then stick a flat blade screwdriver through the access hole. Rotate the hand wheel to bring the eccentric screw into alignment with the hole and turn it one way or the other about 1/2 turn, then check how close the hook tip comes to the needle when the needle has moved down, then up and halted. It is at this point that the hook should be approaching the center of the needle, just about the eye, in the cutout scarf. If you are using the correct needle system, aligned properly and it is set to be close to the hook, but the hook can't be adjusted to intersect it after it makes the aforementioned jog, the shuttle driving gears may have slipped out of time. That is a big deal and I won't dive into it here. If you are not skilled with repairing industrial sewing machines, contact a dealer who can repair it for you.
New machine selection.... Durkopp Adler - Juki 441 clone
Wizcrafts replied to anvilring's topic in Leather Sewing Machines
You can call Bob Kovar, owner of Toledo Industrial Sewing Machines, at 866-362-7397. He is the primary dealer for Cowboy machines in the US and Canada. He will know if there are single toe presser feet for their Adler 205 clone. Or, he can grind off the right toe on a standard presser foot. -
I may be wrong, it has been a long time since I sat down at a 205, but I don't think that the presser feet for a 441 will fit on the Adler presser bar. I think the Adler presser feet have a totally round mount. Parts, like spacers and other presser feet are likely still be available from or through Weaver Leather, as they are a recognized sales partner of Durkopp Adler and Pfaff. Other industrial sewing machine dealers can probably order parts for you. If you have a heart or blood pressure problem you should probably take your meds before looking at the prices at Weaver. You have a genuine Adler 205, not a clone and not a 441 machine. -
You should start a new topic to discuss electronic positioning vs. a plain servo motor. This topic was last updated in 2015.
Uh, NO! That guide will be totally useless for anybody wanting to actually sew leather. Those plastic body el-cheapo domestic sewing machines will break if somebody tries to sew real leather, using bonded nylon thread on them! There are entry level leather sewing machines available through our paying advertisers and they look nothing like the junk on the landing page in that sewing machine review page. It is actually just an affiliate referral page. Leather sewing machines have cast iron bodies and large moving parts and heavy bearings. Everything on them has to be beefier than cloth sewing machines to withstand the pounding from penetrating leather and pulling up bonded thread between the layers.
That IS an authentic Adler 205-370 or 374. It is not really a clone of anything --- but, Juki came out with their TSC-441 a little before Adler released the 205. Did German Adler know about the Japanese Juki and make a modified version of it? I don't know. At $2000, it is a steal! The machine listed at Weaver for over $6000 while it was in production. Be forewarned that if you need any major replacement parts, prepare to mortgage your first born. Otherwise, it uses the same needles and bobbins as the 441 clones. Protect the hook at all costs! -
That is correct! Piano movers have the equipment to safely move delicate equipment up and down stairs and even through windows.
Hire a piano mover!
Stitch pattern question & one on leather.
Juki (Japan) invented this machine around 1988 or 1989 and still makes it. The model is the Juki TSC-441. Thus, the Chinese copies are called "441 clones." I have the Cowboy CB4500 and one of my best friends has a Cobra Class 4. Same mechanism, different colors. However, my Cowboy came with stainless steel feet that don't stain wet leather. -
Can anybody tell me what this is and if I should buy it?
Wizcrafts replied to bryan4christ's topic in Leather Sewing Machines
It's an ancient Landis 1 harness stitcher. It was made to sew heavy harness, saddlery, or thick work, gun and weight lifting belts. If it comes with stock System 1000 needles (now obsolete), it can sew almost one inch. If the needle bar was lowered to use modern System 794 needles, it can sew a little over 3/4 inch. -
I have stepped WAY off the deep end, Pfaff 1245
Wizcrafts replied to HossHouston's topic in Leather Sewing Machines
I have this motor powering my long arm Singer walking foot machine. The motor pulley is 50mm (2") and the handwheel pulley is about 4 inches. I can set the speed limiter very low and sew at 1.5 stitches per second. I can easily single stitch by flicking the pedal and stop with the needle up or down. I have other machines that have a smaller handwheel pulley. I added speed reducers to those machines. The reducers let me sew extremely slowly; like watching grass grow slow. The speed reducers are shown on the same page I linked to earlier. I use both types. -
Here is the servo motor I use. -
If adjusting the tensions doesn't solve knots on the top, check the thread from the spool to the needle for binding. It could be windings cross feeding, or dropping under the spool, or twisting around posts and guides. You should raise the feet manually and pull on the thread before the needle. If it is jammed somewhere, it will be hard to pull and you can follow the path until you see the problem location. If the top path is not binding, check the bobbin to make sure the bobbin thread is actually coming out under the tension spring and that tension is being applied to the thread.
