Want to get more depth to my carving
bruce johnson replied to fleabitpokey's topic in Figure Carving
One of the best lessons I have received in the last year is to create the illusion of depth, rather than to beat depth into my piece. This illusion is accomplished by beveling at different depths (like lighter where stems cross than where the stem is next to background), Steeper bevelers to avoid mashing down large areas, fading the knife cuts, etc. It is not a crime to leave "high" areas in an element like a leaf or flower untouched. A smooth area between a depressed center and pear shaded edge creates more depth at each end than if the pear shading and center beveling meet. Another way to create depth is having a fair amount of crossing stems in the pattern, rather than everything on the same plane to start with. Another option not mentioned yet is using undershots and propetal tools to raise and round up areas. Regarding backgrounding, It doesn't have to be deep, as long as it breaks up the design and looks even. This can be accomplished by either texture or burnishing of the background tool. I have used matters to first depress the area in the background, and then textured with a stamp like a 104. I now mostly use a 6 piece set of backgrounders that are different shapes and sizes, but the same checkering pattern. I have a fine set and a medium checkered set. The are real time savers, less walking. The larger ones double as matting tools. Like Mulefool, I do a lot of basket and geometrics on orders due to customer cost constraints. I am pretty healed up and able to swivel knife more - so I am playing around with more florals again on the stock items. It is coming back. I look at some of the carved pieces of Jim Jackson and others on 3/4 oz, and wish I could get that look on skirting. Those guys have got it going. Bruce Johnson -
If it is the same Wolfgang (from Germany) I met there 2 years ago he won a division of the saddle contest that year. He made a really nice clean looking cutting saddle. Bruce Johnson
Steve, I am with you on this. I oil the whole skirt for the reasons you say. By only oiling part, my thoughts are that most oils will migrate anyway. If you only oil the edges some will eventually work its way to the bar area. Another factor - skirts aren't the only area to contact oiled leather. If we follow that same logic, we also shouldn't be oiling or pasteing the riggings, stirrup leathers, jockeys, swell cover, or any other parts that potentially contact the rawhide. I don't know too many who would advocate that. I thank that group could probably dine at a table for one. Bruce Johnson
Soybomb, When I first saw your post, I suspected that was the creaser you were using. Think pf the legs as skies. As you open them up, the edges splay further and further. Tip the front ends of your skis apart and head down the hill - once. I couldn't get them to track either. IMHO, it is because you are trying to force a groove making tool at an angle. If it was a sharpened tool and meant to cut it wouldn't track with the blade at an angle. What you are trying to do is essentially the same only making a groove with a dull linear surface at an angle. The sized edge creasers with the longer leg, and the creasing surface parallel with the direction of travel works much better. Bruce Johnson
T, A few sources out here on the west coast are Goliger Leather in Santa Barbara, CA and Hide House in Napa and San Dimas, CA. Siegels carry lots from time to time that might fit what you are looking for. Another source I would consider also is Sheridan Leather Outfitters in Sheridan WY. I know the leather you are talking about, but it is hard to tell the drapiness of it on a swatch card. A good rep from any of these should steer you right. Bruce Johnson
Let's talk about Saddle Riggings
bruce johnson replied to bruce johnson's topic in Saddle Construction
Susan, Mechanically once you get a tree positioned on the horse's back and then get the latigo position you want, that will determine the rigging position for me. Looking at the pictures of your horses, it looks to me like your thoughts on full rigging or 15/16ths looks right for the way I would do it. David talked on the other thread about the horse that goes well in a 5/8ths. Tree fit is probably a bigger issue than a strict rigging position. To introduce a few variables into this equation - if the horse has a good back and the tree fits, there should not be a lot forward and back movement of the saddle. If the side to side fit is likewise good, then there shouldn't be as much rolling. With these, you can get by with a looser cinch for most riding. Add a thick 1" pad, or pad and double navajo blanket, and that will change things a bit. More roll and more movement. The rider's cure for saddle movement - pull the cinch tighter. I think that is where a more posterior position will cause some issues. Not to be assumed that back cinches are not to be pulled. They are there for a reason and I use them. Also as David pointed out the mechanics of putting in the rigging are an issue. If the rigging ring is right at the bottom edge on the bar, it will stand away from the horse a bit more than one slightly lower and formed when made. Over time everything may stretch and pull into position, but maybe not. I have zero experience with the Sam Stagg rigging other than seeing it on some period pieces, and the old "Windy Bill" song. You are right, this does throw a monkey wrench into the works. My basic thoughts on any adjustable rigging is they are only as strong as the weakest link. Buckle tongues bend, laces wear and tear, fasteners come undone, and the wreck is on. Bruce Johnson -
