cgleathercraft
Everything posted by cgleathercraft
might try cutting the dyes with alcohol (oil dyes) or water (waterstain dyes). That should result in a lighter color that you can add to till you get the darkness you want. Make sure to test everything out first.
Double Shoulder Rig For A Mac 10
cgleathercraft replied to sscow's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Wild looking! If you take on the job make sure to post some pictures. Sorry, Can't give any advice on measurements. -
What are you planning on making?
+1 to Barbour and Tiger thread. I use Barbour in my needle and awl machine. Strong and stitches great. Tiger thread looks great and is extremely strong.
Knock on wood - haven't had a bad measurement sent to me yet. But I do send detailed instructions.
My website is in dire need of updating. And my workbench is calling my name. Life has a way of getting between the bench and I. Just added another repair project to the list this week. Hopefully I'll get some stuff whipped out soon. Thank you for the compliment! I am my own worst critic lol. 3d printing is a whole different world that can help any hobby or profession. the possibilities are endless!
Cell phone molds. Just make a ring of plastic and fill the ring with epoxy or resin. If you can make print high enough resolution tap offs would be easy to make. Wish I had a 3d printer
Oak Leaf Holster
cgleathercraft replied to Rohn's topic in Gun Holsters, Rifle Slings and Knife Sheathes
It's been said before (multiple times) - the lacing is superb! I wish I had the patience to sit down and do it. When things slow down i'll give it another chance -
Ordered a few things, Very happy with them!
How Many Prototypes Do You Make Till It Is Sellable?
cgleathercraft replied to DavidL's topic in Leatherwork Conversation
I went through 4 prototypes for my holster. all different designs and for 3 different firearms. My final finished product was exactly what I wanted and was the first holster I made for that firearm. While the prior holsters are functional they look like a 3 year old put them together (except maybe that 4th one). Practice and critical thinking are more important than attempting to master a single item in x amount of tries. Burn through a couple (cheaper) hides and make those mistakes. The lessons learned will be more valuable than the couple hundred bucks in your pocket. -
American Straight Needle Tension Issue
cgleathercraft replied to cgleathercraft's topic in Leather Sewing Machines
After moving i back the tension off all the way and made adjustments from there, As of right now i have it going through 16-20 oz total thickness pulling tight and looking good on both sides. Slowly pulled the tension in and adjust how deep to set the knot. All i needed to do. Now i just have to rewire the motor since the wiring came loose in transit -
Prepping A Shoulder For Cutting Straps?
cgleathercraft replied to Crazyjaw's topic in How Do I Do That?
Yeah just wrinkles. Wont be too apparent after tooled and dyed. Gives each piece a little bit of character! -
Most likely just wrinkles. Post a pic of what your seeing. -
Leather has been spoken for a couple times already so i'll skip it. As for glues, dyes, stains or any other product required for working with leather you might be able to find recipe's to make your own dyes. there are a few on here who make dye with walnut hulls (not me, yet) for various shades of brown and use vinegaroon for black (works very well and cheap to make). hope this helps!
- 8 replies
- leather
- suntainability
(and 4 more)
E.c. Stearns & Co. Harness Rivet Press Question
cgleathercraft replied to cgleathercraft's topic in Leather Tools
Nope. The anvil looks to take some form of tubular rivet. However the post on mine is worn at an angle and would most likely damage or set a rivet incorrectly. I haven't taken the time to repair it. Therefore, no research into what rivets I (we) need. Sorry!- 6 replies
- harness rivet
- rivet
(and 1 more)
If it were me - I'd get a side and cut along the back. I'd pick it out personally if it were an option for me (nearest is tandy and thats 60 miles). Shoulders will work for collars but could have some stretch. I second Herman Oak (haven't used W&C yet). You didn't mention the weight of leather. Doubling it up will increase strength and reduce stretching allowing use of a thinner leather. The thinnest i'd go for doubling would be 6oz. The thinnest I'd do for single ply would be 8oz (for non lunging dogs)
Finishing Inner-Sheath - What's Your Preference?
cgleathercraft replied to zachhbc's topic in How Do I Do That?
I use resolene and water 50/50 mix inside and out. 3 light coats. not too shiny and everything is nice and smooth on the inside. This is recommended by many others on the site and I'm happy with the results on my stuff. -
Sounds like a was to use even more of the deer I harvest each fall!
I'm moving Wednesday so I'm putting my research on the issue on hold until at least the next weekend. If it's the timing it can't be too far off. I'm guessing the tension is messed up and causing the majority of the issues. once I get it set up an running again i'll dig into it some more. -
Thread, needle, and awl sizes are all as recommended in the user manual. The bobbin tension is loose enough i fear the screw might work itself out while stitching. No luck yet...still playing around with it. -
New! Ulti Clips - Most Unique And Interesting Holster Clip
cgleathercraft replied to RMB Custom Leather's topic in Suppliers
These are very interesting. Would like to see a review if someone here has used them. At $10 a piece I can make quite a few leather straps with snaps... That's what holds me back the most. -
Seem to be having a tension problem when sewing approx 12oz. Some thicker stuff doesn't have much of an issue but does every once in a while. Top: Bottom: I also break the top thread every now an then. I've ran it slowly and it seems to be taking up too quickly and getting pinched between the bobbin housing on take up. I can get by with running it by hand but any faster than that will cause too much stress on the thread an pop it after a few stitches.
Silkfatblues Custom Shop
cgleathercraft replied to silkfatblues's topic in Motorcycles and Biker Gear
I was gifted a motorcycle from my father-in-law. I need to get it cleaned/fixed up and running good. It needs all new leather an i plan to make some bags for it. The pics have provided a lot of inspiration to get the project started! Thanks for posting!- 34 replies
- silkfatblues
- croatia
(and 5 more)
Agree with dikman Try a few finishes to see what you get. Rough-out will age nicely with use. Sun and rain will only cause an issue if it's never used and just laying around outside.
It might not be leather or the finish that they are allergic to. I'm allergic to nickel so everything from belt buckles to my wedding ring (white tungsten contains nickel) will make me break out....with enough contact that is. Snaps are usually nickel plated so they are a concern for me. Most metals will have a certain nickel content which eventually will cause issues to those with this allergy. Anything that covers the metal will work. Paint/sealer will be temporary. A liner is preferred. Whether it's just glued on or glue + stitch is up to you. Personally, I'd stitch it.
