If somebody is willing to pay $500, go for it! Sell it on Craigslist to a budding upholsterer.
The maximum needle size is determined by one or more factors, including: the diameter of the hole in the feed dog or throat plate and the position of the hook in relation to the scarf in the needle and how far it can be moved and remain in time. Those are physical limits. Additionally, there are thread handling limits that apply to any given sewing machine. Some machines have stronger or weaker take-up levers and crank shafts in the head. Some, if not most upholstery grade walking foot machines are built with an upper thread size limit of #138 (T-135) bonded thread, which has a breaking strength of 22 pounds. If that machine is threaded with #138 thread on top and in the bobbin, that is its safe design limit. Coincidentally, that thread combination calls for a #23 (Metric 160) needle. While those machines will operate with #138 thread using a #23 needle, they are happier running #69 or 92 thread with a #18 or 19 needle, respectively. All of the stresses are reduced with thinner thread and needles.
Cobra Class 26 Tension with 138 Thread
Wizcrafts replied to broncopeters's topic in Leather Sewing Machines
If you aren't already doing so, use a #23 needle with #138 thread, top and bottom. -
Is this Leather Belting for a sewing machine?
Wizcrafts replied to RWL2's topic in Leather Sewing Machines
What you want is a leather belt hook, like this one. -
Stitch Length HELP needed Consew 287R
Wizcrafts replied to CustomDoug's topic in Leather Sewing Machines
You can use the freeware Faststone Photo Resizer to reduce the file size for use on forums with filesize restrictions. -
Skipped stitches with stretch knit fabric
Wizcrafts replied to Gymnast's topic in Leather Sewing Machines
Try to increase the slack thread using the check spring adjuster, There are three adjustments available, depending on what type of check spring system your machine has. The style with the most adjustments has the spring inside rotating disks under the top tension disks. They allow for spring tension (loosen a set screw and use screwdriver blade to tighten or loosen the spring), spring travel (via a curved stop bracket on the bottom of the spring) and a curved slot adjustment to fine tune the amount of extra thread that is allowed on the downstroke. By playing with the check spring adjustments you can get a larger, longer lasting loop for the hook to pick off. -
Different Needle sizes for same thread?
Wizcrafts replied to Memphis514's topic in Leather Sewing Machines
No. I use a #25 needle with #277 thread. A #24 needle hole is too tight to let the knots come up easily in veg-tan leather. You would have to really crank down the presser foot pressure screw and crank up the top tension, and/or lower the bobbin tension. -
I would only use an oversize #230 needle if the bottom of the hole healed up before the knots can be pulled up. This might happen on Biothane harness or heavy webbing straps. For instance, I occasionally get hired to sew vehicle tow straps that are 2 inches wide and about 1/4 to 5/16 inch thick along the overlap. I use #346 thread with a #26 needle to offset the hole bottom closing up. This makes it easier to pull up the knots and center them in extremely dense material. -
If you advertise the Singer 251 as a tailoring/dressmaker's machine it may sell fast. Dressmakers like to sew fast and that machine sure can lay down fast stitching.
The double needle walking foot machine can be operated with one needle and is capable of sewing leather, vinyl, canvas, denim, webbing and fire hose. The 251 is a bottom feed tailoring machine and not for leather or hoses. If you bought the 251 you made a mistake.
They will be metric thread. Contact an industrial sewing machine dealer to get the right parts. Don't ruin the threads to save a few bucks on local, wrong pitch parts.
If you are hoping for replies to your leather sewing machine question, a photo or video of it trying to sew would be more useful than the landscape photo you posted. As beautiful as the scene is, it doesn't show the machine. A close-up of the hook as the needle begins its upstroke would be most useful.
The Juki LU-563 has a double standard capacity bobbin and compound feed walking feet that allow it to sew 3/8 inch. The Singer 29k60 is a shoe and boot uppers patching machine that has a half standard capacity bobbin and top feed only. It maxes out between 1/4 and 5/16 inch of medium temper leather. As for stitch length, the Juki will probably give you at least 4 to the inch while the 29k may give 5 to the inch at best. and less if the feed motion crank is worn out. Both machines top out with #138 bonded thread using a #23/160 needle. This size thread has a breaking strength of about 22 pounds. Other incidentals that will probably come up are the fact that the Juki takes all manner of presser feet, including those with spring edge guides and piping feet. There is no such foot or attachment for a patcher. You may have a hard time sewing a straight line without an edge guide on a top feed patcher. IHTH
Your question is too open ended. You haven't posted a sample of the type of shoes you make that you want to start sewing on a machine. I can tell you that there are some specialized sewing machines that are used to produce shoes that aren't used in general leather work - and vice versa. Once we see some photos of your shoes we can offer our opinions about sewing machines that will speed things up.
