BTW - what I figured today is that the A51 ex factory is a "button covering machine". Not sure what you want to do with it but the Co. still exist and maybe worth checking with them: https://www.astor-berning.de/fashion/fashion-maschinen/187/a-51-knopf-ueberziehmaschine
Pictures of my lever press - its fairly a beast compared with "plain spindle presses". I needed an M10 (male) x 1/4 (female) adapter to make it work. Meanwhile I figured this must have been the manufacturer of my press but back then no data were available. https://www.loxx-produkte.de/live/Historie-Unternehmensgeschichte/historie.aspx But I doubt any spare parts are available anymore. Anyway I´have what I need and this thingy will last for ever. I have never seen a 2nd press like this either.
I do not know ASTOR but usually the threading for the upper die is either 1/4" (UNC) or M6, at least on the presses I worked with. I once restored two very vintage unknown brand presses with odd threading for a friend and on both I was able to replace the inner part that holds the upper die with a plain round m6 long nut (Gewindemuffe or Verbindungsmutter as it is called in Germany). So he can use standard M6 dies. https://www.ebay.de/itm/165996998186? The outer diameter was the exact same as on the die holder it required tinkering but both presses worked w/o problems. For my own press (I´ll post pictures later) I also needed an adapter but he company I bought from (IIRC it called IX-Trade or so) no longer exists (a way different press anyway) as it seems but there are some CO's . in Germany that sell different adapters, not sure if there is one that suits your needs: https://www.jstrading.de/de/pressen-oesen-zubehoer/Zubehoer/ or this one, they even mention ASTOR: https://www.getmore-shop.com/epages/61848837.mobile/de_DE/;ClassicView=1?ObjectPath=/Shops/61848837/Categories/Presswerkzeuge
Pfaff 491 roller foot pressure
Constabulary replied to LorenaLynn's topic in Leather Sewing Machines
You asked that before: -
Are you sure you need a 3-4mm thick thread? 😳 Have you looked on a ruler how thick 3 or 4mm really is? I doubt there really is a machine that can handle such "ropes" or "laces". As a sample - the average paracord (like 550 / type III) is 4mm tick. I once sold my Singer 7 to someone who sewed felt pads for pack animals and IIRC he used NM 230 or 250 needles and the thread for such needles is about 1mm thick. What is you project maybe we can go from there.
Seiko Lsw-8Bl Bias Binding Foot?
Constabulary replied to Oleoleole's topic in Leather Sewing Machines
same as for singer 111w https://www.ebay.de/itm/142635485129 College Sewing or Trojan Sewing in the UK should have them as well EDIT: https://www.college-sewing.co.uk/parts-by-type/single-needle-walking-foot-feet/singer-walking-foot-feet/singer-111w-walking-foot-feet.html?p=3 -
I doubt it will be an upgrade. Why do you think it could be an upgrade? If the Consew has a larger bobbin that IMO would be the only improvement. Both are Chinese made clones of the Singer 29K with minor downgrades from the last Singer version 29K7X
if you cant find one used check with CL Machinenbau - they still make the shuttles for the 8346-20 https://www.cl-maschinenbau.com/de/leistungen/naehmaschinen.html But do not expect them to be cheap 😉
Foot Pressure - Pfaff 491 Machine
IIRC the 491 is using a leaf spring for the foot pressure (similar to Singer 111w - kind of) so there should be a screw on top of the machine at about in the middle of the top arm. -
you have to pull out the foot bar. You have to loosen / remove theses 3 screws too - see rec circel. Alos make sure you removed the return spring that pulls back the presser foot (not meaning foot pressure spring)
Anyone Heard of a "Bind-All" binding machine?
Constabulary replied to hemiyota's topic in Leather Sewing Machines
to me it looks like a Juki 555 fabric / tailoring machine of some kind -
Singer 29k1 presser foot doesn't work
Constabulary replied to MelissaViarengo's topic in Leather Sewing Machines
you probaly have chosen a short stitch lenght or the bell crank lever is worn down (or both). Maybe teeth on the presser foot are dull / worn down. Also theck if the "gib" on the stitch lenght adjuster is installed correctly. See pictures here: -
Looking at this picture I belive the Singer 107w hinges are the same. https://www.college-sewing.co.uk/202258-210844-machine-hinge-hook-singer-107w.html?srsltid=AfmBOopJb1ilppAZoElRixRJKheoNF9ftFELvIPI6Cw_MaVvn7w75taq https://armastore.eu/210844-singer-107w-hinge-hook You will get them on your end as well just check the numbers online But I would probably buy the female part too - you never know....
Adler 205-370 - help an old man who screwed up
Constabulary replied to councilman24's topic in Leather Sewing Machines
Looks like the shuttle race is not installed correctly, -
in addition to my last post: Just in case you think the 29K71 (or other patcher machine - no matter the brand) is a great heavy duty leather sewing machine ... it clearly is NOT! Its is a machine for repair work but not for producing leather goods. It may work for odds and ends in your privat environment but not for pro leather work or for producing goods you probably want so sell. I´m barely using mine but if you need it for "odd work" then it is indispemnseable - it can do work that other machines can´t do.
A Singer 144w as it seems. More or less the "fat brother" of the Siger 111w.
depends on what leather product you want to sew with what needle / thread size. By design it is a high speed tailoring machine and not really a leather sewing machine. It would not be my 1st or 2nd or 3rd... choise.
I´d check the needle - hook timing / needle bar height. My guess is the NB is set a little to high.
Singer 132k6 capabilitues and upgrades
Constabulary replied to Ed Neil's topic in Leather Sewing Machines
I´d try this by hand cranking the machine but again the needle hole has to be wide enough for 2 thread strands + needle. 214x1 / 328 needles have the same dimensions as 216x1 and I´m using the 214x1 in my machine w/o problems. 216x1 has a slightly different needle tip they have some kind of channel in the tip - not sure why. In case the hook tip hits the needle you have to move the hook a bit to the right and probably the bushing of hook driving shaft too. But it depends on how the machine is set up. Back in 2015 when set up my long gone 133K I started this topic: -
why is the bottom thread under the latch of the bobbin case? Always good to read the manual fully (no offense) - I guess you have a manual, right?
