Everything posted by garypl
Nice rifle! I would line your case with some canvas - shouldn’t cause any problems with the finish rusting.
Using an arbor press on solid copper rivets + burrs?
garypl replied to ColdEye's topic in Hardware and Accessories
I use a small ball peen hammer to round the edge after cutting the rivet. Much quicker and easier than using the tool. -
Finally Finished Shotgun Shell Pouch
garypl replied to garypl's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Thanks to everyone for your kind comments! I used bison for this very reason - very strong leather, soft temper and easier to bend around curves. I use a very fine tipped artist’s brush and carefully dye all the black background and letters. Took a couple of hours to finish this one. very nice work! -
Friend asked me to make him a shot shell pouch when I had time. Finally found some free time to finish it. Front and back panels are HO 7-8 oz and gusset is 4-5 oz bison. Saddle stitch the gusset to the panels but used my machine to sew the back flap and gusset folds. He likes it. Now he wants a belt!
Rifle Scabbard
garypl replied to pmieras2000's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Beautiful job - you should be very proud of making something that will be a keepsake for him! -
Consew 206-RB4 oiling mechanism and sewing speed?
garypl replied to sojourner999's topic in Leather Sewing Machines
Buy them on eBay - I bought a complete tensioner assembly for @$16 a year or so ago. Probably a bit more now due to inflation. -
Called blocking or the easiest way to do this is to airbrush darker dye around the edges.
It does fit an N frame with the thick welt and I used it in a match this past weekend - carried a S&W 38/44 revolver just fine! I just wouldn't sell it to anyone! Going to start another holster and make my own pattern this time.
Put the handle in a vise or wood clamp outside that will hold it upright. Take an ingot and a propane torch and hold the ingot over the hole in the handle and start heating it and let the molten lead drip into the handle. I do this all the time when melting lead for bullets and the pieces are too big to fit in the pot. Easy to control and very little fumes.
Looking good! Sounds like it was an interesting project.
Slicking inside of holster
garypl replied to MarlinDave's topic in Gun Holsters, Rifle Slings and Knife Sheathes
This is a great idea! -
Latest bag commission
garypl replied to Bogwot's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
You made a beautiful purse there! -
I have a couple of knives from Terry Moore that are very nice and sharp. Very well made and good looking to boot. They are a little thicker than some of the other knives. Pricing is very reasonable as well. https://leatherworker.net/forum/profile/1667-t-moore-medicine-hat-saddlery/
Colt King Cobra holster
garypl replied to dakotawolf's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Nice job - he will love it! -
Thank you - I think I will use the same design for the carving, just make the whole holster a bit larger.
Chuck - I did make a heavy paper pattern and thought it would fit easier but obviously I miscalculated! I am going to use a similar patter again but this time I will expand it another 3/4" around the edges and trim after I sew.
I normally do go very slow but I think the main problem is sewing too close to the edge on this thick of leather. Next time I will leave the back piece wider to provide the extra support and hopefully will have a better result to post! Yes & Yes - need to make it wider for better support - made a mental note to myself about this, now if only I can remember it!
My dog is so small she would have a hard time fitting it in her mouth! Thanks, my scrap pile has a few tooled pieces to remind me how not to tool!
I think both of your comments are right on. I was trying to keep the edge perpendicular but when the edge is that thick it doesn’t take much of an angle to end up coming out the edge! I did use the pattern from the How to Make Holsters book and I agree that it is a bit small for an N frame. A friend of mine suggested adding 3/4” to the pattern dimensions to allow for a thinner welt and to move the stitch line in a little more. Always learning something new…
Well I was almost finished making a holster for a customer’s S&W M29 revolver and when I sewed the seam things went south quickly. The thickness I was sewing was 3/4” with two layers of really hard temper veg tan for the welt. I was using 346 thread and #26 needle in CB4500. About 1” into the seam the needle deflected and came out the side, hit the needle plate and broke. Tried it again and deflected again - the leather was so hard the needle was bending. Finally gave up, removed all the thread and hand sewed it, but the damage was done, so I am keeping this to remind myself not to use such a thick welt. I used a pattern from Stohlman’s book for a 357 revolver and I think it might have been for a K frame and not an N frame. This is why I added the thick welt so the N frame would go in far enough. Lesson learned - I will make my own pattern for the second holster and add a little width to allow use of a thinner welt. Live and learn!
You made a nice case there! I like to make cases from soft temper leather - I like to use elk hide. Sew the case inside out and then pull it out so stitch line is inside. I double stitch using a machine but I think a single saddle stitched seam would be perfectly adequate. Here is a pic of an elk hide case. Gary
Do you bevel your edges before applying dye and what applicator are you using? I find it easier to dye edges after I bevel them. I use a felt chalkboard eraser cut into small pieces and held in a spring clothespin to apply dye. Dip the piece of eraser lightly into dye and apply to edges. Don’t soak the eraser - just dip the tip and go slow and you should not see bleeding onto the back.
Nice job with the card! Good that the year is not on it so you can reuse it!
