Everything posted by KnotHead
Believe it or not and no disrespect or anything like that toward anyone. I will sometimes be going through my books and looking at different knots. Then I will be sometimes looking through other braiders photo galleries. Then I start to thinking into the wee hours of the night and morning and fall asleep and then even have a dream about it. LOL... I use a tool called the Grid Maker to work out all the specifications on the design itself once I have the design worked out in my brain. Brian...
Thank you Fat Dog. Brian...
Thank you Buck for the very kind comment. Brian...
Thank you both for the very kind comments. The knot is a design based on 2 other different knots, or at least the main features of 2 other knots. It took me about 3 days and long hours of no sleep hardly because that knot kept me awake. LOL... Brian...
Just doin a bit of playin around. This key fob has the traditional trenza de doce braid with the iris knot. 13parts by 8 bights with an Over 2 on top and an Over 3 on bottom. Brian...
Okay. I'll come back for more punishment here. I'll offer up the below. You should be able to wrap this around an appropriate sized mandrel. Here are the instructions to follow. from bottom pin 1 to top pin 7 from top pin 7 to bottom pin 14 from bottom pin 14 to top pin 20 from top pin 20 U1 to bottom pin 6 from bottom pin 6 U1 to top pin 12 from top pin 12 U1 to bottom pin 19 from bottom pin 19 U1 to top pin 4 from top pin 4 O1 U1 to bottom pin 11 from bottom pin 11 O1 U1 to top pin 17 from top pin 17 O1 U1 O1 to bottom pin 3 from bottom pin 3 O1 U1 O1 to top pin 9 from top pin 9 O1 U1 O1 to bottom pin 16 from bottom pin 16 O1 U1 O1 to top pin 1 from top pin 1 O1 U2 O1 to bottom pin 8 from bottom pin 8 O1 U2 O1 to top pin 14 from top pin 14 O1 U2 O1 to bottom pin 21 from bottom pin 21 O1 U2 O1 to top pin 6 from top pin 6 U1 O1 U2 O1 to bottom pin 13 from bottom pin 13 U1 O1 U2 O1 to top pin 19 from top pin 19 U1 O1 U3 O1 to bottom pin 5 from bottom pin 5 U1 O1 U3 O1 to top pin 11 from top pin 11 U1 O1 U3 O1 to bottom pin 18 from bottom pin 18 U1 O1 U3 O1 to top pin 3 from top pin 3 U1 O2 U3 O1 to bottom pin 10 from bottom pin 10 U1 O2 U3 O1 to top pin 16 from top pin 16 U1 O2 U3 O2 to bottom pin 2 from bottom pin 2 U1 O2 U3 O2 to top pin 8 from top pin 8 U1 O2 U3 O2 to bottom pin 15 from bottom pin 15 U1 O2 U3 O2 to top pin 21 from top pin 21 U1 O2 U1 O1 U2 O2 to bottom pin 7 from bottom pin 7 U1 O2 U1 O1 U2 O2 to top pin 13 from top pin 13 U1 O2 U1 O1 U2 O2 to bottom pin 20 from bottom pin 20 U1 O2 U1 O1 U2 O2 to top pin 5 from top pin 5 U2 O2 U1 O1 U2 O2 to bottom pin 12 from bottom pin 12 U2 O2 U1 O1 U2 O2 to top pin 18 from top pin 18 U2 O2 U1 O1 U3 O2 to bottom pin 4 from bottom pin 4 U2 O2 U1 O1 U3 O2 to top pin 10 from top pin 10 U2 O2 U1 O1 U3 O2 to bottom pin 17 from bottom pin 17 U2 O2 U1 O1 U3 O2 to top pin 2 from top pin 2 U2 O3 U1 O1 U3 O2 to bottom pin 9 from bottom pin 9 U2 O3 U1 O1 U3 O2 to top pin 15 from top pin 15 U2 O3 U1 O1 U3 O2 to bottom pin 1 Now when you complete this. You should be able to add the stitch to the center piece quite easily. Outside of this I can't do anymore. Brian...
No I don't think so bro.
Well at any rate I think I'm about secluded with this topic. So attached is a grid representation of that knot. It might not be exact because I can not get an accurate count of the parts or bights from the damn photos. Good luck... 11parts by 21bights - Ginfer Now I go back to get some of my own braiding done. B...
What promotions are you talkin about?
Well let's see if you can make this ginfer knot from these pdf files. If you can make this one you should be able to stitch around the one in the pdf file. Attached: Illustration pdf GinferKnot9x8.pdf Written Instructions. GinferKnot9x8Instructions.pdf Brian...
I don't think that it has to be the same as the one you see pictured. You should be able to work that stitch into any sized ginefer knot. Brian...
Yep. It's a Ginefer knot. Brian...
A tutorial on that. It was too large to upload to here. Zip file contains a pdf document. http://www.khww.net/books/GauchoRingKnot-RingOfSaturn.zip Brian...
Can't get the photo to show up. Please insert the photo here so we can see what you're takin about.
I'd run a core for a few inches or so. This will give the braid some static to hold the dropped strings in place.
I agree with Sovarn on the account of, it's easier to drop strands than to add.
Let me see if I'm getting this picture right. You need a flat braid 4 inches long by a 1/2 inch wide? Correct? Then you need to go back to a 4 strand round braid? Correct? How's this all going to come together at the point of the round braiding? Is this one of those leads you put through a loop, like a cinch type lead, or something else you have in mind? I would consider doing a 6 strand flat braid and then dropping enough strands to do your 4 strand round braids. Brian...
What are you trying to make Tracy?
I think I'll stick with the color that I got on this. I kinda like it and it will pop with the natural against it. Take a gander at the dyed lace. Natural The Columbian Coffee as dark as I could get it. (STRONG TOO) LOL... After 24hrs in the container. Brian...
Thanks all for the replies. I do appreciate the help. Brian...
Thanks. But we'll see if he likes the idea of that kind of work... It's pretty when done though. Never done any of that yet myself. Brian...
Quill braiding(a lot like embroidery) is another option I would consider. Might take a bit longer to do that type of job. But it will garantee that the leather will sit down and behave itself like it should. Brian...
If you have Ron Edwards book Round Knots Advanced Leather Braiding volume 2. He give a good show of a braided knife sheath.
