Everything posted by Bob Blea
High Contrasted Antiquing On Natural Colored Leather
Bob Blea replied to addieleigh's topic in How Do I Do That?
I should have mentioned, if you use Fiebings Antique, you can do the same thing by wiping it with Tan Kote. I've seen it remove darkened streaks in antique very easily and leave a finish just like you your picture. So whichever product you use for antiquing, there is a way to wipe it back off and get a very smooth effect on the untooled leather. Also I should add that both wallets in my picture are a little darkened but that is mainly because the leather I was using had a bit of russet coloring to it plus I oiled them with Neatsfoot, which darkens them slightly. -
I can get this kind of effect just with a couple of coats of resist (Wyosheen) and a coat of Eco Flo gel antique that I quickly wipe off. I've started wiping with unscented baby wipes to remove excess because it seems to do a good job removing streaks. The two wallet pieces below were both antiqued that way. -
First Handbag
Bob Blea replied to LederRudi's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I guess you now know the next area of bag construction you are going to work on! -
First Handbag
I think those all look very professional. I'm sure your wife is very proud of that bag. -
Card And Coin Holder
Bob Blea replied to Petewon's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
That looks great! -
2 Unseen Stohlman Saddles - A 3 Year Post!
Bob Blea replied to PMAZZIO's topic in Saddle & Tack Maker Gallery
I remember your original post too. Thanks for taking the time to post these pictures. It's great to see them. -
For a first time stitching I don't think your work looks bad at all. You might be right about too big of holes, it's a little hard for me to tell. Thanks for sharing the pages from the home course. That looks like a treasure to me but then I love old books.
I always put a very light coating of oil on my notebooks after tooling. I don't find that my leather gets noticeable softer unless I put a lot of oil, and since I keep it very light they seem to hold the same firmness over time. I just put a little warmed neatsfoot oil on a cotton ball and gently rub it over the piece and then let it set, usually overnight. The leather returns to nearly the same color the next day. If the leather darkens significantly and stays that way, you've used too much.
Dye Edges How To Avoid Getting Dye On The Grain Or Flesh Side?
Bob Blea replied to DavidL's topic in How Do I Do That?
Bob Park sells refillable pens that are basically large felt tip markers. You can put your dye in the pen and use that to dye the edges. I don't do this very often (read almost never) because I lace my items but if I was to do this often it's probably how I would do it. There are times that I want to darken the leather under the lacing so it doesn't contrast with the lacing when/if it shows through and to do that I use a sharpie. It works well and I find it very easy to control. -
Hello Joanna, and welcome to the forum! A general rule of thumb is that you was to cut about half way through whatever leather you are using, so on thin leather you can't cut very deep nor can you get the deep tooling relief that you will on thick 8-10 oz. leather. I typically tool on around 4 oz. leather but I have done a little thinner. What weight of leather are you using? The knife does make a big difference. It needs to be very sharp to make good cuts. If it is a Tandy knife it likely didn't come sharp enough to cut well. At the very least you will want to strop it regularly to keep the cutting edge polished so it will cut better. The Leather Tools section has some tips on sharpening in general and there is some very good information there. Keeping a swivel knife sharp is a definite skill and one worth learning, but it does take effort to learn. Bob
What Kind Of Leather Should I Use For Padfolio?
Bob Blea replied to Beardedbandana's topic in How Do I Do That?
Something else to consider: You could go with a softer leather to get a more luxurious feel if you use a stiffener behind it (say a thin sheet of plastic or cardboard) and then line the inside with another layer of leather. -
Hi Andy, It would be hard to select a leather like that for a project without having a sample to gauge the feel and firmness for it. Have you tried contacting Tannery Row or Wickett and Craig to see if they can send out samples? Usually they will have small pieces of leather they can send that you can use to decide if it meets your requirements. Springfield would probably be happy to do the same. And of course if you have a Tandy nearby you can visit them and inspect the leather, though I don't know what they have that would be like this. I make notebooks like that but I've never tried to use that sort of leather, just veg tan. -
I would be curious how to do this too. Do you need to remove the decorative trim around the edges to secure the leather beneath them? Springfield Leather probably can provide the leather you need. What kind of leather are you looking to use? Will it need to be tooled?
Quick Card Wallet
It looks very good! I like how you finished your edges. May I ask how they were done? -
Binocular Case
Bob Blea replied to Otto6294's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
For all the struggles I think it turned out very well. You're right it was a great learning experience. -
Nice collection! I think the tool you were asking about is a Tandy stitch groover, but a close up picture would help. That home study course looks amazing. It would be cool to see what is inside.
- 4 comments
- handmade in u.s.
- custom purse
- (and 4 more)
From the album: Sheridan Style Floral Purse
This is the back of a custom ordered floral purse I made. The lace is red kangaroo lace and it was my first project using it. Contact me for more information at my Etsy shop: http://www.etsy.com/shop/CandBLeather?ref=si_shop-
- handmade in usa
- northwest style
- (and 4 more)
This was a custom ordered floral purse I made. The lace is red kangaroo lace and it was my first project using it. Contact me for more informationat my Etsy shop: http://www.etsy.com/shop/CandBLeather?ref=si_shop- 4 comments
- handmade in u.s.
- custom purse
- (and 4 more)
This was a custom ordered floral purse I made. The lace is red kangaroo lace and it was my first project using it. I now understand why people like it so much. Contact me for more information at my Etsy shop: http://www.etsy.com/shop/CandBLeather?ref=si_shop-
- handmade in usa
- custom purse
- (and 4 more)
I would go with something acrylic on the back to seal it, like Resolene. That would lock in your pigment but also help prevent sweat and oils from the wearer from getting into the leather.
Preparing Leather For Tooling Even Before Casing
Bob Blea replied to whimsicaldragon's topic in How Do I Do That?
Welcome to the forum Lena! For your first question, I don't do anything to my leather prior to casing except to keep it out of the light as much as possible. Veg tan will darken in direct sunlight but even indoor lighting will 'tan' it over time. After casing and tooling I will then sometimes clean it with a weak Oxalic acid solution if there is something on it. Many people do this step automatically on every project to remove any oils or dirt their hands have transferred to the leather but I haven't had it be much of a problem in my work space, so I don't do it every time. The first time some sort of finger print ruins my antique I will probably make cleaning a standard step! For your second question, I don't have a good answer. I know some of the members of this forum do provide recommendation to the long term care of their products but it does probably depend on the finish and what the item is used for. Hope this helps a little, Bob -
Some pictures would definitely help. Are there any spots where the grain has worn away?
If your flex shaft tool has variable speeds start off at the low end. It's easy to over burnish the edge giving it a ragged or burnt look. As always practice on some scraps. Same with all those tools. Sounds like you are getting a nice collection.
