Everything posted by Ferg
First off....Strop the blade for about five minutes. lol Also, did you temper your piece of leather properly? Some of those blades aren't too bad but quite often need sharpening before stropping. I prefer metal. If you have the funds, buy an American Made professional swivel knife, it will be cheaper in the long run. Ferg
Looking for a patch machine
Ferg replied to T Moore Medicine Hat Saddlery's topic in Leather Sewing Machines
Nice impression Mike. I love Buffalo as well as Baby Buffalo. Ferg
IPhone Wallet in Embossed Alligator
Ferg replied to YinTx's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I use the Velcro with adhesive already on the back side of both pieces. I cut the strips 3" long, they are 3/4" wide. I have actually removed the Velcro after some weeks from the leather as well as the plastic case. Mostly to see what damage was done to either which was very little. Ferg -
I get the plastic cases to fit whatever phone. Use velcro to attach the plastic to the leather inside. Never moves and you can take the phone out anytime you wish and snap it back in. My leather case has a partial "Wrap-Around" with a snap. Leather case protects the entire phone when closed, everything accessible when open. Ferg -
Need help finding this piece of hardware please
Ferg replied to timesofplenty's topic in Leatherwork Conversation
This is strictly an observation. I don't like the end of a strap "hanging" from a fixture. They get caught on everything plus I feel they look unfinished. A clever leather loop with some little decorative flourish will hold that strap better. Ferg -
Any ideas what rotary edge paint tool is used in this video?
Ferg replied to tossik's topic in Leather Tools
There seems to be a lot of these with a little different configurations "Out there". I have three or four different applicators, a couple just like the Tandy that I received free. The tapered Tandy style is the best in my opinion. I can do the edges of a complete dog harness in 20 minutes or less, that is one application of material. I do a sealer plus two coats of finish. I do not use the heated edge units. I think my edges are as good or better than some I have seen done with them. Just my .02 Ferg -
Looking for brown iron headstall buckles
Ferg replied to T Moore Medicine Hat Saddlery's topic in Suppliers
You might be held to "Allibaba" for those. Ferg -
You can likely get a small blade to fit one of your knives, wouldn't need to buy the handle. I began leather work almost 65 years ago although I didn't continue it all that time. Marriage, babies, business other than leather. lol I used the method above all the time then when I got on the forum I tried some of the other ways, they just didn't work for me. Hope this works for you. Ferg
stormdevil I want you to try this method of tempering your leather. Soak a trial piece in warm water until the bubbles stop. Using an old terry cloth towel roll the towel around the leather allowing it to roll with the towel. If you do this in the evening, wait until next evening to unroll towel and leather. Leather should lay flat without any problems. The leather should appear like pie dough in texture. If you press a finger tip into it, you should have an impression. That is when it is ready to carve. I have never tested any of my swivel knives with cutting paper. The bevels on the blade should be exactly the same angle. When doing fine work you should use a blade that is relatively thin and about 1/4" in width and angled not straight. Strop the blade after you make several cuts. Do that continuously while doing the design. You should find that the thinner and narrower blades will work better with lots of stropping. BTW: Don't put the towel in the fridge. Leave the roll lay on your work bench or similar area in normal temperature and humidity. Please let me know if this helps with your situation. Ferg
Gump, I think you are going to get some flack on that statement. These oils are not the same and 3 in 1 oil will gum up a sewing machine even if you have been lucky enough to use it with no problems you know of. Ferg
Eric, When I got out of the Navy I worked for a remanufacturing company for electronic radio equipment for the government. We ran out of little "disc" capacitors one time. I checked the specs and went to my electronics supplier. The non-government capacitor was .0001 mfd. different than government issue which wouldn't be available to us for possibly several months due to manufacturing difficulties. The government would not allow us to use what was available locally in the thousands, simply because it wasn't exactly the same. Capacitors used in electronic equipment in those days could be within 100%. Oh Yeah, I could buy them for a tenth what this company was paying for them. BTW: Semi Trucks hauled radio gear into the Airplane Hangar we occupied, 50,000 pieces at a time. Most had a single power resistor burned out. They would only allow us to repair a certain number of them each day. Ferg
I might be missing something here, your response to danielw88 was way off base. Ferg
Keep in mind, if anyone says they want the machine before July, it will be sold. Thanks for your interest. Ferg
Mark842 Looks as though I would have to have $200 - $225 to ship to you. That doesn't include Insurance. I gave $1500 for the machine, you would still be getting deal. lol
Mark842, This machine weighs about 90 pounds without the table and servo. It would need to be "Crated" and packed with impact resistant foam board. That also means I would need to break the legs/table down and pack them separately. Since I have no idea what your area code is I can't give you a figure on the shipping. I will help you all I can, shipping these things is expensive. Ferg
I have used the skiver for 1.5mm to 2mm plus much heavier veg tan. The thicker leathers may need to be run through more than once. The Cowboy and several others are identical except for the name on them. LOL No one should tell you that learning to use a power skiver is easy. Not for the faint of heart. Your eventual results will make a believer out of you. If you do not have a good supply of scrap leather to practice with, go to a Tandy store and buy a bag of same. Chrome tanned as well as veg tan. Ferg
Yes it is.
