toxo
Contributing Member
Everything posted by toxo
  1. OK, so it took a bit of fettling but from what I've learned ALL binders need some fetting. For starters, in my ignorance I asked for the wrong folder and it was too small. I had a couple of this type to play with and they seemed a bit simpler. Took a bit of working out to get it in the right place whilst retaining all the up/down backwards/forwards options. I also wanted to keep the original bits in case I need them later. Yay! My first ever bind. not perfect yet but definitely progress. I won't show you the back side just yet
  2. Walking around the supermarket yesterday I noticed that they use a thick dense cardboard between the layers of bottled water (and other stuff). There was loads of it and I thought it would be ideal for pattern making and laser practice. If it's rolls you're after they're around 3ft square so would make around a 12inch roll with a bit of tape or string.
  3. Just received from where I got my JL341 inc 10 more bobbins. £55 delivered. Now to work out how it works. I do love playing.
  4. There's always UP.
  5. HaHa dikman, your "shop" looks smaller than mine. I have similar boxes along a top shelf. Here's a quick idea, don't know how high your ceiling is or the new press but you seem to have a convenient height at 4 boxes down. Break there, lift the upper 4 boxes up and fix to the wall. A bit more rudimentary woodwork gives you somewhere to put the press and maybe even a bit more workspace.
  6. A bit of a useless debate IMO and one that doesn't seem to be taking usage into account. I've never known a thread that simply holds two pieces of leather together to break no matter how it's sewn (bonded polyester/nylon). Can you snap a piece of V69 with your hands? If you can you have thick skin. Thread used under high stress conditions is different and is usually sewn inside a channel to avoid abrasion. As dikman said, I think a certain amount of ego comes from the S/S camp but you can say that about quite a lot of leathercraft and there's nothing wrong with it as long as it's not part of a strength debate.
  7. Thanks for the replies guys. Let me start by saying that this idea is just for cosplay/steampunk type use. Apart from anything else few over here could afford a bandolier full of 17 Hornet ammo. Not many own a 17 Hornet because our laws dictate that you have to have the land or permission to shoot land before you can have one and at around 3600fps there's not much land left that hasn't been carved up in one way or another that can take that range. As you can see a normal belt size won't do it. After reading these replies I realise that they don't need straps and buckles etc. Just fix the bottom end however and throw it over the shoulder. If it looks good I'll do another to go over the other shoulder.
  8. It's that curve that has to be thought about. Shouldn't take much to work it out, just wondered if there was a "standard". I used to reload including reforming 22 Hornet cases sometimes. Still got the presses and dies somewhere so if I can find the heads it should be easy to set em.
  9. I came across a tin full of spent 17 Hornet cases and I thought if I can find the heads it might be interesting to put some around a hat or maybe make a bandolier. Does a bandolier have a "pattern" or just make it up? Might have some .223 around somewhere also.
  10. Thanks for trying but it's not that big a deal. Wasn't for my benefit anyway. Was just hoping for a copy and paste sort of thing.
  11. Just trying to get a short vid from a Chinese factory on WhatsApp into L/W because some peeps won't have WhatsApp.
  12. An almost accident but a powerful lesson learned. A guy in the pub asked me if I wanted a couple of days work. It wasn't until later that I found out that he was a nutter with no fear of heights at all. We went to a brickyard in Kent where they wanted another 12ft built on top of the chimney. It was tall but not so tall that this guy had built some scaffolding around it up to the top level. I use the the word "scaffolding" in the loosest possible terms. When we first got there I went up for a look at the view. No guardrail and only 3scaffold boards wide. Not impressed. My job was to send up the bricks and mortar. On the second day I found myself well in front so I went up to look at progress. He'd built around 4ft. I was on my haunches livening up the mortar out of the strong wind until I stood up. I was already on the last board, the wind got me and I did the proper windmill bit with my arms. I still wonder how I managed to stop from falling to this day.