Allen, Thanks for your input. Regarding the leather in front of the swells. I am not the end all guy for saddle making for sure, and have changed with time. My fronts are actually blocked up higher than the bar level, and I use 2 sets of tugs in front to hold them up there. Two reasons, first is to minimize that contact with the shoulders forward of the bartips as much as possible. Blocking less to have pressure out there is not to my mind necessary or wanted forward of the bars. Second reason for the heavy blocking is to help cover up the tips of the bars. I want no gapping there. Also these two saddles were built on really different trees. The Weatherly had more bar in front to start with. The association didn't have much. In fact rigging was a bit tricky. I am attaching a picture of my wife's saddle that has a fair amount of "front" to it, but really opens up. It is a roper/user, but there was more bar than the Association had. The length of bar tip determines how far in front I extend the leather. I just want enough that I don't see tree when done. One thing that is a little deceiving on my saddles is that the skirts aren't real deep either. There is a pretty good book, now out of print, on saddle evolution. Glenn Vernam wrote it, and it is called "Man on Horsdeback". Goes from ancient times to modern, at least as modern as 1964. Glenn also wrote "The Rawhide Years" a book about the evolution of the American cowboy gear and co-wrote "They Saddled the West" with Lee Rice, which is the history of several american saddlemakers. Man on Horseback has some illustrations of Moor saddles, as well as Algerian, Bedouin, etc. in some sections. Regarding the Wade popularity. In the Northwest and basin area, slickforks always maintained a good level of popularity. I think the regional popularity was expanded by one man - Ray Hunt. He rode them, and was the first major equine clinician to take the show on the road. He opened the door for a lot more equine clinicians who rode them, and it took off from there. Joe and Jane ClinicAttendee see these guys getting some stuff done with a horse that is pretty phenomenal to them. They see the saddle, it ain't their Circle Y with the braided "boy" horn, and want one. I would wager that at least half the slickforks sold now will never be see a rope as anything but a decoration, and very few big posts will see a reata. There are pluses and minuses to all swell and slick forks. Back to getting the rider forward. There are two limiting factors. The swells and the stirrup slots. You can build a seat more forward, but when you get closer to the swells, that limits the proper knee bend and severely limits forward movement. You are also getting up where the tree is widening out again. The stirrup slots have to have some allowance forward swing, and the more forward you put the seat, you cross that line from stirrups underneath you to behind. If you have ever ridden a saddle that stirrups tend to fall away behind you, and have little forward movement, you probably won't want to again. I am claustrophobic if I can't get my feet up into the flats. This is where plate, triangular, and skirt riggings have the advantage over most traditional folded leather drop dee riggings. Bruce Johnson -
Allen, Welcome!! A few historical points as I know them. The slick fork trees were not developed. They were the originals. They were made form the fork of a tree, and prior to the early 1900s, all trees were slick forks. The first swell fork developer is open to debate, some say Marsden in Oregon, others claim a Hamley employee, not a major thing, but that is the time period swell forks came about. Regarding the bareback rider sitting right behind the withers, that is true enough. However I would offer (for discussion's sake and not to disagree with you) that gravity is the cause of that. As David pointed out in the bar or fitting thread, very few if any horses are built uphill. You naturally gravitate to the lowest spot, and that is directly behind the withers. The withers rise up to stop you. Ride a down-hill mule bareback, and you may be hanging onto ears. I will agree that that position is close to or the pivot point or balance point for most horses. There is a reason bronc saddles are rigged 3/4 - it keeps the rider closer to that pivot point. Try sitting back further and leverage will kick you over the swells. Also why it is easier to get bucked off out of a double rigged roping saddle, you are further back on the leverage arm. Sitting too far back on a spinning horse, lead changes, standing up to rope, anything, and you are constantly "behind" the horse. The horse that collects up and really gets a hind leg underneath himself to stop or turn, you can sit back in the pocket a bit more. Part of the reason the cutting saddles with the flatter longer seats are designed for that purpose. The poor sloppy or "bracey" rider negates all this, but that is beyond our control. Now we are getting into the rider who either purposely sits back and braces (David's concept of "brida") or the seat is built so the cantle is the low spot and everything ramps up from there. The rider has to sit there, or brace to sit up higher and more forward. The posterior seat as some call it. So to get back to where we sit on western saddles. Other than a very short seat, thin forked minimal bar in front of the fork tree, we can't easily put the rider directly over the exact same spot they would sit on the horse bareback. We can get them closer. I vowed I would never make saddles several years ago because I only ever rode two that I liked that weren't cutters. I realized why when I ate those words and built a saddle. I whittled away groundseat and sat in a lot of wet leather to get what I liked. I want the lowest part of the seat in the seat not on the cantle. I got lucky on that first one, and it worked. Chuck Stormes did a series of articles on seats and riggings on a natural horsemanship website - Eclectic Horseman or something like that, where he showed "my" seat in some 1930 Visalias. Some people call them centered seats, David uses the concept of "jineta" vs. "brida"; hell, Xenophon probably had a Greek term for it before any of us. I doubt the Visalia tree makers had heard much of jineta, brida, or Xenophon, but they built a seat that worked. So to expand this thread from riggings and include seats, I think it does fit together. Regarding your bringing up skirt riggings, I purposely left that out, just to create some discussion. I think a properly installed skirt rigging is the hardest to do, and probably strongest rigging styles. I think the deep drop front skirt riggings could be restrictive, just like a deep drop too-much-leather-to-the-front plate rigging could be. Minimal stirrup swing restriction, opportunity for more attachment points, and less bulk makes them a real plus. Too bad there is the prejudice against them in many areas caused by the historically poor job some factories and makers did installing them. We are on the same wavelength about the 3 way. There is a reason some of the best horsepeople are barrel racers and there are a lot of three way skirt riggings on barrel saddles. One thing I am not sold on is free sliding cable riggings. Hamley tried it years ago, and another tree maker is trying to bring it back. The concept is probably OK, the mechanics aren't. What makes me think a leather latigo won't be more easily cut by a cable under tension than by a metal ring with more radius under tension. I cut enough hay strings with a spare string to know my thoughts on that. Now how I was taught to position a rigging. With the bare tree on the horse sitting in the sweetspot, The latigo should hang vertically in the narrower part of the chest. Behind the shoulder muscles and where they will be in all phases of the stride, and in front of the area where the chest widens out viewed from above. Reasons I was taught. Too far forward - we are binding muscles, too much motion under the cinch rings and we are creating sores. Too far back and we are inhibitng chest expansion on some level. Obviously this intimates we are fitting a "particular" horse, but in light of other discussions, I call it fitting the general type of horse now. I think the sweetspot for the latigo has more leeway than the sweetspot for the tree. I was taught to saddle a horse by setting the saddle up a further than you want it. Then slide it back and it will find its "bed" where it wants to stay, let the latigo hang straight down and cinch up. The reasons given were that it (1) puts the saddle where it needs to go, (2) smooths out a wrinkle in your blanket if you have one, sliding forward could make a wrinkle, (3) lays the wool down in all one direction to keep the blanket in place (we aren't going to woolskins front or back right now!! LOL) because thats the way the woolskin was put on, (4) lays the hair down on the horse preventing wither sores, (5) because my Grandpa said so, that was enough - no discussion. I am attaching a couple pics of some of my saddles to illustrate a centered seat vs. a posterior seat. The slickfork with the corner stamping is pretty typical for my "centerish" seat. The branded fender saddle was done with the posterior seat by request. This guy wanted that seat because that he is what he wanted. It is a definite ramped up narrow posterior seat. He wanted to be able to grip something standing up from front to back - he can. Bruce Johnson -
