I use an arbor press from harbor freight as a clicker once in a while. I also use it to do the larger 3d stamps. They work pretty well, but there are limitations, such as size of item. My die is about 2 1/2" x 5" approximately. One thing about the arbor press, if the die is over a few inches you might have to click it in one spot then move it over a bit and do it again. Which for me has worked out fine, you just have to make sure not to lift up the die, otherwise you can mess up your cut and get messed up edges. I've also seen guys using the larger hydraulic presses from harbor freight to stamp out larger pieces.
Chris
