toxo
Contributing Member
Everything posted by toxo
  1. The key on a tin of corned beef. You just push it in the slot. Maybe wiggle it depends on the size of your coins.
  2. Not the answer to your question Klara and maybe not much use to you but this will open any shopping trolley over here. Haven't had to worry bout a pound coin for a couple years now.
  3. I often use a solid bar poking sideways out of a decent vice.
  4. Made I larf that did.
  5. I spend half my life looking for stuff. I normally put it down to the poltergeist but I've recently worked out that if what I'm looking for is even partially covered by something else it becomes invisible to me. Needless to say I'll find it when looking for something else.
  6. In the past I used some see through window stuff from a gazebo.
  7. This first picture has the two parts together and sewn through like yours' This gives a dished effect. This pic shows the front panel over the top of the gusset and sewn through giving a more rounded look. Same pattern, same holes just a different look.
  8. Nice job Frodo. If I had a nitpick I think the look would be better and more rounded if the front panel went over the gusset. same holes just a different look.
  9. Forgive my ignorance Aven but I'll never be too old to learn. Never seen these before, how are they used?
  10. toxo
    Purse prototype
    Very nice Yin. Very clean and well done. I also, when it comes to Sheridan/Western, think less is very much more.
  11. Check out this thread.
  12. Has anyone managed to pour dye from a Feibings bottle without spilling any? You would've thought they would have helped us out by now with a pour able design. I don't think it's rocket science.
  13. Thanks. My daughter still uses the owl bag every day for work.
  14. A few bit's Including this one. And maybe this one. I think I still have a piece of it somewhere.
  15. How about make it in the flat, do whatever to make the partitions, bring the two edges together and use a fringe all the way down to hide the stitching. Or use laces to join the two sides and make a fringe at the same time. Not everyone likes fringes but I do.
  16. My first thought was the plastic tubes that go inside golf bags but if you don't want plastic you could make the tubes from thin leather, just sew em inside out along the edge on the machine and turn em right side out, stitch em together top and bottom and insert as one piece.
  17. Whilst we're on the subject I did find this which might help not making em dull in the first place. https://www.ebay.co.uk/itm/111749803736
  18. Wish I'd had a decent sized "yard" to explore. You guys take that sort of thing for granted, over here there's far too many people for the amount of land hence the "portions" are smaller. Also, whenever someone buys so much as a garage they put a fence around it. That's the only thing I envy you guys for is the space and the freedom. You should cherish it cos someday some arsehole will try to change it.
  19. There's no such thing as a free lunch.
  20. We can all pick a project to suit an argument. I had no specific project in mind, I was merely pointing out that it's possible to mould - dye and then stitch.
  21. Here's another showing dying before stitching.
  22. There's no detail here but it shows the principle. If there were detail such as a gun it would be easy to get out.
  23. Let me first state that I don't make holsters. That being said I have wet moulded many other things. There are many examples on Y/T of getting detail into wet moulding using all sorts of tools including bone folders and fingers as the leather dries. When I pondered this problem I assumed the back of the holster would be flat, (why wouldn't it be if it lies against the body?). But now I understand that not everyone makes holsters this way. If I were to make a holster this way I would wrap the gun in plastic film, lay it down and prop it up level, then using some kind of moulding clay I would press it all around the gun to make a mould. Then using something like resin I would pour it into the mould to make a form that I could use again and again using the normal wet moulding techniques.
  24. We're all different I guess. A blue gun would assume not a one-off. I think I'd rather make a slightly smaller mould and do it the easier way.
  25. Ah, you mean shove the actual cling film wrapped gun in the wet holster rather than use a mould?