A bell knife skiver is a bench mounted motorized skiver. Basically a feedwheel feeds the leather against a rotating bell shaped blade, and that cuts off the skive. Ferdco and Artisan both sell them, and have them on their websites. Kind of the old standard that these are a knockoff of are the Fortuna skivers. There are different presser feet for different shaped skives. The depth and width of the skive can be adjusted by a fence guide to control how far in the skive goes. Also the presser feet are different lengths and can be adjusted to have varying pitch too. There is a top adjustment for depth on the presser foot. These adjustments are all thumbscrew type adjustments and pretty easily changed. With the widest foot and setting it level I can split a 2" strip of latigo or mulehide from just leveling to paper thin. By changing the pitch on the presser foot, I can do a tapered skive up to about 2". Raising/lowering the presser foot or changing the guide fence width makes shorter or longer skives too. I can use a piece of 8-9 for a checkbook, channel the center so it folds easily, and skive the edges so they are not so thick and clunky looking. The thicker center leather makes it safer to undershot and propetal with less risk of cutting through. These skivers sell at prices on-line for the knockoff models from about $900-1300. They usually come with a stone feedwheel and two or three basic feet. Additional feet are available, as well as the steel milled feedwheel for vegtan. Not for everyone, but I wouldn't be without one now. I have a heavy sewing machine, and flatbed sewing machine that can do up to 1/2", a shop press for a clicker, Chase pattern splitter, handcrank sole skiver, handcrank heavy splitter, and a rein-rounder. I have everything mechanical I foresee needing. All of the work these machines do can be done by hand, these just do it more consistantly for me. Bruce Johnson
OK, looks like time to move onto riggings. And on this topic I likewise expect no consensus, and encourage differing viewpoints. The battle of the "rimfires" vs. the "centerfires" went on 150 years ago, and hasn't been toally solved yet. A few random thoughts. First we probably need to define (or at least get on the same page) on what the various positions mean to us. I was in a class that an elderly statesman sat in on. The original positionings were based on the lowest point of the front pad and the rear pad of the tree. Centerfire was exactly half way between these two references. Three-quarters was hung at 3/4 of the way between them toward the front, likewise 5/8. Full position was directly under the low point of the front pad. They didn't go from the middle of the fork, middle of the horn base, or use the cantle as a reference. Likewise, they didn't use the 1" back from full is 3/4, 2" back is 5/8". There trees may have been pretty standard and these measurements would correspond to how some makers determine postion today, don't know. Fork thickness, horn placement, and cantle placement all could affect the measurements on the same bars today. Likewise different bar patterns with differing low spots could affect the postioning going by the old system. My best references to the centerfire are some of the old vaquero books. Arnold "Chief" Rojas wrote several. He got in on the tail end of the ranchos, and talked with and wrote down the storeies and lore of the older vaqueros who had gone before. Centerfire cinchas were wide for stability. They were riding generally thinner 900# horses, with not a lot of bodyfat, and accroding to several accounts, fairly slab sided. They were credited with being great horseman, and admired for getting off every so often and loosening the cincha, lifting the saddle, and airing out the back. In a couple accounts it was mentioned this was mainly to readjust the slipping blankets and reposition the saddle, not necessarily caballo concern. Roping was done with reatas, the dallies run, and so not a lot of stress or jerk on the saddle. Centerfires fell out of favor because they were not stable enough for evolving use of the horse, interfered a bit with leg cues, and the body style of the horse evolved. As an aside, they talk about the time taken to train the famous Californio stock horse. These horses not put into the full bridle until at least 6 years, spade bit packers, etc. According to several sources, horses were cheap and tools. They were used hard over big areas in a day from ranchos, not from cavvies in a camp and traded at noon. The users were not shod like the "Fiesta" horses. A colt might be ridden 30 miles over dry adobe or rocky foothill ground all day. It took many of these horses 2-4 weeks to get over being footsore and saddlesore enough to ride again. They may get to be 6 or 7 and have had 30-40 rides at most. Meanwhile they go through the transition from hackamore to bridle in 30-40 rides. The good horses were like good horses today, if they were special they went on a fiesta horse to ride to town or to another rancho. Rojas estimated that 1 in 30 ever learned or were good enough to pack a spade bit, they were the ones you took to visit. About the same as today. They took several years to train these horses, but it was generally pretty interrupted compared to today. Back to riggings. The other battle generally is plate vs. ring rigging. Then we get to how low the riggings should go down the side. One camp says the lower they are, the