Who Makes A Good Oblong/slot/bag Punch?
bruce johnson replied to Andrew Chee's topic in Leather Tools
Pretty much going to have to sharpen them all as Jeremy said. Even sharp you need to use more force on a longer slot punches. The coning down and bevel effect is greater the bigger the punch and thicker leather just magnifies that even more. The punches from England don't have quite as much bevel and drive a little easier. Still I am driving most slot punches over 1" with a 3# maul on a 12x18x3 granite plate with a LDPE board on top. -
How Do You Know Which Size Oblong Punch You Need?
bruce johnson replied to ranchmom77's topic in How Do I Do That?
For me it depends on the buckle. Some buckles with thicker heel bars I go up 1/8" to allow for the bottom of the tongue to lay down into the slot and have plenty of room for a good range of movement of the tongue back without binding. -
These are all as they came. I had a call about who made them too. Left to right - Walt Fay, pushes and lifts. Barry King under cutter - the thin profile "cuts" a nice pocket underneath but minimal lift. Good to cut and then follow with another lifter for maximum effect. Elton Joorisity - same angle as the Fays and nice. Gore - decent pocketing and lift, good depression under the impression without a heel mark so it lifts and compresses for a nice effect. on the right - original Ray Hackbarth. not a lot of lift, but a nice "push effect" on tight patterns.
Heavy Saddlery And Harness Machine Manuals Wanted
bruce johnson replied to Singermania's topic in Old/Sold
I am not sure if they will have all you are looking for, but ShopTalk has a pretty extensive collection of manual reprints for sale. Here's a link - ShopTalk -
Pattern punches. These were handmade for some specific part of something. A lot of these were made for shops that didn't use a press/clicker or maybe even prior to powered clickers being available. These could have been used for footwear, purse or bag pieces or trim, etc.
The last order I had from them took about 3 weeks. Slowest international mail is usually between the US and England, followed closely by the US and Canada.
Thank you Walter, Macca, and Tor! This is my favorite thread on the forum! One thing I am finding interesting after seeing several are the different configurations of the fences (guides). Steel, brass, two pieces of steel, etc. Then the shape viewed from the top is interesting. They all have some "flare" on the front. From there some have a long flat area. Others have a shorter flat area and may flare back out a bit on the back edge of the guide. This flare at the back seems to be a bit more common on some of the Dixons. One question I have is on the screws on the Blanchards. Is there a name for those with the rounded heads? Are they still available in Europe? One thing with them I found last year is at least some, the rounded head is threaded onto the shaft of the screw. I had a plough gauge that the head would unscrew from the shaft when it was loosened. Thank you, Bruce
Macca, Thanks for posting these. The pictures look much like my shop does right now. I just got several plough gauges and French knives. No French splitters or eyeletting machine though. Like you, I have plenty to keep me busy for time to come. - Bruce
Campbell And 441 Clones Throat Lenghts
bruce johnson replied to RoyalLeatherDesigns's topic in How Do I Do That?
The needle and awl machines were harness and saddle stitchers. They were mostly used for edge sewing and don't need the reach. The single needle machines were for other sewing, when you are sewing tarps, wear leathers on saddle blankets, and centered inlays, that extra reach is nice. As far as making the needle and awl machines affordable, the affordable 441 clone machines are made in parts of the world with a different cost of production than the US. -
If you asked for 8' and got 7-1/2', I'd have them issue a call tag for this one and send an 8 footer. You aren't going to get 6" of stretch out of 7-1/2, and if you can I sure wouldn't use them for reins. There are some makers who do some creative cutting on a curve to get more length, but then you have a curved piece to straighten, it may want to go back to that curve some and hang funny.
Nice nice nice! I particularly like that knot on the popper.
What Direction For Stitching Punches In A Die?
bruce johnson replied to MrLentz's topic in How Do I Do That?
