Everything posted by Colt W Knight
My first attempt at a Ranger Style belt I needed a new work belt, and I was tired of my old belt stretching so much. This one is pretty HD. 13 ounce latigo I had left over from making GPS tracking collars. 1" portion of the belt is 8/9 ounce veg tan with copper rivet reinforcement Now I want to make a more decorative one.
Ranger Belt Questions.
Colt W Knight replied to Colt W Knight's topic in Gun Holsters, Rifle Slings and Knife Sheathes
My over lap is about 2" longer than the 1" strap with the holes punched in it. The inside opening of my buckle sits flush with the wide end on the other side of the strap * still need to finish burnish the edges and add a few copper rivets. Belt is 13 ounce latigo I had left over from GPS tracking collars I made for cattle. The 1" straps are 8 ounce veg tan. -
Colt W Knight posted a topic in Gun Holsters, Rifle Slings and Knife Sheathes
I have never owned a Ranger belt, but have wanted one after I saw one for the first time ( and new what I was looking at). Decided to make one, but I couldn't find any guidelines about the over laps. I just winged it after looking at a few picture. Couple questions for yall. 1. How long do you make your overlap on the wide part that tucks in behind the belt? 2. Where do you position your buckle in relation to the end of the wide part of the belt? -
Roll Top Version 2
Colt W Knight replied to Hi Im Joe's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I am pretty sure those copper rivets come from the factory with a coating to keep them from tarnishing in the box. Once you cut, hammer on them, it wears the coating off leaving them subject to tarnish. Yes, you can polish off the corrosion. Something like Never Dull will take it right off. If you want to prevent the tarnish, you can top coat them with something. -
Roll Top Version 2
Yes, Copper rivets will turn green. I just had some do that. -
I amazed by the original artwork you biker and tattoo guys have. I struggle with faces. Did you actually use your knife on the face, or just trace it on with a stylus?
Raw, Veg Tanned Guitar Strap Question
Colt W Knight replied to geckostraps's topic in How Do I Do That?
It will look even better with age and dirt, but you can add a layer of protection like resolene or leather lacquers like wyosheen -
Do I Really Need An Airbrush For Dying Leather With Acrylic Dye?
Colt W Knight replied to HC009's topic in How Do I Do That?
Glad that turbine system is working for you. -
Do you use an awl or a chisel to make your holes? When I used a chisel, I found I had to dye, allow to dry, seal, then punch the holes. If I punched the holes, then dyed, I couldn't keep the thread clean.
Any Other Hand Cranked Machines Than Tippmann Boss?
Colt W Knight replied to Edvin's topic in Leather Sewing Machines
Depending on thick you need to see, you can pick up older treadle operated Singers. -
Roll Top Version 2
Just read your post about the frayed thread. I went through that when I switched to 138. What I found is that indexing the needle properly was key with the larger thread. When I used #92 thread, it really wasn't that big of an issue. However, when I switched to 138, I found that the slot on the needle has to be aligned perfectly, or it causes fraying problems. The needles I use don't have a flat spot to index them, so I have to watch very carefully to keep the grooved side of the needle on the left and not twisted any to the back or front. Another thing I noticed that would cause problems is if the bobbin was almost empty, or the needle is dull/nicked. I just read another post of the Leather Sewing Machine forum that said you can easily index the needle by using a toothpick. -
Roll Top Version 2
Bags look nice. I want to start making bags soon. Quick question, why the roll top instead of something like a zipper or hasp? -
Nice stamping. I was going to buy one of those nice Cowboy machines, but I had some things come up that ate away my sewing machine fund. I hope to get saved back up and buy one by January.
Mine does this if the needle isn't seated just perfectly.
My sewing machine does this if I don't have the needle turned just pefectly. I don't K own what needle system you use, but mine has a round shank, so indexing the groove on the left side of the needle is critical. It will also do this if the bobbin is about empty, or the needle is dull.
I don't have much real experience with lvlp. So take this with a grain of salt. I do not think you can cover a hide that quickly with a lvlp. I think you will want a hvlp to get the volume up. That leather is going to literally suck up the dye you spray on it like a sponge. I doubt that compressor will not run during use with a spray gun. That doesn't mean it can't keep up on small projects though. It's just going to be noisy. Ideally the compressor will keep about 120-140 psi in its tank. You will have a pressure gauge on the tank to adjust how much psi the compressor will hold before the motor kicks on and starts refill ING the tank. You will have another gauge that allows you to set the pressure to the Ling going to the gun. I generally set mine about 60-80 psi. Then you can pit a gauge on the gun itself that will allow you to control the psi entering the gun, ~30 psi. Then you fine tune the spray with the adjustment knobs on the gun. If the pressure gets to low, the gun will start to spray different and you can just release the trigger and watch the gauge till its ready to go again. If the pressure gets to low, the gun will start to spray different and you can just release the trigger and watch the gauge till its ready to go again. -
I would completely avoid electric sprayers. Everyone I have ever used either broke, or didn't function anywhere near as well as a pneumatic spray gun.