more they "wrap" around the horse, and less cinch pressure is needed to hold the saddle, and the horse is more comfortble. The other says that the lower plate riggings will act like a corset and bind up chest expansion. If the plates have a lot of leather forward of the slot, that can interfere with the shoulder muscles. Should the rigging be on top of the skirts and spread that pressure over skirt edge, or lower and possible have a lump where two or three laps of latigo are on the horse? I definitely agree that a tree will seek its sweet spot on the horse's back. My general though is that the latigos should hang vertically below that. The latigos and cinch should be in their "sweet spot" too, behind the elbow and in front of the widest part of the chest. Shoulder angle difference between two horses can play a part in a particular saddle having the same sweetspot on top, but slightl y different for the latigos. We can also get tinto the merits of rigging hardware - SS vs. brass, beveled or flat dees, EZ dees, etc. How to attach them for strength, but still allow adequate stirrup swing. All opinions and input are welcome. Bruce Johnson
Art and others, Report on my bell knife skiver quest. I am on a boot and shoe makers group as well. I got some advice on bell knife skivers there as well. I went to Melanie Machines in LA at the advice of bootmaker. This is the candy store of leather machinery - new and used. A couple hundred stitchers and sewing machines, rollers, cementing machines, folders, kick presses, clickers big enough to crush cars. The owner used to run a shoe factory that kicked out 5000 pairs a day before that trade went overseas. He stayed in leather with machinery. He invited me down with my leather to play. He sells new and used, and had a used Fortuna and a new Asian knockoff both set up for me to try. For most shoe and boot shops, the knockoff is working out fine. I needed one to do vegtan up to 8-9 oz or so, as well as softer chrome tan. The one I tried at a tradeshow was the knockoff, and I had all intentions of buying that type skiver, although was warned by several that it doesn't do vegtan well. They told me I needed a top and bottom feed for vegtan, and the bootmakers tell me the top feeds can eat the surface of chrome tan. Arnold set the machines up with a steel feed wheel (instead of the standard stone feed wheel) for the vegtan and a roller presser topfoot, both machines plowed through it. The stone wheels may slip and glaze with the vegtan and then need to be dressed to move anything. The steel wheel has milled grooves like the feedwheel on a handcrank splitter - it gets ahold. The Fortuna casting is heavier than the knockoffs. The feedwheels are easier to change on the Fortuna as well, although I have had no problems using just the steel wheel for everything for the most part. Some of the Fortuna feet needed slight modification on the drilled hole to fit the knockoff as well. Fortuna makes about 40 feet for different specialty edge skives or channeling for folds. This all made the decision for my wife to tell me to get the Fortuna easier. He had his mechanic go through it, replaced almost every bolt, beefier tension springs for the vegtan, new belts, new motor, and shipped it to me. I have had it a little over a month. It is used every day. Easy to readjust for different skives, or change feet. I use it to skive edges to use heavier leather, but still have a thinner nice looking edge. It thins mulehide and latigo hornwraps like nobody's business. Skives or thins soft chrometans and latigo. They are clean and not wavy, and it makes welt strips simple. The only thing I haven't got the foot to do right is grooving folds deep in from edges like on a binder or briefcase. I can still use my french edgers for that. I guess you can tell I like it. Glad it is on my team. Bruce Johnson
A source I have seen advertised but never dealt with is Paisano Boot and Shoe Findings in El Paso. Website is www.paisanoleather.com. There may be other boot and shoe finding outfits that sell welting as well. Like Art, I make my own from scraps. I love my bell knife skiver. Thought it would be a frivolous luxury, it is used at least daily. Bruce Johnson
I have to weigh in with Roger on this. I tried Weldwood for all my cementing when the HL and some availability issues came up with Barge a few years ago. It gave me very poor bonding with wet leather. It did not tack up with heat if dry like Barge will do. That said, I did find some places where it does better than Barge. When I cement in thin pigskin or goat linings in things like checkbooks or business card holders, the Barge will sometimes soak through and be tacky on the grain side of the lining. Weldwood doesn't do that. It doesn't do as well in cold weather as Barge. My Barge lives outside in another building for storage, and on the back porch for the gallon in use. Weldwood tends to get thicker and less adhesive when cold. The big issue with all of these adhesives are that they are changing, and fast. Word from a shoe repair friend, and corroborated by a seller of Barge is that the new formula separates and needs to be mixed prior to each use. Most all of the consumer level adhesives (and other chemicals for that matter) are changing formulations too. Whether the two products we are comparing now will be similar in a year remains to be seen. Bruce Johnson