What is the Consew 206 of straight stitch machines?
Wizcrafts replied to ensitmike's topic in Leather Sewing Machines
Correct! However, if one reduces the top and bottom tensions to the minimum needed to maintain a reasonably tight stitch, the thread drag will be minimized. Couple that with an aftermarket heavy duty feed dog and throat plate and a bottom feeder, coupled with a roller or Teflon foot will move leather and vinyl reasonably well. It will still be limited to fairly thin thread and needle sizes. I used this approach when I was in between being completely out of the leather business and when I began reacquiring industrial sewing machines. I had to make do with a Singer 15-91, which I beefed up as I described. It was passable until the right machines came along. -
I have several Family Sew 550 watt servo motors with speed dials. I usually set them to slow speed for leather sewing. But, now and then I take in vinyl upholstery, or tarp, or banner work that involves long seams. For those I crank up the speed, re-oil the oil holes, then fire up the machine and sew flat out at about 20 to 25 stitches per second. Sometimes my partner needs to spray silicon on the needle as I sew that fast. I could probably buy a magnetic lube jar, but this doesn't happen too often any more.
You may have to remove the foot, needle clamp and stitch regulator, unscrew the revolving head section, and pull it off the machine. leaving the needle bar attached to the take-up thread control arm. That should let you remove anything that's in the way of getting the top tension disks off. Before reassembling, oil the needle bar and the parts inside the revolving head. This would also be a good time to replace the feed motion bell crank if you are getting less than 5 stitches per inch into 6 or 7 ounces of shoe upper leather.
Cowboy CB3200 forward and back Stitch misaligned
Wizcrafts replied to palvim's topic in Leather Sewing Machines
I was instructed by my Cowboy dealer that the best setting for most sewing on a 441 clone is to remove any leather, then handwheel the machine until the tip of the needle reaches the feed dog. Then loosen the big bolt on the crank on the back to position the inside foot to make contact with the feed dog. The results should be the best combination of lift between the inner and outer feet, in sync with the vertical motion of the needle. This should also cause the needle to pull out of the leather while the inside foot is still holding it down, preventing skipped stitches from lifting leather at the point of the lockstitch formation. The inner foot delay should also help stabilize the position of the leather so it doesn't move back as the needle ascends. -
Looking for this part in video!
Wizcrafts replied to DavidMillsSaddlery's topic in Leather Sewing Machines
I'm pretty sure CowboyBob can get you a race cover and a cover plate. -
I was responding to the feet not meeting the feed dog with the needle. You asked that on Thursday. I didn't realize you already solved that problem. -
If you bought this machine (and motor) from Techsew it may still be under warranty. If so, contact them about getting the motor replaced and for tech support with any stitching problems you have been experiencing. In the meantime, unplug the motor and let it set a while. If there is a fuse, check to see if has tripped or blown and replace it (you probably got a spare fuse with the paperwork). Then plug the motor back into the AC outlet and see if it has reset itself. If a new fuse pops, or fails to reset the motor, contact Techsew for a replacement. If your machine is out of warranty, there are other servo motors you can install.
sewing machine cuts thread when stitching (juki 5550)
Wizcrafts replied to beltbuckles's topic in Leather Sewing Machines
Sometimes, the top thread getting sliced is because the check spring is either not threaded correctly, or is not adjusted to keep the thread taut until the needle pierces the material.
