Everything posted by Ferg
Just enough to get the shiny smooth edge. ferg
How bout around 1200 to 1500 rpm. Works for me. ferg quote name='Chavez' timestamp='1340226853' post='253416'] Hi sixer, If I hold the burnisher for to long, yes, I could feel the burn. I thought it was part of the process :brainbleach: Like you can't have a BURNisher without some burn =) Would recommend dropping the rpm to 5k?
Switched Out Clutch Motor For Servo - Not Really Happy.
Ferg replied to JimC's topic in Sewing Leather
I have a Consew servo on my 206RB5 with a reducing pulley, have no such issues. You do realize there is a control knob on the end of the servo to change speed etc. I set mine about mid-way to sew maybe ten stitches per, I don't like sewing leather real fast. Barely pressing my foot on the pedal will create very slow stitching as in 1 stitch per. Full pedal will do the 10 but your work up to it. BTW: I don't think there is a clutch in the Servos ferg -
We are surmising the mother has gotten herself killed on the road. These little guys are probably looking for some food. They are about the size folks use to keep for pets. They definitely followed my voice. Now! What do I do with our collie that has been sprayed several times in the past? She will probably be spending some extended time inside the house. ferg
I grow my own vegetable and flowers from seed in my greenhouse. I just finished planting the last of 2000 annuals yesterday. Have about 4000 flowers in our yard including the perennials. That, my friend will keep you from "burning out" on leather. ferg
Sixer, Did you see the original post I made with the photos? What other info would you like? ferg
Wiz, Just put kwokhing in Google. Ferg
Some things I simply cannot resist. These little guys are across the road from our home under the neighbor's home. Four of them about 10 or 12 inches long. As I took photos of this little guy he started coming toward me until I decided enough was enough, they are old enough to "Spray". ferg
Wiz, Could part of his problem be "Too small needle" ? ferg
Jon, I have a trailing "Little Finger" if I don't keep it out of the way when tooling etc. I get little swirled marks. Slightly dragging a tool when you lift it, a straight edge, O'boy! there are many others. Observe closely how you use your tools, that will probably tell you more than anything. Hang in there. ferg
Bruce, You are correct the one I had was a 5 in 1. I refurbished it with intent to sell it which I did. Thus, my slightly vague comments concerning part of the machine. Have trouble finding my way home sometimes so any loss of memory is normal. LOL ferg
I am not one to suggest machines in your list. That said, true to several posts on this forum, searching the archives for what you want is a little intimidating. Most every machine revued/sold by member dealers is top notch. Obviously there are a number of different machines that will do different things better. When looking for a heavy machine you should be looking at 441 clones or similar machines that will sew 1/2" thickness of hard leather at least. Remember, most of the heavy stitchers will not sew thread below #138. ferg quote name='StNicky' timestamp='1339347500' post='251984'] I have searched around a little, and read and reread everything I came across re best machines including Wiz's invaluable series re the basics of a good leather machine.....BUT...I guess because of the advertisers.....I can find no list of all the brands and different models thereof that are suitable for heavy leather work and which are the most highly rated. Does anyone know of such a list? I would be glad to assemble such a list- Brand/Model/feed/max sew thickness/durablility/and some other important aspects, if the members want to nominate all the machines they consider qualify as an industrial strength leather capable sewing machine.
Bruce, The three functions are as follows. Skiver for soles so the shoe sole thins at the heel, trimmer for trimming shoe soles after the sole had been sewn, and I just had one of my many senior moments and cannot remember the name of the apparatus on top. It is used to press the edge of the shoe sole together. I tried it, really worked.Also, the sole trimmer is used to cut the blank for the shoe sole. Pretty much makes it a 4 in 1. LOL Mine was a Landis, I am sure had Memphis on it for manufacturing site. ferg
As you can tell from the photo I sent previously, my 3in 1 was not configured this way. I think the one I had was made in Memphis. Does that sound "kosher" ? ferg quote name='bruce johnson' timestamp='1339349837' post='251986'] I am starting at new thread on comparing two crank skivers I have with pictures. The American is my own user and a Model B with a 2-1/2" blade. The hand lever will open the gap between the rollers. This skiver I modified. The top wheel was milled originally. I took the teeth down to make it smooth. The blade angle adjusts with two eccentrics. One is under the hex head bolt to the left of th etable in the rear view of it. The other is under the lower slot head bolt to the right. Loosening the bolts and then turning the eccentrics changes the balde angle. There is a view with the blade leveled for splitting too. The Landis is one I just got. It has a 1-3/4 blade. The blade angle is adjusted by the hex heads in the slots - two on the left and one on the right. This one will level up too.