  13. In a previous life I was a fabricator/welder using stick welding and I had to visit The Royal Eye Hospital in London a few times. Because the slag is non metallic they can't take it out with a magnet. They have to dig it out. The first time I put my chin on the black and chrome contraption the guy on the other side comes at you with this spikey thing, shines a really powerful light in your eye and says "Don't move, don't blink" and then pluck pluck. Believe me with the tears falling down you face you don't move and you don't blink. When I was done a big black nurse put drops in my eye and started to bandage me up. It got tighter and tighter and I think I might have fainted. (I was only a whippersnapper). My trauma didn't end there ........ I'm outside waiting at a request bus stop at the end of a long wide road which is a one way. The buses turn into the road about 250yards away and if no-one has their arm out on my side they keep over to the far side ready to turn right. Half an hour later, there's me still there because I couldn't see the number on the bus with my one eye until it was too late and he was turning right across the road. Eventually I learned to hail whatever bus turned around that corner.
  14. Close shave. Did it wrap around your shirt?
  15. I didn't want to tag this onto the sewing machine accidents post so I'll say it here. Many years ago an engineering pal told me about the day when when a 1 1/2 inch by 12 inch grindstone came loose at full speed. It whizzed around the workshop 3 times causing much damage before coming to a stop such was the inertia. My worst nightmare accident is getting a tie caught in one of those. You wouldn't be able to stop it in time. Makes me shiver. Is why ties are banned.
  16. My dogs (only two left now) won't leave my side even when sitting on the loo they have little beds at my feet. This goes for the project room as well and once or twice one of em has trod on the pedal, fortunately at a safe time. I know I should find a way to stop this happening. If I kept them out of the room they would howl the place down.
  17. Thanks Chuck. I'm ok generally, just the old stuff like underactive thyroid/kidneys etc. This scan and that scan. Most of it I can handle in a breeze but probably because that throat cancer in 2000 left my throat like a mouse's EARhole, that camers down my throat was worse than a bitch. Afterward my BP went up to 257. Had to sit there till it went down but at least he said he didn't find anything too dramatic. As for my Millie, what a little soldier she was. Always drawing the short straw including Pyometra? when she was young. Couldn't watch the light going out of her eyes little by little any more. Was feeling guilty today because I found myself with extra time because I didn't have to look after her any more. I know most dog lovers go through this at one time or another but doesn't make it any easier does it. Thanks again Chuck. Appreciate it. Thanks Darren.
  18. After listening to you guys I have to be thankful that the hospital is just 20mins away. Just as well cos I've had a couple weeks of it, the latest was a camera down my throat, through my stomach and into my bowel. I'm brave says I, don't need sedation. My God. After 20 mins of gagging and coughing and worse( can't say more else @Northmount will tell me off.) Never again. That was the day before yesterday. Yesterday I put my dog to sleep. Getting old sucks.
  19. As a soon to be 76yr old Brit, I was forced to change after getting used to imperial. Probably a bit more au fait with metric than you guys but I still get confused sometimes but no-one can deny it's easier to mess with units of 10 than it is with 12 etc.
  20. Not to mention that it could be exactly the same machine. There will always be the issue of after sales service or maybe the lack out it. When I bought my machine I tried to eliminate any problems that might arise by asking many questions and asking for videos to be doubly sure and making sure to order a flatbed and extra bobbins. One thing that pleased me was the option of self oiling. Always felt guilty in the past that I might not have oiled enough.
  21. I think we're getting to the point where all the clones are merging into the same machine. Don't know the specs re needle/thread size but be aware that this price is for head only. Table, motor etc will be extra as will the shipping.
  22. Die Making Supplies & Tools Special offers
  23. Let me start by saying my machine doesn't get an awful amount of use. The short answer is no but that's because I haven't tried. I usually use it on a slow setting and I find it easy to get the needle where I want it with small movements of the pedal or the handwheel. Maybe I'll have another go at it sometime later but at the moment I've other stuff on my plate including a very poorly dog. I will say that I'm impressed with the machine. I've just stitched both sides of a 60 inch strap on 20 and it didn't bat an eyelid. Can't say that of other machines in the past.
  24. Since setting up my machine I've got it working so I can use it easily and so haven't look at the finer details but I have to say something that's on my mind before I forget it. If you take the cover off the normal NPS there are two serrated discs and they have gaps in them which stops the motor. You can get the needle where you want it and then turn the disc to suit. One disc for needle up and one disc for needle down. I used this method for a long time until I got this new one which has a speed reducer. What I've said here doesn't seem to work with speed reducers but if yours doesn't have one it might be worth a look.