Looking for a postbed sewing machine for sewing bags
Wizcrafts replied to Parfektionisto's topic in Leather Sewing Machines
Juki is mostly made in Japan and they certainly have post machines. Because they are so well built they last a very long time and the price reflects that fact. Your other options for European built machines include Pfaff and Durkopp-Adler. USA built industrial sewing machines are few, purpose built and expensive. USA modified is another story. The are quite a few dealers who will modify industrial sewing machines to meet a specific requirement. We used to have Ferdinand and Luberto industrial/leather sewing machines made in the USA, but they are long out of business. There are other ancient design American made sewing machines that were specific to the harness, gun leather, saddlery and luggage trades that can still be found used or rebuilt. They are extremely heavy, hard to master and parts can be extremely expensive, if available at all. -
Singer 29K58, 29K62, 29K71 Instruction Manual
Wizcrafts replied to Constabulary's topic in Leather Sewing Machines
All I have is this manual for the Singer 29k71, 72 and 73. I hope that helps you. 29k71-71-73 Service Manual and Parts List.pdf -
I see you're located in:Singapore. You could contact CowboySew/HighTex to see if they have a dealer in or near Singapore. They make post bed, cylinder arm and flat bed sewing machines in your part of the World. The have various types of feed, including compound feed. -
Reading the operating instructions I saw that your machine uses either DBx1 or System 134 needles. It depends on the diameter of the bore in the needle bar. I would try the DBx1 first. If the shank is too loose the needle will be off center. Then you could try a System 134 needle.Stay with the best fit and fine tune the needle bar height for the best pickoff.
The Sailrite machines are meant for sewing canvas, Sunbrella and vinyl materials. They are dual feed, with teeth on the feet to assist with the top/bottom feeding. The maximum thickness they can sew is 1/4 inch, with up to #92 bonded polyester thread (maybe even #138). If your projects fall withing these specs the Sailrite may be a good solution for your limited space. Because these machines are built to stand up to sewing soft vinyl and cloth, they may be over stressed by leather. Leather has resistance to the needle and thread. The bottom of the needle hole tends to close slightly as the needle ascends. So, you may need to use one size larger needle when sewing leather. This adds to the work load on the take-up mechanism. You should use leather point needles for leather and round point for cloth and synthetics. There is one more factor to consider if you buy a portable walking foot machine. That is punching power. Leather requires more punching power and the basic setup of these portables doesn't provide that much. You may need to upgrade from the Power Plus wheel to the Monster II balance wheel to get the necessary torque. That adds $125 to the price of the machine. The teeth on the bottom of the standard feet will leave marks in leather. you may need to upgrade to the knurled presser feet, which they sell for ~$32. By the time you are through upgrading a portable dual feed walking foot machine you could probably have bought a Consew P-1206RB industrial compound feed walking foot machine.
Is the needle going through the center of the slot in the cover plate? If not, the needle bar may need to be loosened and turned slightly. However, this will change the alignment of the needle clamp and thread guide. If the needle is already centered, then the shuttle assembly position may need to be tweaked to clear the needle.
Hook problem “CowboyMachine” clone
Wizcrafts replied to Onlyintheaters's topic in Leather Sewing Machines
I recently bought a 3/4 inch swing out single fold edge tape attachment on ebay and am waiting for a spare bobbin cover sliding plate to J.B. Weld it to. The mouth of the folder (business end) is fairly wide and looks like it can handle almost 1/4 inch combined edge thickness. I will report back once it is mounted and I try it out. The edge tape I bought for it is fairly thin polyester (looks like the equiv of 1.5 ozs). It looks like it can feed leather edging too as long as is thin enough to go thru the bent channel in the binder (guessing about 2 oz). There are certain folders that are extra wide for edging carpeting. I haven't gone there yet. All of these folders are made to feed slippery edging, like cloth, nylon and polyester. They slide through with little resistance compared to leather than may be sticky. Double folders are trickier than single folders with almost any material. -
Actually, I proposed to the Admin that we create a new sub-forum for members to discuss old domestic sewing machines. I have a couple myself and until last year I refurbished and sold old iron body Singer home machines. I will let you all know if or when this new forum is created. Until then, feel free to continue this particular discussion.
It may be time for a new sub-forum for discussing domestic sewing machines. This forum, as the label suggests, is for industrial leather sewing machines. The Singer 15-91 is a domestic straight stitch sewing machine for cloth.
These all have 4 motion feed dogs. This is also known as drop feed and it is pretty much the standard feed system in both walking foot and straight stitch machines. Sliding feed is non-standard and is only useful on binder machines. Otherwise, it is an impediment in my opinion. Those who already have such machines either learn to make do with the sliding feeder or sell them off and buy a 4 motion feeder machine.