Bruce, I fiddled with mine a number of times trying to get it to cut level to no avail. It had a bolt that tightened the blade. You loosened it and turned an eccentric to change, retightened the bolt to use it. i bought a new blade for it but it would not handle chrome tanned that I had very well. The serrated roller was worn on it somewhat, cleaned and done some re-adjusting, it worked fine. I tried it on a piece of leather about the thickness of a shoe sole, it skived the edge perfectly. ferg
Bruce, The 3in1 I rebuilt had adjustments on it that would not enable flat even thickness skiing. The adjustment was actually eccentric. My understanding, when I spoke to a gentleman at Pilgrim, the skiver was intended for shoe work, explicitly the sole. That of course doesn't mean it couldn't and hasn't been used otherwise. The unit I rebuilt was a Landis. ferg
I think you have a Skiver not a splitter. The blade will not cut level/flat edge to edge. Adjustments on the little table make it skive a different amount from the edge of the leather. This is what it looks like to me. I rebuilt a 3 in 1. ferg
Ghost Riders STAGE COACH ROBBERY Telecaster BACK DAY 1
Ferg commented on chancey77's gallery image in Our Leatherwork Galleries
We ship thousands of packages, very few via UPS. They have gotten so expensive we just ship USPS (Post Office), First Class and Priority. They provide free boxes. I do know, the UPS Stores charge a premium. I think it is 35% above standard charges. Your $52 seems out of "Kilter" for sure. ferg
I don't have a Cobra or 441 clone of any kind but I do have a Consew 206RB5 and a Seiko CW8B1. Consew is a Flatbed, Seiko a cylinder arm. Wiz is familiar with both machines. The Consew came from a dealer in California. I requested a Servo Motor which works perfectly for me. I also have a speed reducer on this machine, couldn't do a darn thing with it if I didn't have the reducer. I can slow it down to one stitch at a time or let it run like a rabbit, it is 3/4 HP. This machine will sew 3/8" thickness with no problem. The Seiko came from Bob at Toledo. One of Bob's Servo motors. Wiz told me to set the speed dial in the middle, that works perfect for me with one exception, when sewing 1/4" of leather I need to increase the speed dial some so I have enough torque. Part of the time I have to give the wheel a quick pull for it to sew and still be slow as I wish it to be. If there is any difference in these two Servos at all, the one on the Consew may be a little bit more powerful. If I was doing leather work for a living I would certainly have one of the "Professional" Servos. Just my .02. BTW: I have communicated with Wiz frequently as well as talking with him personally while at Toledo. I have learned more than I could have imagined from Wiz and Bob. They have never hesitated to answer any of my multitude of questions with expert guidance. I am also sure that Steve, Ronnie, Greg and all of the remainder of dealers and professionals have the same mind set. ferg
That looks like a speed changer to my old eyes. Some I remember had a trigger like apparatus that made the belt move from one size pulley to another. ferg
You will find the self centering punches in woodworking catalogs as well as metal working catalogs. The punch actually slides inside of the barrel. The end of the unit is made so it centers in a hole. http://www.garrettwade.com/product.asp?pn=35K08.01&ch=10S09.09&EID=W6061011&SID=W6061011&utm_source=googlepla&utm_medium=cpc&gclid=CPmf5qTEqLACFUMCQAodTyDXUQ http://www.amazon.com/Stanley-58-013-Self-Centering-Screw-Punch/dp/B00002X1YB I have one of the Stanley punches. Have had it for 40 years, use it occasionally in the shop, works fine. I believe an Ace Hardware or possibly Lowe's, Home Depot, or Menards would have them. ferg
Don't mean to make your day bad, we carry $2,000,000 liability. Have never in 35 years needed it but I can only imagine what would happen if some idiot decided to sue and we weren't covered. Your cost may be decided depending on your yearly sales, ours is. ferg
I guess that could be from a "Paint" but somehow I doubt it. Looks more like "Hair On" cowhide. I certainly have not seen every hide that has been tanned but I don't believe I have ever seen Horse hide tanned with hair on. Learn something every day? ferg
The "45 Type" Machines (Ga5-1, Cb2500, Etc)
Ferg replied to ChimeraKennels's topic in Sewing Leather
My experience with most any type of tape used similar to this is the adhesive that stays on the surface of the leather. Best way to reduce the marks, not necessarily eliminate them? Use smooth dogs and/or presser feet. I also use a smooth needle plate with a slot for the needle. Doing this requires lowering or on some machines removal of the feed dogs. If your requirements call for sewing soft leather consistently I would use the smooth feet and slotted plate. The machine will need some adjustment since you do not have ridges on the feet or dogs to move the leather through the machine. ferg