Romey, This knife (and I have another) is a Clyde. I also have an Osborne to compare to. The Clydes feel just a tad thicker at the back edge than the Osborne. I have no micrometer, but butting the back edges against each other, the Clydes are a little higher, but not a bunch. I am not good on angles, but the Clydes when I got them had about 1/2" of bevel. I took one back to about 1-1/2" of flat bevel on both sides. Wet/dry on the stamping granite. Then I took the outer about 1/2" even thinner by flattening the angle more. (At this point I am thinking like my surgical instruments - flatter angle, less tissue drag)That left a little ridge where the two angles met. I polished that off with a swatch of wet/dry on my finger to ease the ridge. Polished everything up on the strop and went to town for 2 feet, strop and two more feet. I could feel the edge curling. I took the edge off square until I had a definite visible even flat edge, and then sharpened that at a higher angle to make the steeper secondary bevel. Seems to be working, I usually only have to touch up on the 1200 to 4000 wetdry, and then strop lightly if I really abuse the blade. If I strop more regularly, that is about all I really have to do though. Bruce Johnson
Fitting different types of backs
bruce johnson replied to AZThunderPony's topic in Choosing the Right Saddle for the horse(s)
Susan, Welcome to the group. Your questions are almost exactly what I had in mind when I started this whole saddle tree line of questions. I think most of us feel like we can decently fit most of our customer's horses with what we are using now. But what do we do when the customer comes in who doesn't ride the average 1100# QH? The person who has the more Spanish influenced horse, the gaited horse, or whatever, and wants to ride in a western saddle. The off the rack saddles (and trees) are probably not going to work, and that is where we can help fit the bill. Again to bring up shoes. The average person buys off the rack shoes, the average rider buys an off the rack saddle. The person who has foot problems needs either orthotics or custom made shoes. The specialty shoe market is a very miniscule part of the total number of shoes sold, just as custom saddles are. It is still a viable market. Your questions and comments on rigging type and position are interesting. That is one of the areas I wanted to go to, with carrying on this whole fit and saddlemaking thread. Like bars, I think that needs to sit on its own. Each of these could sit on their own to make this usable without a lot of searching. My thoughts are to have separate threads for the top of the tree - cantles (style and angle), forks/swells/pommels (styles to a point - there are about a million, materials and attachment), tree covering (rawhide, glass, synthetics dips). Other than Rod and Denise's articles in LCSJ, there has not been much info coming from a tree maker. Likewise separate threads for the rest of this area. Rigging type and position is probably secondary only to trees as fit issue. The best tree rigged wrong for a particular type of horse won't work. Skirts play a part. Should they be laced all the way back, or just to the bar points? Skirt linings - real woolskin, synthetic, gel inserts - all probably have their merits. This is going to be the "never-ending" story.... Bruce Johnson -
Shawn, I didn't line it or put in pockets. Most of these chap leather purses I don't. No reason other than the big shops and sellers I am "competing" with don't. I have had some requests for linings, and then I like either goat or pig. One some of the bigger purses I put in pockets on request, but those are the customs. This little purse took me just under two hours start to finish. I tooled the yokes first, then put those under the high fan while I made up and cut the body pattern. I do mostly custom orders, but like to have a few things made up for the "I need a gift now" customer. I think this style fits that bill pretty well. I see I could batch up and do several of these in a day. This was a scrap project and we all need those. Bruce Johnson
Regis, The handles on purse was some skirting split down to make up about 8 oz total. One was the piece from straightening the back, lined with some belly I had left over. The belly was still decently firm, so I couldn't tell you which side is up. If you Barge and get a good bond, you don't need the clips. If the bond is not set well, but still holding somewhat, I space the clips out. Barge also doesn't give me as firm a bond with oily leather, finished leather, or leather wet to start with. If you put the Barge on dry leather, let it set, and then wet it - you get a good bond. Shoe repair guys do it all the time. You just can't put it on wet leather to start with and expect the same results. If I am making round handles, I glue first and then soak the leather in a water bucket until sloppy wet. The Barge tacks right up with a shot of the paint stripping gun. All this is based on the Barge I have right now. A shoe guy told me that the new Barge separates from the solvent and needs to mixed each time you use it. I don't know if the new stuff activates with heat like the Barge we all know, and some of us love. When I get through what I have, I will see. Bruce Johnson
