Everything posted by ninety5percent
Found that stamp your looking for... Midas stamp http://www.ebay.com/itm/RARE-Vintage-Kelly-Midas-224-Geometric-Stamp-Leather-Stamping-Tool-/391447336952?&_trksid=p2056016.l4276 http://www.ebay.com/itm/RARE-Vintage-Kelly-Midas-224-Geometric-Stamp-Leather-Stamping-Tool-/391447336952?&_trksid=p2056016.l4276
Barry Kings make a stamp very similar in Geometrics: Celtic Square, Im sure if you email him he can tell who originally made it. It could be his grandfather Don King's stamp.
You can spend money on the top of the line swivel knives, but what really matters is making sure the blade is sharp. I've had craftool from the starter set and it sucked. I upgraded to a Barry King knife and it was night an day. So much smoother and well worth it. Now I've switch to Leather Wranglers and I'm very pleased. My next new knife is going to be a Clay Miller that I hope to get this weekend when i visit his shop. Use what is comfortable to you. Size of the barrel and blade. My LW has a 3/8 barrel but I have very large hands and a lot of cutting I get cramped. Hopefully Clay will have a 1/2 inch in stock and I can try that. I would recommend Barry King to upgrade first! Good luck
I would try... http://makersleathersupply.com/category/BGHG.html They used to be owned by Chris Andre of slickbald.com. Google him to see his stuff, it's amazing. It's now owned by Aaron Heizer from Killeen, Tx. The site lacks a little flash but I know him personally and he's a great guy and ships fast. https://www.facebook.com/Makers-Leather-Supply-236961589714049/?fref=ts Oh yeah if you need custom stamps made... He shares a shop with Clay Miller with Clay Miller tools. Check him out too... I use his mail and stamps. https://www.facebook.com/leatherstampsbyclaymiller/
Does anyone know if the lizard, ostrich, alligator remnants on sale on the online outlet store real or fake. They do also have a "genuine caiman flank" for sale, I just didn't know since the other remnants don't say genuine. Thanks
Not sure I'll be much help, but in the book The Art of Hand Swing Leather, Al put a stitch groove on the bottom round and used that as a guide to stick the awl through. It doesn't say of a trick to keep it strait but just make sure you line it up. You could pre punch the holes on the bottom round and line it up and just sew it that way. If you don't have that book you should defiantly get it. There is a pdf version that can be purchased online on Tandy's leather craft library site. Good luck.
This might be a long shot.... but I have seen some with white residue type stuff on their leather and all they did was heat it up with a hair dryer or heat gun and it just "melted" back into the leather. It turned out it was dried up oils in the leather and it come to the surface of the leather and it kinda look like sweat or salt water residue. Good luck.
You are correct. Some leathers need a boost of oil. If you do oil before you use oil dye, use 100% neatsfoot oil or extra virgin olive oil. The oil can be used to see light spots in the leather that may cause your oil dye not go on evenly. If that's the case you can just oil it again and let it dry to where its even again. Be careful not to put too much oil it will take forever to dry or change the color completely. Most of the leather craft books say to use a light coat of oil.
Help Figuring Out Price Per Inch
ninety5percent replied to ninety5percent's topic in Marketing and Advertising
Thank you all for your input. Dirt, JLS, Zulu. I think I'll buy sides. I appreciate the input and thank you Zulu for the breakdown. -
I'm trying to figure out how much a piece of leather cost that I cut from a side. This is what I need help with... I purchases a 12"x24" inch piece of leather for $37 I cut a 7"x9" square . How much is that 7x9 pice cost. I figure 12"x24" is 288 sq inches take $37 divide bye 288 = .$13 per inch. Is that a correct way to figure that? And if so what is the price of the 7x9 square? I may be looking to much into it and it's a simple answer but all these calculators online and stuff is confusing. Thank you for any help you can offer!
Problem When Antiquing With Wool
ninety5percent replied to Oceanstreetleatherco's topic in How Do I Do That?
I pretty sure that Kris Tanner uses mineral spirits mixed with his antique paste and he also mixes colors too. Clear lac works real good but I have to let it sit a day or two before i put paste on. -
First Bikers Wallet
ninety5percent replied to Wraith's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Looks Good!!! Nice Job! -
I posted this on the other thread.... hope this helps. You can use the Tandy #2 edge beveler for that weight of leather. I think it's the most common used and that's the reason Tandy only sales that one. Here is a pic from the Al Stohlman leather craft tool book.
From the album: Tips
I don't buff the background dye after I let it sit overnight, there really is no need to because the dye penetrates the leather like it should. After dying the background and let it sit overnight, I put resist on the background and/or the pattern and let that sit another overnight after a coat or two. Then you can put your antique on and finish your project. The resist will prevent the dye from smearing. IMPORTANT TO LET IT DRY!!! Hope this helps
White Lines At Swivel Knife Cuts
ninety5percent replied to dnd's topic in Floral and Sheridan Carving
The lines are caused by cutting the leather too deep with you blade. Your beveling is not getting deep enough and when you bevel it compresses the leather with that line showing. You can either cut shallower to correct it or if you but a dye or antique it will cover it up. Hope this helps. -
I think your only suppose to use the finish after the dye is dry. On the Tandy videos it doest mention anything about applying finish before. The finish will try to act as a resist to the dye but will not because you technically can not resist dye. Since this is water based, you can dye your project and then use a lightly damp sponge and rub it like crazy and the elevated parts should "rub off" and then that will give a highlight the high's and lows. I know with oil base dyes they can not be resisted but your using water base dye. I would think the rules would apply still to any dye. I do know in order for the finish to resist any highlight or stain and antique that it has to sit and rest for at least 24 hours. If the finish or resist or shene does not "cure" then the color will be blotchy. Where is the picture?
Some Fun With Holsters
ninety5percent replied to tiggertlee's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Looks good. Did you dye the edges or was that antiqued too? -
My Western Floral Is Improving
ninety5percent replied to VonTannin's topic in Floral and Sheridan Carving
Looks Good!! Im with you on the subject but hey it's whatever. What does the final outcome look like.