I don't think I'd have them put in at all. If one ever breaks or bends, then there'd be a problem. You may decide down the line you want to do finer work and want to sew 7 to the inch. I hate to sound all old fashioned but a sewing awl and couple sizes of overstitch wheels will probably cost about the same as having slits put in a die and give you more options. My thoughts. -
Tor, I understand about the sentiment of nobody carrying the tradition of tool making. One of my Australian customers wrote me this - In 100 years somebody will find a 2012 plough gauge and wonder why they used a square fence plough gauge with a plastic roller.
Looking At An American 3-In-1 Crank Splitter
bruce johnson replied to thenrie's topic in Leather Tools
The top wheel is narrow and coarse and you'd have to have a new one made smooth to not mark your leather. Depending on how this particular model feeds, that might be a problem. The screw backing the blade is broken off. Not the end of the world, but if you break the piece trying to back it out, that could be. Overall - pretty rough and probably would need a good breakdown, clean up, and reassembly. On Ebay that means you buy it, you own it and you hope to hell they pack it well enough to arrive in one piece and expect it in 2 or 3 pieces. Once you do all that, you will have a machine that will skive and cut leather out on the end. There is no Osborne machine comparable. These were designed for shoe shops. The end wheels would cut and the skiver would put a tapered skive in soles. Good for doing a consistant skive for groundseat work, a folded edge, or run a strap through cross-wise and do a lap skive. Handy to have one for sure, but I'd be wary on this particular version and condition.- 2 replies
- leather splitter
- leather skiver
(and 1 more)
Pcox is right. Don't grind, you can mess up the spacing and won't work. It looks like the bottom wheel is a driver. If so then you could get a wheel made by a machinist that is smooth for the top. A friend of mine got one made for a wide American for $40 last year. These will work with one driver. They will do vegtan and firm latigo OK with a good sharp blade.
What Is Your Favourite Tool? What Wouldn't You Be Without?
bruce johnson replied to Hallyth's topic in Leather Tools
Only a few makers send out tools sharp enough to use straight out of the box. Right after you buy the first edge tool figure out how to sharpen it and what to use to sharpen it with. It can go from wet-dry paper to stones of all varieties to power systems. Get a comfortable sharpening method and learn how "sharp" is really sharp. Not an orginal quote from me but "Sharpening is not an optional skill". -
California Restrictions
bruce johnson replied to RoyalLeatherDesigns's topic in Leatherwork Conversation
I have Ferdco machines I bought several years ago. -
I didn't write the laws but some distributors will ship and some products can be shipped if you have a business license and not as a retail customer. Not a real issue to have it shipped to AZ or NV either that I can see. With all the stuff coming across porous borders, a case of glue or finish is small potatoes. Next spring there are leather shows in Wickenburg and Prescott AZ, people that sell this sort of thing will be there. -
Another maker to consider is Wayne Jueschke. I use a 12 oz, 16 oz, and 32 oz the most. The 16 oz is pulled most of the time.
Kate, As far as replacement parts, Pilgrim Shoe has the most in the US I'd guess. A few others like Bogle-Greenwell might, but otherwise you have to either have them made or scab them off a parts machine. Problem is that the stuff that commonly breaks or wears is probably what made a "user" into a parts machine.
These can can be adjusted a few ways, Like Kate said the top screws will raise and lower top roller and working one side or the other will level the roller and blade edge relationship. You can adjust the bottom roller buy working the nuts and machine screws below. These were designed for sole material period. If you are running thinner leather through consistently then you need to raise the bottom roller some to get adequate pressure between rollers to grip and push. If you are splitting really thin splits off heavy leather consistently then lower the top roller for less clearance and the lower bottom roller to allow the split to go through the gap between it and the blade without really compressing those springs and straining the frame. These can be tuned for about whatever thickness a guy starts with and expects to end up with. Set them up like you use the most and most of the time the tolerances will let you do outside those ranges easy enough.
Look really good, Bret. If I had about 2 more horses I needed to rig up for, I'd sure be looking hard at these.
Beautiful paring machine Walter! The maker had some good ideas on the design also.