I placed the problem with PayPal. Day or two after, the owner e-mailed me the address to return the hide to. Done that, had the tracking number of course so I checked delivery which was made this past Monday. He verified it yesterday, I got my refund on PayPal this morning. He sent me another e-mail telling me how nasty I am etc. and that he wouldn't sell anything else to me. Do you suppose he may have even thought I would buy anything else from him? Anyway, another lesson learned, I have my money back and he has his piece of crap leather. Ferg
I seldom bite on anything from this particular type of seller. He is close enough to me to save on shipping so I thought I would take a chance. MY BAD! I use quite a lot of Kangaroo. Love the leather. I have bought some from reputable dealers I wouldn't give my dogs to chew on. I have been buying leather etc. for enough years to know most of the time, if a deal is a deal. I appreciate everyone's comments. I sent a note to him through PayPal a couple days ago. I received an e-mail from Michael this morning with his shipping address. Will let everyone know if I get a refund. Ferg
We have owned a business that sells many thousands of product to folks all over the world. In forty years we haven't had to refund on a product more than half a dozen times. If someone has a problem, we refund or send a new item free of charge and do not ask for the item to be returned. Ferg
Well, I am afraid this is going to be another of my very few bad encounters with suppliers. I ordered a Latigo side priced at $125. Now I have been around long enough to know that I should not and do not expect this to be a top of the line hide, this one is a piece of junk. It has stain blotches all over it plus for Burgundy it is more just ugly brown. My wife tried to call him today and no one answered the phone. I sent him another e-mail saying: "Anyway, are you going to honor the refund? I have no problem with paying the shipping for the hide to be returned to you." I got an e-mail this evening saying he felt my e-mail was "Nasty" and he wasn't going to answer me. I have no recourse but to take it up with PayPal, I paid with them. Ferg
Has anyone bought leather from http://kentuckyleatherandhides.com/ I ordered and received a hide from him I wish to return and be refunded to me but I cannot make contact with him. Sent him a couple e-mails and tried phoning to no avail. I know he has limited hours but do not know what they are. Any enlightenment appreciated. Ferg
Bobbin Storage! What works for you?
Ferg replied to JerseyFirefighter's topic in Leatherwork Conversation
I bought a couple small plastic boxes at JoAnn Fabrics, about 5" x 10 3/4" x 1 3/4". They have plastic latches on the lids. I used a Forstner drill bit slightly greater in diameter than the bobbin diameter, to drill a row of holes through a piece of pine 1 1/2" x 7/16". I then used my table saw to rip the pine in half directly through the middle of the holes. Spacers between the rows of bobbins is 1/2". I used small pieces of pine as fillers in the ends. I know everyone doesn't have a wood shop, I bet a lot of you have a friend with some woodworking tools that would help you out. I tie the ends of the thread on the bobbin through one of the holes in the bobbin side. You can see in the photo which ones are the first I done. Ferg
