wizard of tragacanth
Contributing Member
Everything posted by wizard of tragacanth
  1. Yes, Chris, you are absolutely correct. It is very unlikely that the dye colors are equivalent to the RGB values. This is just an estimate. We have to start somewhere. I started with my own experiment using Fiebing's Yellow and Navy Blue. This resulted in a decent Olive Green which may or may not work for the intended application. Jeff presented a formula based on RGB values and I converted it to practical dye quantities. There is no guarantee that it will work, but it might. If no one has an actual formula or source for OD dye, these are two places from which to start one's own experimentation. nick
  2. You are contradicting yourself. We are not talking about measuring a belt for fit. Of course, the way that you are doing that is the correct method. We are talking about the the length of the of the belt past the last hole. You are saying that you measure from the last hole, when you said that you never measure from the last hole. So, on your 7 hole belt, the distance to the last hole is 3 inches. Agreed? Then you measure from the last hole for 2.5" to 3" correct? Isn't that 5.5" to 6" from the center hole? Yes??? Like I said, yes? So the OP asked how long should the belt extend past the last hole, without stating how many holes and at what spacing. Isn't it just easier to say 5-6" from the center hole? That way, the same formula is used regardless of how many holes and what the spacing is. nick
  3. Measuring from the last hole does not make any sense. You would need a different formula for every permutation of 5-holes, 6-holes, 7-holes, with 3/4" spacing, 1" spacing, etc. A 5 hole belt with 3/4" spacing puts the last hole only 1.5" from the center hole. A 7 hole belt with 1" spacing puts the last hole 3.5" from the center hole. On both belts, the tip should be 5-6" from the center hole. You may disagree with how far the tip of the belt should be from the center hole (4", 5", 6") but to measure from the last hole just confuses everything. nick
  4. Trust me... Olive Drab IS a color and it isn't made using yellow and black (or gray). What kind of color picker did you use and what was the actual target? Was this a MS Paint color picker used on a computer screen target? Anyway...if we are going with your color picker, it would be almost equal amounts of red and green with some blue, right? Or to be more precise: 37% Red, 38% Green, 25% Blue Or for example -- 1.5oz of Red, 1.5oz of Green and 1oz of Blue. That assumes that you had your color picker on a true Olive Drab. And of course, that depends on the actual value of each of these colors in dye form. nick
  5. Oh, I see... I just went to the Staff tab and PM'd "Administrator". Well, forget about it... doesn't matter, but thanks for your response Fred. nick
  6. I did a quick experiment with Fiebing's Pro Dye. 2 parts Yellow to 1 part Navy Blue = Olive Green May not be exactly what you want, but pretty close, it may help to add a tiny bit of Orange to that. nick
  7. Just wondering. So far, it has been two days short of a month. I hope that I am not stepping on toes by asking this question. I did a search and looked for a FAQ on it but could not find anything. nick
  8. I would add to this, to use more complete or descriptive titles on your posts. Simply saying "Leather Dye" or "Question about Leather Dye" or even "Mixing Leather Dye" is not descriptive enough -- whereas, "OD Green Dye Recipe" works! Someone knows what they are getting into when they click on it. nick
  9. I am completely confused. None of this makes sense. First, there is a confusion of terminology. There is no such thing as a flat-back pancake holster and these terms have been used interchangeably in a couple of statements here. They are two completely different designs. A flat-back holster is flat on one side and all of the molding is done on the other side. A pancake holster (or 50/50) is molded equally on both sides. I'm pretty sure that you want a flat-back holster. An IWB, "Inside the Waist-Band" holster is worn inside your pants. An OWB "Outside the Waist-Band" holster is worn outside your pants. Which will this be? Right now I am thinking -- IWB, but not sure. So, is this flat-back holster that is going to be worn inside the pants on the left side, say somewhere between the 8:00 and 11:00 position? Is the flat part going to be facing in, toward your body or facing out, toward your pants? Somehow, I am thinking that you might want to put this between the belt and pants, and yes this has been done. It uses a wide loop sewn on the front-center of the holster. There are no wings at all. You can see how confused I am. nick
  10. So, this would be for a left-handed shooter, worn on the right side, so it would be a cross-draw holster... right? And it would be worn inside the waist-band? What would you change from the picture above? nick
  11. It's better to measure from the center hole.. Some belts have 5 holes, some have 6 or 7 holes. Some belts use 1" spacing between holes, some use 3/4" spacing, so measuring from the center hole makes more sense. Approximately 5 to 6 inches from the center hole. Others may have a different opinion. nick
  12. Todd, I have read this 3 times and I am unable to understand the design. Do you mean something like this but for a left-hand cross-draw? nick
  13. Though I have no intention of doing this myself, I thought that there might be some of you who would like to try this. I found two videos on this topic. One is done by Harry Rogers, a guy who was figuring it out by himself, much like we would. He gives info on the exact brand and type of steel rule that he used but unfortunately does not mention the brand, source or price of the tools that he used. The other video, done by a pro, mentions nothing -- but it is nice to watch his skill & technique. Both are interesting... to me anyway! Hope you like 'em. nick
  14. Your work is superb! Great pics too! nick
  15. Really nice work there! nick
  16. Yes, they have... but I am pretty sure that there is more to this question. I am assuming that you want to use it as a clicker, right? See this thread... And this one more specifically... nick
  17. Nice work. I find the sheath on the right to be most interesting. That's a great look. nick
  18. That is a beautiful set. Absolutely stunning carving & color.. nick
  19. Thanks. I was very happy to find that. It is much nicer that the plastic envelope from Tandy... right? Got it from Rocky Mountain Leather Supply. https://www.rmleathersupply.com/search?type=product&q=needle+case Well, now that I think about it... I originally saw it on RMLS but bought it through Amazon. They were available in at least two different colors, light and dark, so if you want to keep two different types of needles, that helps. Oh, yeah, here it is. https://www.amazon.com/Chiloskit-Embroidery-Toothpick-Storage-Organizer/dp/B07F37885F/ref=sr_1_5?keywords=needle+case&qid=1577662792&sr=8-5 nick
  20. Hey, thanks Frodo. I should have posted that the link worked for me the next day. Don't know what the problem was. That's a good find. nick
  21. Okay, so you do have a diamond chisel but the pic that you showed, clearly had round holes, so what are we to think? Here is a comparison of Tandy Big Eye needles that I started this hobby with, and the Tandy, size 0, Harness needles that I use now. nick