Regis, The slots for the handles are cut in the yoke only. The handle ends are sandwiched between the chap body and the yoke. Makes for a cleaner look inside, only the Chicago screw for the concho is visible. One thing I did on this as a trial. On my other purses done like this, there is a decent sized lump where the handle is sandwiched. With larger conchos they don't sit flat - the edges are up a little. On this purse I skived about half the thickness of the yoke from the slot down to past the post hole. With the handle in there, the lump is a lot less evident. Looks very clean inside and out. Bruce Johnson
Thanks Kate, I forgot to add the 3 things I would improve on it. I would make the darts shorter. I would sew with smaller thread, this was sewn with my headstall setup - 346/277 (Iguess in a hurry, this is a prototype, new pattern). I would make sure the towel I stuffed it with for the picture was even, It kind of skews some things that really aren't. Bruce Johnson
Regis, I would do a little of everything you are thinking of. If the leather has much body, you wil probably want to moisten it to fold easier. I would also use a cement like Barge. You can apply the Barge, let it dry. apply water from the other side (or even dunk it) and hit the Barge with some heat. It will tack back up and do fine. I would set the bond (and fold) with a smooth face hammer just because. That said, I do use the binder clips like you are showing. I use a bunch and line them up edge to edge, removing as I come to them while sewing. They do sometimes slip, and the glue won't. Bruce Johnson
Today seems like scrap day. I did a few little things, and then tried to make a little smaller purse than I usually do. I used to not like this flower very much. However it is growing on me. Probably because I did it over and over in a class, until I am confident I could cut it left handed and blindfolded. I am liking it a lot more now. This flower really lends itself to embossing and plugging, I did that on the last purse and it really looks sharp. I used some left over workchap scraps for the body, and split down some skirting for the handles and yokes. It measures 8x8 inches, and is pretty lightweight. I am thinking If I had a daughter, this would be a good date purse. Room enough for lipstick, a cell phone, and small handgun. Bruce Johnson
Regis, I bought one of the SpeedStampers last year. Advertised in LCSJ for under $200. They are a flexible shaft tool with an oscillating handpiece. The chuck for the handpiece is big enough all of my bevelers fit it with no turning down the shanks. I know other guys with the wood carving handpiece that turned down the shanks to fit those. I use mine a lot for beveling. It paid for itself in about the first 2 months. I thought it would background, but just oscillates too fast to leave anything but a fairly smooth pattern if you "run" it. That said, several guys that do silver engraving have one of the GRS engraving systems already. They require a smaller shank. I know Barry King makes some stamp tools with the smaller shanks for those guys. I don't know of anyone using one for anything other than beveling though. Bruce Johnson
Pictures from old(er) masters
bruce johnson replied to Johanna's topic in Saddle & Tack Maker Gallery
Thank You Johanna and Ashley, I will still stand by my statement a few months ago, and expand it a bit. Chester Hape is one of the top two carvers all time in the Sheridan style. It is arguable who is the other, but Chester is one of the two. Bruce Johnson -
Wayner, No ideas on sources for dehaired bearhides. Other sources for the hippo might be Sheridan Leather Outfitters in Sheridan WY. They have quite a few exotics not listed in their catalog. Good people to deal with. John Fong might have it also. He is in San Francisco. Don't know why, I just haven't dealt with him. That said, I just like dealing with Jerry VanAmburg on exotics. He has always played "let's make a deal" with me at the shows, has good stuff or knows where to get it. If you have ever dealt with him in person or on the phone, just that contact will be the equivalent of shotgunning 3 Red Bulls. He goes 9-0 with his hair on fire. He is probably tough to get ahold of this week, traveling to Sheridan I'm sure. The prices of these exotics kind of fluctuates. Show prices are usually better than phone prices, but worth a call in another week or so. Depending on how the show goes, still might be some deals at home too. Regarding the turkey leather, used to go by the name of "gallapava". I had some boots from it back in the day when I was single and still had money. The boots lasted as long as money does once you're married. Turkey skin is meant to stay on the bird through the roasting process. Bruce Johnson
